02-02-2023, 10:51 AM | #1 | ||
hi guys is it ok to post this here?
My car squeaks over those annoying speed bumps that are basically every 100 metres where i drive and deliver stuff. I want to remove the inside bushes and clean and re grease and put them back on. Whats the easiest way to do this, the nuts seem so tight I couldnt even budge them, would I jack both sides of front up first, because I can access without jacks, Im just not sure what pressure is on the sway bar when all two wheels are on the ground as opposed to them being lifted (or one lifted). Sorry if this is a really dumb quesition! |
02-02-2023, 01:55 PM | #2 | ||
Have you tried just lubricating with WD40 or similar?
jaydee351 4DV8 |
02-02-2023, 02:39 PM | #3 | ||
Where to next??
I'm wondering if that will do something to the rubber?
I heard boot polish was used to lubricate bushes 'back in the day'. Not sure if there was any truth behind it.
02-02-2023, 04:22 PM | #4 | |||
HSV - I just ate one!
Only lifting one side will put a twisting force on the sway bar and it will make it an unpleasant job to remove and nigh on impossible to refit
02-02-2023, 04:57 PM | #5 | ||
02-02-2023, 04:57 PM | #6 | ||
Do it at ride height. Get new bushes. Superpro is ok, if you use their grease, it won't need regreasing for 1-2 years.....possibly longer. If you use other greases, you might find that you need to regrease them every 6 months or so, depending how many puddles you run over.
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. |
02-02-2023, 05:00 PM | #7 | |||
And another dumb question! when I jack it up, where do you put the jack stand as the jack is in the reinforced section? |
02-02-2023, 05:01 PM | #8 | |||
02-02-2023, 05:14 PM | #9 | ||
Silicone grease is compatible with poly bushes and rubber bushes.
You can get silicon grease from bunnings in the plumbing section (tap repair kits for about $10) or a car store ($25 tube). The little packets of dielectric grease that they often sell for headlight sockets is also silicone grease. Probably score that for a few $ But there could be a million things causing that squeak from sway bar links, to control arms... good luck.
I love Holdens.... |
02-02-2023, 05:32 PM | #10 | ||
The sway bar should not move move inside the bushes. The rubber should "stick" to the rubber & the rubber does all of the flexing. Don't lubricate the bushes at all, they should be totally dry & tightened at ride height.
This is why poly bushes are always noisy, they don't flex. Dr Terry |
02-02-2023, 08:03 PM | #12 | ||
02-02-2023, 09:37 PM | #13 | ||
Former BTIKD
It takes time to think up inane posts.
03-02-2023, 10:59 AM | #14 | |||
Im wondering if the car has been fitted with Poly bushes & that's why its squeaking
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
