Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Blue Streak Performance
Blue Streak Performance Specialist performance parts for your BA-FG Turbo 6 and V8. Contact
Old 05-04-2017, 08:47 AM   #151
JOSH
JOSH's Avatar
Default Re: PSI Miami.... The compound test bed
Originally Posted by XR8menace View Post
It's been like that for a long time... Funny but the 1/8 mile drag radial World Record is a screw blower car and the X275 world record in the USA was just reset by a blower car so there will always be a place for blowers.
Australian 1/4 mile Coyote record should be getting reset later in the year and I have a funny feeling that it will be done by a blown car..
any details on the car?
03 BA Pursuit
Blue Power Racing Developments
(03) 93053000
Ray Prescott Auto
(02) 49902488
JOSH is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2017, 10:08 AM   #152
CAT600
Making your Ford Better
CAT600's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Daniels knowledge of modular engines and superchargers is extremely valuable to the AFF community. I have learnt quite a bit just reading his build threads. His contributions are often utilised by other members. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always willing to help out fellow AFF members...
...Australian 1/4 mile Coyote record should be getting reset later in the year and I have a funny feeling that it will be done by a blown car..
Who said the AU would be running this year?
BLUESTREAK PERFORMANCE
New products HERE
"PSI Miami" BLUESTREAK compound turbo system development mule
CAT600 is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2017, 10:43 AM   #153
XR8menace
Haha, nothing would surprise me with you mate!
XR8menace is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2017, 12:24 PM   #154
XR8menace
Took the FGX back to the hub dyno today, we are still battling away with an issue preventing the car from revving clean past 7200rpm, so have elected to drop the rev limiter, pull some power out of it and it will be run at the track in the coming weeks.
I thought I'd post a pretty cool video showing the ZF shifting the 2-3 at "around 1200hp" on the dyno!
https://youtu.be/bNVnN4vFDMg
Yes they are precision turbos if anyone was wondering
Daniel
Sounds tuff mate, could you imagine trying to do that on a chassis dyno at your power level!
Old 05-04-2017, 05:31 PM   #155
BOOSTEDGAZ
When in doubt-MORE BOOST!
BOOSTEDGAZ's Avatar
AWESOME Dan, Absolutely AWESOME, Sounds so tough and so well engineered.
Can't wait to see a Modular running something like this
PROUD TO CARRY ON THE ALUMNATOR's LEGACY
PROUD TO FLY THE BLUE STREAK FLAG HERE IN NZ!!!
[SIGPIC][/SIGPIC]
BOOSTEDGAZ is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2017, 08:28 PM   #156
Tsar01
Cant get enough S/C5.0
Tsar01's Avatar
Thanks Dan I underconstumble now lol. Makes sense . Again beautiful work, gob smacking
AL
2011 FPV GS Sed, ZF Auto #283
Silhouette, Shadow Leather,
Prem Sound,Dual Zone Climate.
470- ish Rwhp@ 9.5psi Tune only Dual cone air pod with SS induction grill scoop, Rear exhaust delete, IMS Twin Bush Diff hat with Super Pro's.
Previous 2x Xb's, 3x Xc's, a Purple 302XD Fairmont, & Monza Red 6cyc manual XE:- S-Pak "worked" with bathurst 9" 12 slotters Lsd diff with short gears, EB Xr8 "Lemon". A few Lasers & Xf utes...Ef fairlane
.. Arrgg Ford thru n thru
Tsar01 is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2017, 10:16 PM   #157
XW Coyote
Yes mate, quite a bit the single turbo kit is well underway, hope to have an update on that next week or so... You guys are going to be impressed without doubt.
PSI MIAMI is having some beefier rods fitted as a precaution (read: take it up a notch ), I've also bit the bullet and done something I told myself I wouldn't do so soon and thrown some cams in there while its apart... It's quite a big job getting this engine in and out as you can probably imagine and I was always going to give them a try at some point so I though I'd kill two birds with one stone.
Hope to have it on the dyno before the weekend and maybe try to get to PC if everything lines up timeframe wise, it's a tall order but I like this working under pressure thing it seems
Daniel
Hi Dan,
It's been awhile since I've visited here. Good to see your kit has progressed. Excellent work.
What cams did you end up installing???
XW Coyote is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2017, 07:51 AM   #158
CAT600
CAT600's Avatar
Originally Posted by XW Coyote View Post
Hi Dan,
I went with some custom Comp grinds, lost a bit below 5000 but with so much down there anyway the amount gained up top was worthwhile
Daniel
New products HERE
Old 18-07-2017, 10:30 AM   #159
XW Coyote
Thanks for the update mate. Great work keep it up
Sent from my SM-A520F using Tapatalk
Old 27-09-2017, 11:05 PM   #160
DMENTDGT
ON CHARGE
DMENTDGT's Avatar
Any updates Dan???
cheers,
Andrew
FORD FALCON FPV GT 335
Lightening Strike
ZF Box
Leather
Cat Back 2.5" Stainless Steel Exhaust
5% Tints
Stock Power: 346.3rwkw
DAILY: Suzuki GSXR 1000 K1
PRIOR RIDES: BA2 xr8 ute, AU2 Xr6, EL xr8, EB Ghia 5.0L, XD 4.0L
DMENTDGT is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2017, 03:29 PM   #161
CAT600
CAT600's Avatar
Originally Posted by DMENTDGT View Post
Any updates Dan???
cheers,
Andrew
Not really mate the engine development is all done, she has had 40psi boost in it from 5000 to just under 7000rpm and it drops to 37 beyond that so even with a wastegate spring change we cannot hold any more boost up around 7200 so id say the turbine housings look to be tapped out. I am still trying to get around an rpm limit type issue that has plagued the car for around 12 months so i'm onto some ex-Prodrive people to see if its something that changed with GT-F and FGX and/or if its something I do not have access to with the software currently.
The transmission testing has gone very well while with the torque converter we settled on a different internal free wheel device than what we started out with (Sprag made way for a Mechanical Diode) as the Sprag gave up a couple months back during some track torture, so the new design should be ready to test soon.
My focus has been on a couple of customers cars with two blown coyotes on at the moment and a blown GT500 engine as well, we also welcomed a new addition to the family recently so its been all hands on deck at home!
Daniel
New products HERE
6 users like this post:
Old 28-09-2017, 03:54 PM   #162
DMENTDGT
ON CHARGE
DMENTDGT's Avatar
Daniel
Congrats on the baby Dan, best feeling in the world... well done
cheers,
Andrew
Lightening Strike
ZF Box
Leather
5% Tints
Old 28-09-2017, 03:58 PM   #163
CAT600
CAT600's Avatar
cheers,
Andrew
Thankyou, its our 3rd but the feeling is still pretty special, they are all so different even when brand new!
Daniel
New products HERE
7 users like this post:
Old 28-09-2017, 04:10 PM   #164
Mechan1k
Mechan1k's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with technical information. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Brings a wealth of knowledge to the forums and is frequently giving helpful advice.
Daniel
Congrats on the new addition.
I know the feeling ... our number 3 arrived 3 weeks ago.
I need more sleep
Old 28-09-2017, 05:35 PM   #165
CAT600
CAT600's Avatar
For those wondering what 37psi at 7200 looks like, this is on a mild ignition curve and very rich at .72 lambda (10.50 afr in gasoline equivalent)
New products HERE
Old 28-09-2017, 06:09 PM   #166
CAT600
CAT600's Avatar
Video of one of the other runs here:
https://youtu.be/BJZEqJ3oRt0
New products HERE
Old 28-09-2017, 08:01 PM   #167
custard
custard's Avatar
Congrats on the little one!! Always an awesome, sleepless time....
I know time will be limited, but any time you can find to drop a line on this beast, the voodoo or any other project would be super appreciated. Love it when I see the Cat Man has posted!
custard is online now   Reply With Quote Multi-Quote with this Post
Old 29-09-2017, 05:10 PM   #168
BOOSTEDGAZ
BOOSTEDGAZ's Avatar
Love that Video Mate!! She is a true weapon in every way and in the tradition of Terminator and Aluminator a Weapon in disguise.
from the outside just like mine it looks like a XR8 that's been lowered onto some rims and got a exhaust - Most don't look at the big brakes until they have a reason to look properly.....little do they know that particularly in your BEAST it is an all out Race / Street Outlaw that can and will destroy pretty much anything out there in diguise!!
As much as the FG is always going to be my favorite shape, Your FGX has really shown me that they can be made to look bloody awesome with the right wheels and stance and you have really accomplished the ultimate - as always mate .
I think it's fair to say you have more than achieved proof of concept and some!!
Are you still running the twin Precision 6466's?? or have you changed to bigger.
[SIGPIC][/SIGPIC]
Old 29-09-2017, 06:46 PM   #169
CAT600
CAT600's Avatar
Still the 6466's, id be pretty confident to say at this point that the .82 turbine housings are the limits, which if you consider the car is making 1600-ish at the flywheel then 800 per turbo isnt too bad at all.
PTE do make a 1.06 stainless housing for these turbos but unless I can turn the additional rpm id be inclined to leave this combo as it is and use bigger turbos elsewhere where I can turn 8000-8500 and 40psi up top.
Daniel
New products HERE
Old 29-09-2017, 11:10 PM   #170
custard
custard's Avatar
8000 - 8500 rpm, got an idea there's a voodoo in the wings that could manage that !!
Old 19-10-2017, 10:24 PM   #171
BOOSTEDGAZ
BOOSTEDGAZ's Avatar
There is another build out there that might accomplish that and some maybe some time in the near future But.... it it won't be with a coyote
Not that I have anything against Coyote's - quite the opposite but I already may have a particularly "Potent" Modular Combo, all I know is watch out when it happens.....it will be very special and a very OZ / NZ Combo - A Street Legal Race Car.
Road legal under my drag Licence and Logbook and minimum 3 Competition events a year so hopefully the car lives up to its new name ALMN8R and does exactly that to the competition and sets some Records in the process at least here in NZ it will definitely be the most trick late model engined Ford Set up!!
BLUESTREAK All the way with the build - I would not consider using anyone else so..... Just in planning but watch this space and The AluminaTTor Build Page....
Enough said.................. ...
GAZ
[SIGPIC][/SIGPIC]
Old 18-12-2017, 05:24 PM   #172
Day in day out, track to track, turbo cars just are not as consistent as a blower car when it comes to hooking up. When they don't hook, they stay unhooked.
solarite_guy is online now   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
