Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Castle Hill Exhaust & Performance Centre
Castle Hill Exhaust & Performance Centre Leading the way in specialist performance exhaust systems and tuning packages Website Link
Old 06-12-2010, 10:49 PM   #1
Dale@CHE
Default our FG XR6t gets a turbo upgrade
well the time came to put a real turbo on the FG to see what it would do, we had a nice T04z made up with a T3 flanged exhaust housing,.
the car usually runs up around 325rwkw on 21psi with the stock FG turbo.
so we ripped off the stock turbo and fitted the new T04z with a turbosmart external wastegate and made up a new intake pipe and 3.5in dump pipe, the results are a stock looking 380rwkw on 16psi boost
with a fuel system and a new clutch a nice 400rwkw will do
ill get some pics and dyno sheet up tomorrow
www.castlehillperformance.com.au
Dale@CHE is offline   Reply With Quote Multi-Quote with this Post
7 users like this post:
Old 08-12-2010, 02:05 AM   #2
CHLAXN
CHLAXN's Avatar
Nice work mate alot less boost now and making great power.. Does it boost up quick like the standard smaller turbo or a bit more laggy? Possible to put some pics up of the new turbo setup? Cheers
CHLAXN is offline   Reply With Quote Multi-Quote with this Post
6 users like this post:
Old 08-12-2010, 07:19 PM   #3
Dale@CHE
ill get some pics up tomorrow mate sorry been flat out,
its definatly not as responsive as the under sized FG turbo, but its not too bad at all
Old 09-12-2010, 01:26 PM   #4
Dale@CHE
here is a few pics, nice and stock looking
Old 10-12-2010, 11:42 PM   #5
CHLAXN
CHLAXN's Avatar
looks like the pics arent working at my end mate.
Old 12-12-2010, 09:40 PM   #6
Dale@CHE
should be working mate, definatly working for me
Old 12-12-2010, 11:09 PM   #7
mercules
mercules's Avatar
hey dale kev mate off s/f hows things im still working on trying to get back these props im ringing him twice a week so by looking at this do you own castle hill exhaust do you do a s/s system for a bf typhoon cheers kev
06 bf fpv f6 typhoon. octane orange. 19" argents. 6sp ZF. factory installed dvd. GT momo wheel. and footwell lights.
now with CES zorst 8lb actuator 60lb dekas K&N filter hpc exh manifold and hpc dump pipe currently 438.8rwhp
mercules is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2010, 08:53 PM   #8
Dale@CHE
Hey mate
yep can do a SS system no problems at all, shoot me a PM and ill get you a price tomorrow!!
if you can get those Props ASAP that would be tops! Grafton B2B is on end of Jan and need to put a big one on it for there!
Old 11-07-2011, 12:15 PM   #9
unclewal
Default Re: our FG XR6t gets a turbo upgrade
hey Dale, Can you share a few more details on this t04z setup, looking to do something similar (read:exactly the same) on my ute and would like to know the exhaust side AR and if you have any pictures of where you mounted the gate on the housing? Thanks !
unclewal is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2011, 08:57 PM   #10
Dale@CHE
the turbo is a custom one we had made to our specs, it uses a T3 flanged exhaust housing.
ill see if i have some more pics tomorrow
Old 01-08-2011, 09:08 PM   #11
FreddyDUZ747
FreddyDUZ747's Avatar
Excellent result for the boost pressure.
Im doing the exact oppisite atm and putting a smaller turbo on my BA.What psi actuator was used with 325rwkw?
thankyou.
FreddyDUZ747 is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2011, 10:53 PM   #12
Dale@CHE
stock actuator,
i dont know why you would go back to a smaller turbo tho, they take a lot more boost to make the same power...
Old 01-08-2011, 11:06 PM   #13
FreddyDUZ747
Smile Re: our FG XR6t gets a turbo upgrade
stock actuator,
Im over peak power Dale and want to have more power/torque sooner,320ish is enough for my 150,000km bottom end tbh.I was pushing it at @350.
Old 02-08-2011, 11:44 AM   #14
Dale@CHE
problem is your going to need 20+ psi to make 320 with the small turbo and it will be a time bomb...
Old 17-09-2015, 11:44 PM   #15
ChasingFg
Hey how's it going, wondering if you recommend doing a IWG upgrade, mods already going on is exhaust, cooler, fuel pump, injectors
ChasingFg is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2016, 11:11 AM   #16
simmosford
Originally Posted by Dale@CHE View Post
stock actuator,
hi do i need to fit a new acuator if im going to tune my fg xr6turbo ute. Its just had fitted a delete pipe a high flow cat with dump pipe and a cold air intake the rest is stock. Ive just brought a sct x3 flash tuner im going to tune the car
simmosford is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2016, 11:12 AM   #17
Dale@CHE
No you don't
Thread Tools
Display Modes
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
