Old 30-03-2025, 08:08 PM   #1
Eddie
Bush Mechanic
Default 1999 Ford Laser 1.6l Running Rough
Recently my mate made the unfortunate decision to buy a "running and driving" ford laser which upon arrival wasnt running and driving. The timing belt had jumped a tooth and was scraged but upon retiming the engine (reusing the belt) it now runs terribly(hunts at idle with it stalling out and can barely move itself in 2nd). I checked compression and got 140 psi on all cylinders and also checked for vac leaks but couldnt find any. Ive got a leakdown tester on the way but with compression being so even I have my doubts that itll prove anything. Any suggestions are welcome as I'm shit out of ideas.
Eddie is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2025, 12:51 PM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: 1999 Ford Laser 1.6l Running Rough
I'd suggest as it's OBDII compatible getting Forsscan and a dongle so that you can read error codes as a starting point becasue that may be easier than trying to guess what could be wrong.
Observatio Facta Rotae
Old 31-03-2025, 01:12 PM   #3
Eddie
Bush Mechanic
This one doesnt have obd 2 its still got the obd 1 "diagnostics" connector
Old 31-03-2025, 01:17 PM   #4
russellw
russellw's Avatar
It is OBD1 - there are OBD1 code readers around so that might be the only option.
Thread Tools
Display Modes
