Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Blue Streak Performance
Blue Streak Performance Specialist performance parts for your BA-FG Turbo 6 and V8. Contact
Old 15-06-2016, 12:05 AM   #61
CAT600
Making your Ford Better
CAT600's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Daniels knowledge of modular engines and superchargers is extremely valuable to the AFF community. I have learnt quite a bit just reading his build threads. His contributions are often utilised by other members. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always willing to help out fellow AFF members...
Default Re: Diff Bushes
Hey Thommo.
Mate they are ready now and if you send me an email with your suburb I can give you an idea on who and how much.
bluestreakperformance@outlook.com
Daniel
BLUESTREAK PERFORMANCE
New products HERE
"PSI Miami" BLUESTREAK compound turbo system development mule
CAT600 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2016, 08:06 PM   #62
marcosanga
Hi Dan
Looking at a set of yr diff bushes for my 2005 Ba XR8 Series 2.
Ive got a rear cradle out of a BA XR6 turbo that im going to rebuild and swap out.
Are the bushes the same?
Marco
2005 BA Mk2 XR8 6SP in Velocity Blue, Full Premium Pack
marcosanga is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2016, 10:43 PM   #63
CAT600
CAT600's Avatar
Originally Posted by marcosanga View Post
Hi Dan
Marco
Yes Marco the front I make suit 2002-current it's only the rear bush that differs
Shoot me a PM if you are keen for a set
Daniel
New products HERE
Old 07-07-2016, 07:01 PM   #64
PHANTMXR6
It's not an FG MKI.......
PHANTMXR6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Willing to help out with useful advice in the technical areas of the forum.
Smile Re: Diff Bushes
Dan. I've had a failure of one of your front bushes.
When i replace them would you like me to send them to you for failure analysis?
06/08 Manual FG XR6T. Not an FG1 or MKI, an FG...
Want to know how to do an A Service for an FG XR6T?
Look in this http://fordforums.com.au/showthread.php?t=11339404
Thinking of oil sampling your engine?
Have a look at this trend http://fordforums.com.au/showthread....ght=oil+sample
PHANTMXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2016, 09:12 PM   #65
CAT600
CAT600's Avatar
Can do mate no worries... yours are from that date range around 3-4 years ago?
Did you want to have them recast its less that half the price of them new?
Daniel
New products HERE
Old 10-07-2016, 10:08 AM   #66
PHANTMXR6
PHANTMXR6's Avatar
Thanks Dan, but I'll be replacing them with Superpro items.
Was just more wondering if you wanted the old ones back to see if you can work out why one failed.
Not 100% but i think i bought them around 3 years ago. They've only done 10000ish kms though.
Old 10-07-2016, 01:16 PM   #67
CAT600
CAT600's Avatar
No problem.
Yes please mate if you PM me your bank details I will transfer you the cost of an express post bag so you are not out of pocket. In the last 3 years ive only had two pairs come back, one was a set that was laying about unused that had discoloured the compound and gone brittle (incorrect mixture ratio) the other set tore out but the rear bush had failed catastrophically as well so it was a bit chicken or the egg. The other 70 or so pairs in that time are all still going so far as I know so will be interesting to see whats happened to your set.
Daniel
New products HERE
Old 03-08-2016, 10:44 PM   #68
xexr6t
Hi Dan
Looking at a set of diff bushes for my 2007 Bf Series 2 GT.
Ross
2011 FG mkII GT Kinetic Auto 12.61@113mph
and 12.65@116mph
xexr6t is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2016, 07:03 PM   #69
xexr6t
Diff bushes arrived today
Thanks Dan
and 12.65@116mph
Old 30-10-2016, 06:06 PM   #70
GTpilot
FG GT 5.4 w/ additions!
GTpilot's Avatar
Originally Posted by CAT600 View Post
No problem.
Daniel
you must be talking about a set of mine, but your description does not fit.
my right hand side one has failed again. left is fine, so it must be the heat from the exhaust causing the resin to go brittle and shatter.
nothing to send back except the inner and outer aluminium.
Originally Posted by prasac
googoo gaga whoops sorry i thought this was the let's be whiny babies thread
GTpilot is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2016, 07:09 PM   #71
Silver Ghia
2013 Titanium Diesel RWD
Silver Ghia's Avatar
Sorry for butting in, but the right hand bush should have a heat shield covering it, and secured properly against the cradle body so heat cannot reach the bush.
Was this heat shield refitted properly with fasteners after bush replacement?
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2016, 07:50 PM   #72
GTpilot
GTpilot's Avatar
Who knows. I've never seen one there, but it does make sense. My local dealer has only ever been the ones to work on it.
Do you have any pics or diagram to show one in place? I can check it out.
Old 30-10-2016, 11:16 PM   #73
Silver Ghia
This is mine, ready for the cradle assy to be reinstalled in the car after fitting Dans bushes. It covers the bush completely.
The top fastener is an original rivet, the other two rivets were drilled out to allow the heat shield to be turned around to gain access to the bush for replacement. Replaced by bolts (can be seen in pic) which either screw into the hole in the sub assembly nicely with washers, or with a nut in the case of the innermost one.
The left hand bush can also be seen in the photo, no heat shield over that one (located immediately behind the fuel tank).
Old 31-10-2016, 12:25 AM   #74
[THOMMO]
[THOMMO]'s Avatar
Would be nice if you could replace the bushes without dropping the entire rear end haha
[THOMMO] is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2016, 12:32 AM   #75
FrogXA
Blown BF XR8
FrogXA's Avatar
I had the set that were unused for a while and were discoloured and soft/ brittle.
When I put the supercharger on, I knew I would have to replace the diff bushes eventually so I bought a set of Dan's bushes. However, I also wanted to fit a Wavetrac differential and a set of 3.73 diff gears so the bushes lay around for a while so I could fit everything all at once while the cradle was out.
When I checked the bushes before install, I noticed they were discoloured and soft and flaky. I sent Dan an email with photos of the bushes and he promptly sent me a replacement set no questions asked. These are the ones in my car now and I have had no problems with them since.
BF XR8 6spd Manual, Kenne Bell 2.6 intercooled supercharger, BPR CAI, Difillipo Big Boy twin 3" exhaust, Mal Wood Option 3+ clutch, Mal Wood short shifter, Brembo's, Shockworks coilovers, Wavetrac diff centre, 3.73 gears, Herrod tailshaft
FrogXA is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2016, 12:50 AM   #76
GTpilot
GTpilot's Avatar
Please don't take me the wrong a way folks, I have no issue with Dan or his service. He replaced my last set without question. Although I have had the same thing happen again a few years and only about 5000k later, (car is rarely driven).
Having said that though, it looks like my car is missing a heat shield, but I can say I don't recall having ever seen one there since the car was new.
Old 31-10-2016, 01:13 AM   #77
CAT600
CAT600's Avatar
No question heat is definitely an issue.
The set in my old twin turbo were in there from early 2010 until Gaz bought the car earlier this year and just prior to selling him the car I removed them to check them out after all the pain they have been through as well as extemes of heat etc and fit a new pair (as the planed hatched by Gaz was to step into the FG down the track but initially the car was going to traverse the Tasman to serve as a dedicated streeter until such time as it stepped up)... the original ones were still fine I have them sitting at home to show people that are interested.
Because I cannot control what people do (their mechanics removing the heatshield when fitting bushes and/or for exhausts that tend to foul on shields etc) I have several months back made a move to a compound that takes heat better (prompted by the full twin exhaust on PSI MIAMI that runs over the passenger side as well as the driver side which inherently has no shields) its very early days and while they are kicking goals now im not sending large quantities out until we can establish some longer term results.
Jason (GTPilot) your set was prior to the three years ago I was referring to, yours failed in May or June of 2013, as you know time flies.... if you are keen to run a set of this trial compound without the heatshield in place (be it a factory omission or its been removed by someone is not a concern to me) just let me know and I will send you a pair this week.
Regards,
Daniel
New products HERE
Old 31-10-2016, 01:19 PM   #78
GTpilot
GTpilot's Avatar
Hey Dan.
As always you are spot on and more than helpful!
I'll PM you
Thanks,
Jason
Old 26-12-2016, 09:49 PM   #79
XCH00N
XCH00N's Avatar
Hi, How much for a set of diff bushes to suit a 2005 BA MkII XR6 turbo?
THE SHED
Daily - BA Mk2 XR6 Turbo, Auto on 20s
Long Term Project - XB Sedan, too much to do on this one But its a 351, 4speed with a LSD 9inch (Back over home in NSW)
XCH00N is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2016, 07:11 PM   #80
CAT600
CAT600's Avatar
Forum price is $275 incl freight and GST.
This is the side/front pair the centre/rear bush I recommend Nolathane or if going for the ultimate solution IMS hat setup
Regards
Daniel
New products HERE
Old 03-02-2017, 10:56 PM   #81
XESP-351
Hi Dan, I also would like a price on the cat600 rear diff bushes.
Car is a FG 09 XR6T ZF6
From what iv been told i need.
Rear diff bushes X3
Centre bearing
Uni joints.
Also a postage cost to NSW 2526.
If you could pm me, that would be great.
Cheers Steve
XESP-351 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2017, 12:25 PM   #82
CAT600
CAT600's Avatar
Hello Steve.
We do not supply driveshaft parts, thats something best left to the specialists with the tooling to press joints/bearings and balance shafts.
Of the three Diff bushes, I only supply the front two as eBay has made it nonviable for me to buy and sell the rear one (you can buy it the same price I can)
The forum price on the front pair of bushes is $275 including GST and express post included.
If you would like to go ahead simply email me at: bluestreakperformance@outlook.com and we can get the details swapped over for shipping address, invoice and bank details
Kind regards,
Daniel
New products HERE
Thread Tools
Display Modes
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
