Old 22-11-2006, 09:58 PM   #1
monkeydog
Shift for brains
Default 2ltr Pinto cylinder head bolt size
Hey guys,
Would anyone know what the size of the driver i'd use to on the bolts holding the cylinder head of a 2 liter pinto are?
I believe they look similar to such (this is a TORX type?)
https://burtonpower.com/pic_viewer.a...ead%20Bolt.jpg
I guess you'll either not know, or know.
If you are the later, please inform me.
Thanks, James.
monkeydog is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 10:50 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
hang on let me find the cortina book i have.
Damn cant find the book, i am sure its in the shed, will have to get in daylight, might even have the tool out there as well, will check for that too.
Old 22-11-2006, 11:46 PM   #3
monkeydog
Shift for brains
Thanks for this.
I have a Ford escort repair manual and Gregory's service and repair manual but am unable to find it. A double hexagon socket wrench appears to be the tool that needed, the size, I'm still unsure of.
As the bolt is the part that is the has the socket end, would this be a hard tool to come by?
Old 22-11-2006, 11:49 PM   #4
EA2BA
PM me if you want
EA2BA's Avatar
Originally Posted by monkeydog
Thanks for this.
yeah took me a while to find one in a 2nd hand tool shop at that, and i dont think it was all that cheap either.
not looking good this end, thought i could find the tool, a few other spots to check, but not looking good.
try find a UK car club for some info possibly.
Old 23-11-2006, 12:04 AM   #5
rag top
rag top's Avatar
IIRC, I think it is a twelve point bit, size 12. I tracked down a kincrome one in the 90's. I just pulled it out of the tool box to see if I still had it. It is a bit dusty!
I've seen the results of someone trying to use the incorrect bit to get them off. Does more damage than good.
Old 23-11-2006, 12:36 AM   #6
monkeydog
Shift for brains
Thanks guys. I've done a bit of research from the above information
and the 12mm 12 point socket is looking good.
http://www.asttool.com/product_images/6300_X-12.jpg
http://www.pelicanparts.com/catalog/...12Point_FW.JPG
If this can be confirmed, reply away (:
(I will measure it myself before buying any parts still)
Thanks again guys.
Old 23-11-2006, 02:47 AM   #7
THORNSPAWN
In the Forced 'lane
THORNSPAWN's Avatar
You can get the spline bits from supercheap for about $10 a set
XE S-Pack
4 Runner
XH11 Longreach
THORNSPAWN is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2006, 08:26 AM   #8
rag top
rag top's Avatar
Monkeydog, do you have a headbolt lying around, or be able to get hold of one?
If so, walk in to any tool shop, and see if they have one to fit.
The links you put up look exactly like the one I have.
Thornspawn's idea sounds pretty good too.
Old 23-11-2006, 09:50 PM   #9
monkeydog
Shift for brains
Ok, Thanks for your help guys, I think I have enough information now to get further in my attempt to obtain one.
I'll take a look in supercheap as well.
If I find the definate part, I'll post back here what it is for future reference.
-James
Old 23-11-2006, 10:00 PM   #10
eb_5litre
It'll Buff Out.
I bought 2 different sizes of these Spline Drives when I was into Eskys... still have them too I think and i'm pretty sure I got them from Pep Parts or similar. They are a long shaft with 1/2" socket end.
There was another bolt the same type but a smaller size..... the belt tensioner I think, might pay to get that one too.
When life hands you lemons, take them. Free stuff is awesome.
eb_5litre is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2006, 08:38 AM   #11
whooligan
whooligan's Avatar
....Unfortunately the 12 year olds behind the counter at my "Stupidlycheap" have no idea what I'm talking about. :
Would the person I lent my socket to please return it. :
Old 26-11-2006, 06:36 PM   #12
monkeydog
Shift for brains
Success,
I got a kincrome set of bits for around $50 from bunnings.
The part is a 1/2" (12mm) 12 point spline, labeled M12
Head bolts came out no worries.
Thanks guys.
..Now to get those spark plugs out
Old 27-11-2006, 09:40 PM   #13
XFshep
Bodysnatcher
mine had 12mm hex head bolts :S
guess someone replaced the original ones with something more user friendly.
XFshep is offline   Reply With Quote Multi-Quote with this Post
