02-12-2018, 07:07 PM | #31 | ||
02-12-2018, 07:26 PM | #32 | |||
Sent from my SM-G935F using Tapatalk |
02-12-2018, 07:33 PM | #33 | |||
As a test, disconnect the vacuum advance and block it, then run the engine and see if it still has the flat spot, backfire? Also, when you have the vacuum advance hose connected reset the engine idle speed to spec, it should be idling too high. Unless there is something seriously wrong with your dissy, a electronic dissy will not solve the problem, but would be nice. |
02-12-2018, 07:43 PM | #34 | |||
02-12-2018, 07:50 PM | #35 | ||
When you reset your idle speed, also reset your idle fuel mixture, make sure the auto choke is not engaged.
02-12-2018, 07:54 PM | #36 | |||
02-12-2018, 09:03 PM | #37 | ||
There is a mixture screw at the base of the carburettor, this is the fuel mixture screw for idle.
On a pre emission carburettor you wind it out to add fuel. On a emission carburetor you wind it out to add air to lean mixture. On a emission carburetor the mixture screw may be hidden behind a plug to prevent tampering and which was to prevent people changing the vehicle emissions. I don't know when the change is mixture screw setting came into effect, you will have to use your initiative here. All I really want is you adjust until you have a nice steady idle at the specified rev's before we go on with the diagnoses. When you fit the new PCV, you will need to reset this. |
02-12-2018, 09:05 PM | #38 | ||
If the mixture screw does not have any effect on idle condition, you may have a vacuum leak?
02-12-2018, 09:07 PM | #39 | ||
02-12-2018, 09:13 PM | #40 | |||
02-12-2018, 09:18 PM | #41 | |||
There is a idle speed adjustment screw on the throttle linkage to adjust the idle speed. The mixture screw is to adjust idle quality to where it runs best. |
02-12-2018, 09:24 PM | #42 | |||
Experienced Member
Missing pvc valve could be your backfire problem as it will upset your engine vacuum, this can cause leaner fuel/air mixture ratio making it more volatile resulting in backfiring. |
02-12-2018, 09:35 PM | #43 | |||
My other thoughts where maybe burn valve or too much advance, but the above seems to be plausible at this moment. When you have a problem no one can solve, you must go back to basics and check everything and eliminate possible causes until you solve it. |
02-12-2018, 09:40 PM | #44 | |||
02-12-2018, 09:41 PM | #45 | |||
02-12-2018, 09:43 PM | #46 | ||
02-12-2018, 09:51 PM | #47 | |||
"Missing pvc valve could be your backfire problem as it will upset your engine vacuum, this can cause leaner fuel/air mixture ratio making it more volatile resulting in backfiring." Completely block off your PVC and try running the engine again and see if it reduces the back fire. |
02-12-2018, 09:52 PM | #48 | |||
02-12-2018, 09:55 PM | #49 | |||
Set how well (smooth) the engine run with the mixture screw. (the one at the base of the carburettor). |
02-12-2018, 09:57 PM | #50 | ||
02-12-2018, 09:58 PM | #51 | |||
02-12-2018, 10:05 PM | #52 | |||
It's getting too much air without it and too little air when it is plugged. Do you have access to another vehicle with a PCV to steal and fit to your engine and do a test to eliminate the problem? |
02-12-2018, 10:12 PM | #53 | |||
03-12-2018, 02:19 AM | #54 | ||
As Yearby said, you need that PCV. Gee, PCV's should be everywhere at the wreckers. A new one isn't necessary. Just find one, out of the same engine type and give it a good clean and rinse in solvent until it rattles freely. The things are virtually indestructible. Also, if you aren't sure about the accuracy of the idle mixture setting, a good starting point is to, screw it in all the way (gently), then back it out a turn and a half. That should get it very close. You may have to screw it in a little to lean it off until the idle is smooth.
Ya don't slow down as you get older ... you just enjoy taking longer to do it ... better! |
03-12-2018, 12:02 PM | #55 | ||
The engine won't run properly without the PCV valve, as the previous post says, almost anything will do, (I use a PCV from an FGX in an XT 221 log head motor)
Also you can't time an engine accurately without a timing light because of wear and tear in the timing chain and distributor. The book says 6 degrees +or-2, see attached page from factory XD-XC WSM. I had a 250 crossflow for 15 years and it ran quite happily set at 10-12 Degrees BTDC Check the condenser, if it's on the way out it can cause the motor to misfire or stall under load.
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
03-12-2018, 01:14 PM | #56 | |||
10-12-2018, 05:19 PM | #57 | ||
Soooooo I put my.pcv valve on. Adjusted the idle and the idle curb. I adjusted the mix screw and turned it in 1.5 turns (to the right) and it started to idle up. Got it idling nice. Idles in drive and does not start to labour. Flat spot is still there. Not as bad but still there. If I punch it from idle it pops half the time and not the other half. If it's not idling it very slightly pops but revs up. My timing is suppost to be done at operating temp with the vacuum advanced hose off. In drive or neutral? The timing is sitting at 10degress after adjusting my idles and screws in neutral. When the vacuum advanced is off it sits at 4 ish. Sp making progress. Better with pcv valve and adjusted the mix scree
10-12-2018, 08:11 PM | #58 | ||
Adjust the timing in neutral.
On the box the carb came from, is there a date or date range for the engine application? What is the manifold vacuum at idle? |
10-12-2018, 09:03 PM | #59 | |||
10-12-2018, 09:55 PM | #60 | ||
Ask your mates about borrowing a vacuum gauge. Failing that check online. Good prices are available, BUT before buying anything research both the product and the vendor.
