Old 25-08-2007, 08:54 PM   #301
philstoj
philstoj's Avatar
I cant remember exactly, though it looks about right.
Very strange why it isnt lining up, are you sure you are putting them on right?
I just managed to find the part # for the front brakes for mine.
They are:
- CALIPER ASSY RH - BAF2B118A
- CALIPER ASSY LH - BAF2B119A
- ROTOR FRONT BAF1125A X2
These are the kits FTG are selling, but before they included the slotted rotors.
Old 27-08-2007, 12:05 PM   #302
Perana
Perana's Avatar
Yeah I'm 100% sure..
I'm either thinking that we have been supplied the wrong calipers (I have a feeling that these are BA calipers) or that the FTG kits that a number of people have are actually BF XR calipers and Territory ones are different..
EDIT: Have measured up a BA caliper and it seems that we have been supplied the wrong ones.. will see if I can find a Territory to measure up this arvo.
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2007, 12:53 PM   #303
genebaby
Abuser of Charvels
genebaby's Avatar
From memory that doesn't look like a Territory or BF XR8 caliper. Remember, a Terry caliper looks the same as a BA one, it's just the bracket is a bit bigger.
Contraband Facebook
Daily: Tornado MY20 GTI
Retired: Venom BA XR8 - build thread
genebaby is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2007, 01:40 PM   #304
philstoj
philstoj's Avatar
The bolt spacing between territory,BF,BA, AU2 calipers will all be the same, so if yours are a wider bolt spacing, chances are they will be VE calipers, as the Holden's do have a wider bolt spacing.
Old 27-08-2007, 02:28 PM   #305
Perana
Perana's Avatar
The spacing between the bolt holes is the same.. but the spacing of the holes from the main caliper housing is where the problem is.
Though it doesnt really matter.. it's looking more and more like we were supplied the wrong ones.. Pity PBR dont put actual part numbers on the caliper itself.
Old 27-08-2007, 03:26 PM   #306
loxxr6
XB in parts...
loxxr6's Avatar
Wazza69: Can you tell any difference in the handling with the EB swaybar.
I can't tell the difference on mine but am interested in another opinion for my and possibly other people's curiousity.
Has Fez and XB.
Old 27-08-2007, 06:36 PM   #307
blackers10
blackers10's Avatar
is it worth getting an up rated swaybar from say whiteline??
also is the EA item the same as the EB-ED???
Old 27-08-2007, 09:53 PM   #308
wazza69
wazza69's Avatar
I haven't noticed any difference in handling at all.. mind you i haven't driven it much.
Current Rides:
2015 Ford Transit Custom
1967 ZA Fairlane 289W - Thread: https://fordforums.com.au/showthread.php?t=11456233
2005 Suzuki GSX1400
wazza69 is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2007, 10:47 PM   #309
Perana
Perana's Avatar
Have looked at a Territory and they ARE Territory calipers.. So it seems that there IS a difference between Territory calipers and BF XR calipers as far as the mountings and Territory calipers DO NOT fit.
Old 27-08-2007, 10:50 PM   #310
philstoj
philstoj's Avatar
What model ford are you trying to mount them to?
Old 27-08-2007, 10:52 PM   #311
Perana
Perana's Avatar
AU Series 2
Old 27-08-2007, 10:56 PM   #312
philstoj
philstoj's Avatar
Have you compared the stock calipers (mounting bracket) to the Territory calipers?
They have to fit as they all use the same stub axle virtually..
Old 27-08-2007, 11:01 PM   #313
Perana
Perana's Avatar
Yeah they are similar.. If we had BA Discs it would fit fine but the holes are 10mm out with the 322mm disc on.
The stubs are quite different Falcon to Territory.. LCA's are completely different and caliper is mounted at the Back of the disc on the Terri instead of at the front.
Old 27-08-2007, 11:06 PM   #314
philstoj
philstoj's Avatar
Here's a pic i took after i painted my calipers a few months ago no.
When i bought them of FTG, they told me they were the same, Territory and BF XR8, and they fitted real easy, bolt straight on.
Old 27-08-2007, 11:14 PM   #315
Perana
Perana's Avatar
That is what I was lead to believe too..
Guess i should have just got them through FTG.. but by time I added up postage etc it worked out cheaper to get them from my local parts supplier, and with DBA Slotteds instead of the RDA's
Old 27-08-2007, 11:18 PM   #316
philstoj
philstoj's Avatar
Can you post pics of the stock AU2 caliper and the Territory calipers (mounting sides together) ?
I was actually happier i bought them with the Ford rotors, before they made the kit with the RDA rotors..
These work very well on my ute, stopping power has improved 100% over the puny stock brakes, and you can notice a huge difference between the braking from the ute and sedan.
All i need is the rear ones and itll be complete.
Hopefully by the end of year ill have the sedan fitted with these brakes aswell.
Old 27-08-2007, 11:19 PM   #317
Perana
Perana's Avatar
Yeah will do when the caliper os off the car again..
Yeah just the size difference is massive.. I can imagine the difference they will make.. The Rears make the stock AU brakes look way too small too!
Old 30-08-2007, 11:37 AM   #318
Perana
Perana's Avatar
They are:
Phil, can I just confirm that these are the part numbers that were on your calipers when you got them. Seems like we willb e able to swap them for the right ones, but I want to make sure 100% that we will be ordering the right ones this time..
Old 30-08-2007, 12:04 PM   #319
philstoj
philstoj's Avatar
Yes mate, they are off the boxes i got with all the gear.
So did you findout which ones you were given?
Old 30-08-2007, 12:18 PM   #320
Perana
Perana's Avatar
Thanks for that !
It seems 99% certain they are Territory ones, everything is pointing that way. Ah well as long as we end up with the right ones in the end all is ok,
People just be careful that you get the right ones (BF XRT/8) or just buy the FTG kit!
Old 30-08-2007, 09:11 PM   #321
private9
www.TUFFCARPARTS.com
private9's Avatar
Originally Posted by Perana XR8
Thanks for that !
Now you've got me scared mate! I've got Terri calipers/discs waiting.....Oh well, we'll find out for sure when it goes to the brake shop!
Old 02-09-2007, 06:28 PM   #322
dansau1
Question au 1
will the bakes off the ba/bf fit to my series1 au falcon ute if so were to get the best price on them
dansau1 is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2007, 06:31 PM   #323
Casper
Contributing Member
Casper's Avatar
Not without changing a significant amount of front suspension.
You will need this as a minimim:
Stub axles
calipers,
discs,
EB Swaybar (and the pins/bushes for it).
The other option is to just change it all over to AU2/3 suspension specs.
Older, wiser, poorer.
Old 03-09-2007, 09:23 AM   #324
loxxr6
XB in parts...
loxxr6's Avatar
Best price may depend on what state you're in. FTG Auto Salvage (site sponsor) can hook you up. Different people have used different places.
Has Fez and XB.
Old 03-09-2007, 04:40 PM   #325
Casper
Contributing Member
Casper's Avatar
Just did an interesting comparison out of curiosity.
I currently have both a set of BA front calipers designed for 298mm rotors and AU2 calipers designed for 287mm rotors in my shed.
Looking at them separately the BA ones appear to be considerably bigger than the AU2 ones, as you would expect given they fit a disk 11mm larger.
Put them side by side though and the phisical size difference of the calipers is basically nil.
Take the pads out of each and the same applies. The BA ones look bigger until you match them up and they are almost identical. The AU2 pads have a more pronounced curve as you would expect to fit a slightly smaller rotor. Overall pad surface area is effectively identical though.
So there you go, the braking difference/effectiveness between AU2/3 and BA is entirely in the disk size (as opposed to AU1 to AU2 where the disk diameter is identical and the calipers are significantly different. Disk thickness is different but not a major factor).
This sort of comparison backs up the packages you can now buy on Ebay that uses the calipers for the 298mm rotors and converts the mounting to allow them to be used on a 330mm rotor. Same pad surface area, bigger rotor, more brake "leverage".
Old 03-09-2007, 05:00 PM   #326
Casper
Contributing Member
Casper's Avatar
oh, and for the record, it may only be an 11mm size difference but you can immediately pick the bigger rotor without fail. Its a noticeable difference.
Old 03-09-2007, 05:10 PM   #327
genebaby
Abuser of Charvels
genebaby's Avatar
Yeah, PBR don't do too much where they don't have to. A few bits on BA&BF calipers come from AU2. Rebuild kits for the front are the same as they are the same pistons and the slide pin is the same as well.
Contraband Facebook
Old 03-09-2007, 05:11 PM   #328
Casper
Contributing Member
Casper's Avatar
Id like to compare the basic BA pads to the Terri ones.. see if there is any difference there or if its just another rotor size increase.
Old 03-09-2007, 05:46 PM   #329
genebaby
Abuser of Charvels
genebaby's Avatar
There is no difference, pads are the same. When I looked into getting my BF/Terry calipers I looked into getting Formula pads again but a search for Territory pads said no go. Then I got QFM's, but I had them side by side when I got the brakes and they are the same. Later I also saw in a brake pad catalog that the part numbers are the same for both.
PBR engineered a different lower bracket to suit a larger rotor. Not hard for them to do in the end, but it works.
Contraband Facebook
Old 03-09-2007, 05:55 PM   #330
Casper
Contributing Member
Casper's Avatar
Basically the same as the change from AU2 to BA then. The calipers are different but really the main functional change is the lower bracket and a change in the inner bracket radius.
With the Terri calipers it looks like they probably didnt even change the pad radius.
I think the main advantage of going to BA calipers now is that there is an after market range of brackets now to allow the fitment of 330mm rotors and, I'm guessing, probably even bigger in the future.
