Hello all. I need your help please.
I am keen to buy a genuine Mk1 GT Cortina. Two of the cars I am interested in don't have ID prefixes that conform to the format I have seen on the internet. One claims to be an early Mk1 GT with an ID prefix of ABSCD and a model number 21112. I think this one is dodgy. The second claims to be a 1964 GT with a prefix of CBRCD and model number 27232. While the model number of this one seems OK the prefix still worries me. Also this car has the same numbers stamped into the bodywork. I have not seen any mention anywhere of ID numbers for Cortinas being stamped into the body work. Can anyone interpret all of this for me please. Thanks |
neither of those look right to me. look at this thread
https://fordforums.com.au/showthread.php?p=6700547 |
Thanks Simon. That is what I have been comparing it to. Both owners are adamant that their cars are legitimate so I am looking for advice from someone who knows more than me before I bail out on both of them. Cheers.
RS The Faster Fords
![]() Join Date: Feb 2014
Can't find any info on the first one, in 63 and possibly early 64 some GT's were being bought in from the UK for motorsport use, might be worth checking English model ID's
Heres a breakdown on the second. CB= Australian built R= Right hand drive C= May D= 1964 27232= 4 door GT There should also be some numbers on the chassis, Vin on the strut tower and a model number on the radiator support, this one will identify what it is, GT, 240, 440 etc. These can be missing if the radiator panel has ever been changed dur to accident damage.
Escort RS2000 Restored factory a/c and alloys. TD Cortina Unrestored 35 000km 6cyl manual. Mk1 GT Cortina Project. FG XR50 Daily. Last edited by Rallye Sport; 20-03-2024 at 09:22 PM. Reason: more info |
Thank you.
There is a 28112 code which is a 2 door deluxe with a 1200 motor
The 27232 is a 4 door GT The body numbers are stamped on the radiator support panel there will be another stamping on the RH strut tower early cars had a 116E engine casting number = 1500cc you really need to look under the cars to see if they have the tramp rods fitted real early cars have a strip speedo that goes to 110mph column tacho and 2 gauges in the console 64 cars had 3 large gauges these were the consul cortinas the airflow had 2 gauges speedo ,tacho and 4 gauges in the centre they were made through to 1967 |
Articblue
I'm hoping you may be able to assist in deciphering my ID plate on my MK1 GT Cortina. It reads as follows:
CG78GK 39659 210610 12437 F X K L |
CG Ford of Britain CKD (Broadmeadows assy)
78 4 door GT GK Feb 1967 12437 Cortina "GT" Sedan 4 Door - Bucket Seat F 1500cc GT X 4 speed close ratio floor shift K Silver Grey exterior ??? L 4.4:1 rear axle ratio |
Articblue
Thank you muchly appreciated.
Hi Chaps, I'm also hoping to find out the details for this Cortina GT, and confirm engine number please - 15CA13732
TIA, Steve K ![]() Last edited by SlotBaker; 28-04-2025 at 11:56 AM. |
#12 | ||
Code Body Description Engine Rear Axle
27234 4 Door GT 1500cc 3.9 : 1 FS March 1966 |
#13 | ||
Ivy green; really nice colour with modern COB paints.
#14 | |||
Thanks CB, can you please share with us, the source of your response?
I see the "27234" info from RSMotorsport. Any confirmation on what the engine number tells us? 15CA13732 Cheers Chaps, Steve K |
#15 | ||
#16 | ||
The short answer is, I don’t have a reference source outside my memory.
X is the colour code, I had a ‘65 Falcon in that colour - hence recognising it. The triple code represents roof, main body and any insert (like a side flash) colour. So, for example, AXX would be your Ivy Green car but with an Arctic White roof. (I also had a ‘64 Falcon colour code A88 - white roof on a lovely blue lower that I can’t remember the name of). |
#17 | ||||
#18 | ||
https://www.rsmotorsport.com.au/ford...rtinamkii.html
this has the X - Ivy Green (for a 67 mk2) but not what XXX is overall the mk1 page here doesn't list an X at all, nor does it have 4461 as a trim code. https://www.rsmotorsport.com.au/ford...ortinamki.html |
#19 | |||
There is another thread by Paull, https://www.fordforums.com.au/showpo...34&postcount=4 where he posted; "1965/67 codes and colours D = Sunlight Beige met N = Honey Gold met X = Ivy Green met Z = Silver Blue met" Which doesn't specifically mention Ivy Green for the Mk1, so I'm not 100% sold on that yet. The colour on the car looks like it could be right, so I'm going to go with it until I can confirm, one way or another. ![]() I originally thought the "XXX" may have been non-standard colour, or some other instruction. Thanks mate. Last edited by SlotBaker; 30-04-2025 at 10:36 AM. |
#20 | ||
I'm still looking for some info about the engine number to confirm if it's the right donk for our GT.
Engine No. 15CA13732 Can someone point me to where to find the details? Many thanks. Steve K Last edited by SlotBaker; 30-04-2025 at 10:46 AM. |
#21 | ||
That is Colour “X”, Ivy Green, absolutely.
I’ve tried to explain the three-character colour codes clearly; it would be churlish to reject the information because I can’t cite an internet resource. Ford would not invent a parallel yet different regimen for colour notations on other models they made in the same country, in the same year, for the same market. |
3 users like this post: |
#22 | |||
I'm sorry if I upset you, and I'm certainly not wanting to be rude, or ungracious. Yes, you did explain your reasoning behind your comment, I accepted it and thanked you. I have no reason to question how Ford operate, and your rationale is sound. My mindset comes from 20 years of doing genealogy research about my family, and unless information can be confirmed with "official" records, or by multiple sources for cross reference, it can't be accepted as factual. Thanks again for taking the time to give me feedback. Steve K |
#23 | |||
RS The Faster Fords
I find it a shame that the word of an enthusiast is no longer accepted, I've learnt more about these cars by word of mouth and physical inspection than any referenced literature.
This is according to my factory parts manual, not that I doubted your answer in the first place ![]()
#24 | |||
I don't agree when you say that "the word of an enthusiast is no longer accepted", that's not globally true, for the most part of our hobby, that is what keeps it alive. In my particular quest, I have 2 reasons for wanting to see 'formal' identification; 1/ To know that I have the best possible details, and, 2/ To be able to print out/keep the record as I compile a log for this particular car. That 'formal' identification could be many things, ranging from; Sales brochure, page/s from workshop or parts manual, factory newsletters or publicity announcements, advertisements, etc, etc. I've occasionally found errors in some of those as well, so it is sometimes difficult to be sure what is accurate. I'm a member of quite a few facebook groups, and forums across varying subjects, and over the last 35 or so years that forums have been going, I have been one of those "enthusiasts" that you mention, offering up help when I can. When I provide info, I do so knowing that I can back it up with either documentation or professional experience, which I could support with written proof if required. I certainly don't know everything, hence my posting this thread, and I'm learning with the help from people like you, CB, Simon, and everyone who posts in these threads. I did own a couple of Mk1 Cortinas in the 60s, (Consul 1200 column shift, and a 440 1500 stick shift) and knew a bit about them, but not the GT. So, I have accepted that the three letters denote body, roof and side flash combinations and paint code X is Ivy green metallic. I haven't seen so far, "(or Guinea green) on cars from March 65 onwards." Are you able to point me to where I could see this?, maybe a scan? Thanks again, Steve |
