Old 29-09-2016, 11:00 AM   #391
Professor Farnsworth
Spool & Whine
Professor Farnsworth's Avatar
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
Default Re: Wheels That Fit Brembo Brakes
And I've been chasing a good condition set for weeks, no joy.
cars.
Professor Farnsworth is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2016, 01:35 AM   #392
ivanflo
http://www.stgeorgetyres.com.au/pack...ct-detail.aspx
I was in the market for staggered 18 inch wheels and...
Apparently these 17 inch wheels clear Brembo's?
I believe them to be XXR 550's, anyone had any experience with XXR?
ivanflo is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2016, 09:27 AM   #393
HI PSI
Matt from Race Brakes Sydney is currently investigating modifying a rotor hub and brackets, so that I can fit Brembo's behind normal wheels. I'll keep you posted on further developments.
HI PSI is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2016, 10:09 AM   #394
FLOORED
Race Brakes Sydney
FLOORED's Avatar
The rotor is a two piece option and will run bobbins (which are being manufactured) and just waiting on them to proceed.
MATTHEW PEARCE
DBA SALE DBA SALE DBA SALE
http://www.fordforums.com.au/showthread.php?t=11450035
Phone 02 9609 1101
WE HAVE NOW MOVED ACROSS THE ROAD
U10 / 62-66 NEWTON RD WETHERILL PARK NSW 2164
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 01-01-2017, 09:36 PM   #395
Kezz1
Originally Posted by kboot6 View Post
These are lenso d1r I got fitted today
front 18x9 +15. 245/40
Rear 18x10 +22. 265/35
They fit over 4 pot brakes.
Its standard fpv height and the rears are rubbing on the guard lip so i might have to get them rolled and the fronts i might change to 235 if i can get enough rolled on the front.
Bit of a thread mine here.....
Kboot 6 - out of interest, how much space do the D1R's have between the wheel and caliper up front over the 4 pots?
Kezz1 is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2017, 02:38 PM   #396
08G63T
Would someone know if the following wheels will fit over 6pot brembos?
- Lenso Speed 2 in 19X8.5 Front and 19X9.5 Rear with P35 or P40 offset
- XXR 527 in 19X8.75" Front and 19X9.75" Rear with P38 offset
I'm going to assume guards will need to be rolled
08G63T is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2017, 10:53 AM   #397
Sunburst XR50T
Guys I'm wondering if anyone knows if 19" XR50 Turbo wheels will fit over the 6 pot Brembos? Or anyone in Sydney with 6 pots that I could see if my wheel fits over?
Cheers.
Sunburst XR50T is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2017, 11:45 AM   #398
irvinnie
irvinnie's Avatar
50th anniversary rims won't fit over brembos. I had to change rims on my ute when I fitted 4 pot brembos
irvinnie is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2017, 11:41 PM   #399
SIRGTP
Koya SF06...
20x9.5 front +22 clear easily over 6 pots and 20x11 +37 rear just clear rear 4 pots...
SIRGTP is offline   Reply With Quote Multi-Quote with this Post
6 users like this post:
Old 14-03-2017, 07:46 PM   #400
Six6
Can anyone confirm if Vertini Drift 19" x 8.5 +30 fit over 6 Piston brembo brakes? I can confirm that +25 do.
Six6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2017, 12:31 PM   #401
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Most suppliers will generally be able to tell you if that helps.
MATTHEW PEARCE
Phone 02 9609 1101
Old 15-03-2017, 12:35 PM   #402
Six6
Thanks for the reply FLOORED. I have tried getting in contact with them but they are unable to confirm if they will fit. But confirm that +25 will
Old 15-03-2017, 01:37 PM   #403
FLOORED
Race Brakes Sydney
FLOORED's Avatar
If you have 90mm clearance between the outer rotor face to the inner face of the spoke then they generally fit we don't work off the offset as the spoke can still foul.
MATTHEW PEARCE
Phone 02 9609 1101
Old 15-03-2017, 01:54 PM   #404
Six6
Thanks again FLOORED. Unfortunately It looks like it goes from 93mm to 88mm from the outer side of the spoke down to the hub side.
Old 15-03-2017, 03:53 PM   #405
FLOORED
Race Brakes Sydney
FLOORED's Avatar
This may still be enough for you and i would suggest if you can get a Ford with either 4 or 6 front Brembo's on you could check your wheel for clearance.
MATTHEW PEARCE
Phone 02 9609 1101
Old 16-03-2017, 10:02 AM   #406
HI PSI
Let us know how you go with it. I am sure that other will be interested.
Old 06-09-2017, 04:34 AM   #407
perthbfxr8
Hi fella's
I recently received Speedy Hotshot wheels from Autocraze (great people to deal with )
The wheels i went for are 19 x 8.5 all around with 245/35/19 rubber on the front and 255/35/19 rubber on the rear.the offset is +30 and they comfortably cleared my 6 spot brembo calipers and discs in front ( i am running standard Ford/FPV brakes in the rear ), the vehicle is a december 2010 FPV GS 315 ute
december 2010 fg gs 315 ute
Tuned by Monsta Torque
395.2 KW
610 NM
3.07 diff ratio (changed from original 3.73)
6 spot brembo's on the front
3 inch manta cat back exhaust with X piece
6 speed manual
k & n air filter
rear calipers painted red
debadged stripes etc removed
perthbfxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2017, 05:20 PM   #408
marcyeo
Regular member
marcyeo's Avatar
20170930_164445 by Gerald Yeo, on Flickr
20170930_164511 by Gerald Yeo, on Flickr
20170930_143634 by Gerald Yeo, on Flickr
TSW Nurburgrings in Matte gold. 20 x 8.5 +20 fronts and 20 x 10 +40 rear's.
Clear Brembo's with heaps of room!! Thanks Matt!
CURRENT
2013 335 GT - BMC twin filter, Herrod IC, injectors, fuel pump, oil breather, SC pulley and balancer, X-force 2 1/2" cat back with high flow cats = 453rwkw. Thanks to Lee at Real Dyno performance.
OLD
2010 FPV F6 FG - Herrod CAI, Pedders extreme XA's, Whiteline fr & rear swaybars, PWR stepped IC, injectors, turbo dump pipe with Venom cat, Herrod piping kit = 350rwkw
marcyeo is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2017, 12:29 AM   #409
JC
Miami Pilot
JC's Avatar
Inovit Force5 19 x 8.5, P35 offset will also clear brembos:
[CENTER]-----------------------------------------------------------------
FG GTE | 376rwkw / 504 rwhp | 1/4 mile 11.946 @ 118.71mph/191kmh 1.797 60'
The Daily: 2001 Mercedes C180 | 95 fwkw | home to work in ~ 23 mins! @ 70km/h average speed
Old 29-11-2017, 04:14 PM   #410
WyldOne
Hey all,
Just curious will these rims fit over rear Brembo’s. Thank you in advance
File Type: jpg 83709F49-5840-4FB0-91F0-06E783CC7C23.jpg (69.2 KB, 5 views)
WyldOne is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2017, 04:31 PM   #411
raised by monkeys
wish i was a jedi
raised by monkeys's Avatar
Vertini Hellfire F20x8.5 +30 R20x10 +40
Front will fit 6p not sure about rears, not much room between the caliper to the inside of the wheel. I did ask for these to be cut to suit front brake upgrade.
[IMG][/IMG]
cheers
Shaun
Current
2012 FG MkII G6E Turbo
Forged motor - built by Heinrichs Performance and Tuning
Previous
NEO BFII FPV TORNADO #0021
3.5" turbo back and 4" dump, IDI1000's, walbro intank, flash tune 351rwkw - Heinrich Performance and Tuning
Old 29-11-2017, 05:31 PM   #412
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by WyldOne View Post
Hey all,
Being 17" and the dish in them i doubt they will but the manufacture should be able to tell you once they know the model they are being fitted too.
MATTHEW PEARCE
Phone 02 9609 1101
Old 01-12-2017, 09:59 AM   #413
WyldOne
Thank you mate ☺️
What about 17” Simmons FR with the correct offset.
File Type: jpg 7DD6FC8C-36B9-4679-9906-5BD59BAE3EA6.jpg (84.3 KB, 6 views)
Old 01-12-2017, 11:00 AM   #414
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Thank you mate ☺️
Your best bet is to ask the Simmons supplier which wheels will fit factory FPV brakes as they should have that info. Dished wheels generally wont allow bigger brakes.
MATTHEW PEARCE
Phone 02 9609 1101
Old 02-12-2017, 12:23 AM   #415
HI PSI
I did a mod to my brakes, the rotor and caliper sit 10.4mm further inboard. Then purchased a set of BBS CH rims, that would have fit anyway...
Old 14-12-2017, 09:38 PM   #416
WyldOne
Anyone know if a +40 pos on the rear will clear Brembo’s? Thank you
Old 14-12-2017, 10:12 PM   #417
arronm
Silver F6
arronm's Avatar
Yes, but depends on spoke design.
Nizpro equipped and Tuned by the BEST in the west
Xtreme Ford Tuning
479RwKw Fuel limited, more pumps and power too come.
F6#0507. Pro racer and Tech expert
arronm is online now   Reply With Quote Multi-Quote with this Post
Old 14-12-2017, 10:38 PM   #418
WyldOne
I forgot to add Simmons FR
Old 14-12-2017, 10:54 PM   #419
arronm
Silver F6
arronm's Avatar
Call tempe tyres, they are simmons.
Xtreme Ford Tuning
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
