Old 08-06-2018, 09:37 PM   #1
tabac
Default 2008 LT focus TDCI fuel issues
hey all
ive been having issues with my focus tdci latley the engine has been running rough when i start the car shakes for about 10 to 20 mins, last week the car wouldnt start, it would crank but not fire sounded like it wasnt getting any diesel.
i removed the fuel line before the filter, and cranked the engine it was completly dry, so i pumped some diesel into the line then pumped it back out and its starting flowing again its been fine since, but still have the shaking and rough idle.
ive pluged the car into the scanner there are no codes, im assuming its the in tank fuel pump which is the issue, if so how much would a replacement be? ive heard that the fuel pump needs to be coded to the car?
what you guys think could it be the fuel pump or something else? maybe the lines or feeder sock in the tank is partlally blocked?
thanks any help would be appracited.
tabac is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2018, 09:26 AM   #2
Default Re: 2008 LT focus TDCI fuel issues
Sounds like my old LT diesel when I put 91 petrol in bu mistake, but it took 210 kms, for this same stuff to show up. Has someone else put petrol in it?
kevino is online now   Reply With Quote Multi-Quote with this Post
Old 09-06-2018, 11:54 AM   #3
tabac
hey mate
dont think so it been doing it for about 3 or 4 tanks now, unless there is abit of petrol left in the tank, but if there was in sure it would of come though by now! dont recall putting the wrong fuel in.
Old 09-06-2018, 12:10 PM   #4
Maybe you had a bad bunch of diesel fuel. Used to only put Caltex Vortex and BP Ultimate in mine.
Might be a job for diesel injection specialists.
That's where I took mine after putting 91 in it. Didn't do it any harm. ran it for another 50000kms still went like a train at 278000kms when I traded it on an LZ.
Old 09-06-2018, 12:16 PM   #5
tabac
yeah you could be right, i was hoping to work out the issue myself and repair it.
Old 09-06-2018, 07:23 PM   #6
marg99
I would also check there is no air in the line above the fuel filter to the injectors
Old 10-06-2018, 10:59 AM   #7
tabac
thanks ill check that out
Old 04-03-2019, 12:34 AM   #8
fbvisitor
Just wondering if you got to the bottom of this?
fbvisitor is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2019, 10:27 PM   #9
Citwit
I recently had the fuel tank out of my 2008 focus LT TDCI to help in diagnosing a fuel problem (metal filings in the fuel filter) and found there is no fuel pump in the tank. Only the fuel pickup and fuel gauge sender unit.
Citwit is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
