Old 25-01-2020, 09:28 AM   #1
BMTf150
Default Eb to xa
Hi There
ive just had my XA converted from manual three speed and 4.1 to EB 302 and 4 speed auto everything is almost complete but I have to find a way to get the speedo to turn in the right direction , presently it is turning backwards.
Does anyone know how to fix this I have two weeks to do this or I have to re certify?
BMTf150 is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2020, 09:45 AM   #2
cs123
cs123's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Can't think of anyone more deserving. Russ Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all the technical support behind the scenes. Tech Writer: Recognition for the technical writers of AFF - Issue reason: Technical submission
Default Re: Eb to xa
Originally Posted by BMTf150 View Post
Hi There
You need to retain the vss from the transmission in order for it to change gears correctly if you are using the factory TCU. So you cannot just disconnect it unless you plan to fit manual shift kit
You can get a unit to convert the electronic signal from the vss to a motor drive for the XA from speedhut or places like that.
I love Holdens....
cs123 is online now   Reply With Quote Multi-Quote with this Post
Old 25-01-2020, 10:16 AM   #3
BMTf150
Cool thanks for that I think its called cable x ill look into it Cheers
