Old 07-07-2006, 05:17 PM   #1
mk2_1979_escort
Default Sierra 5 speed
Hey guys,
Hope his question doesn't ensue any lively debates hahaha..... But anyways I have found a sierra 5-speed in my local trading post and wish to fit it to my 1979 4 door escort. My questions are;
1. Will my tail shaft need to be shorted or anything drastic like that.
2. Will the manual transmission tunnel need any modifications.
Also any other pointer would be great.
James
mk2_1979_escort is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2006, 06:59 PM   #2
tufLTD
tufLTD
tufLTD's Avatar
Originally Posted by mk2_1979_escort
Hey guys,
James
Hey James,
It should bolt straight in. The tailshaft should be OK for length too. You may have to cut a hole further back for the shifter, I know in Mk1's the shifter sits about 2" further back with the Sierra box.
tufLTD is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2006, 07:45 PM   #3
Perana
Perana's Avatar
Depending on the tunnel (some are narrower than others) the original rear gearbox mounts (that are welded to the floor) may need moving as the box is a fair bit wider and won't fit. You'll also need a longer speedo cable.
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2006, 10:02 PM   #4
V8falcons
V8falcons's Avatar
Hi got a sierra 5 speed box in My RS .use a auto cross member and its a straight bolt up,though you need to move the gear lever hole back 2-3" and use a cortina 4 cyl(longer) speedo cable.
The ratios are no different to stock your just getting the 5th gear OD for express way use only.
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2006, 02:45 PM   #5
eski666
eski666's Avatar
Auto cross member hey?? Never thought of that! Should look into that as I have a very VERY dodgy set up lol!!!
eski666 is offline   Reply With Quote Multi-Quote with this Post
