Old 08-11-2017, 06:50 PM   #181
BlueBear
Shockwave
BlueBear's Avatar
Default Re: Definitive AU1 to AU2/AU3 brake upgrade thread
I believe they were a twin piston and an even larger disk than the BA, though I can't remember the actual size.
It should fit up, but you will need at least 17" wheels.
Cheers.
BlueBear is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2017, 06:59 PM   #182
auxlr8
Thanks for the info mate. For them it's like looking for a needle in a haystack full of ford calipers. Anyone perhaps have a serial no or caliper model no or exact disc size I can pass onto them to help look. Would they have tickford or premium printed on them? Painted? Would seriously turn a massive job into an hours job with the same result
auxlr8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2017, 07:10 PM   #183
BlueBear
Shockwave
BlueBear's Avatar
http://i745.photobucket.com/albums/x...47/fbrake2.jpg
Taken from this thread. https://fordforums.com.au/showthread.php?p=5328384
Also check here. https://fordforums.com.au/showthread...premium+brakes
Painted red.
It also saays they are 329mm disks.
Please note I have never come across these, so my info is not to be taken as gospel.
Hopefully others with experience will be able to help out.
I reckon though, that if these wrecker guys didn't remove the disks and calipers they would be long gone.
Cheers,
Old 08-11-2017, 07:22 PM   #184
auxlr8
Thanks heaps for the help. He thinks he has them laying around so fingers crossed. You guys are like the Wikipedia of au falcon!
Old 08-11-2017, 08:39 PM   #185
lotus
The factory rotor size for premium brakes is 329mm but aftermarket ones are listed as 330mm. They use C4 calipers (twin piston) and have a "TICKFORD" logo on them. The actual size of the C4's are smaller than the calipers used on BA's but not sure if the piston sizes are different or the same. The pads are bigger on the BA calipers.
I think there is a bracket that goes between the upright and caliper to allow the caliper to move out for the bigger rotor. They used a bracket for the C4 calipers that mounted at the front of the wheel on Ser 2 & 3 .
We salute those brave souls that enter the DARK side
lotus is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2017, 08:54 PM   #186
superroo
You can't stop the signal
superroo's Avatar
Yep premium brake uprights. Sought after but useless without the calipers.
Was C4 corvette calipers with the tickford symbol.
Discs were 329x25mm
Second best non brembo combination and is period correct
Old 09-11-2017, 08:11 AM   #187
auxlr8
Great news if the wreckers can still find them. I'll know more today but if not, finally got a set of the right parts now anyway
Thanks all
Old 09-11-2017, 01:46 PM   #188
auxlr8
So the guys at the wreckers remember taking the premium tickford calipers off and put them aside as originally I asked for ba calipers...They have been looking hard and come to the conclusion that the tickford calipers have been stolen as they didn't sell them and they are now gone.... That leaves me back to the original plan of the full series 3 conversion with 322mm carrier, discs and ba calipers...... unless.....anyone might know where I can get a set or tickford premium front calipers that face the rear as I've now got a spare pair of uprights that will fit them
Old 09-11-2017, 08:28 PM   #189
auxlr8
If anyone wants ford premium brake uprights off a series 3 xr6 with the calipers facing rear, your welcome to them.... FREE. Happy to post at cost or welcome to come pick them up
Old 20-07-2018, 01:57 PM   #190
macman
macman's Avatar
EDIT: Just seen this was yonks ago...
macman is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2018, 10:59 PM   #191
Xr302
Hey guys,
If anyone is still following this I need some help!
I have a au2 xr8 I have recently fitted front premium brakes off a ba xr6 turbo, they are 325mm x 32mm and apparently use a c4 caliper.
I obviously bought them second hand, when I fitted them, the pedal was terrible! It nearly has to be on the floor before the brakes work... The old 287s worked better but they were warped to the **** house...
Has anyone that has done a brake upgrade had this problem or know a fix for it?
Cheers 👍🏻
Xr302 is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2018, 04:30 PM   #192
Ken_AUXR8
Ken_AUXR8's Avatar
Hi All, just completed this upgrade almost successfully.
However, my brake lines are wayyy too short. These are the S1 original brake lines. I've changed to BA bits incl calipers but they look the same as the S2/3 calipers at the start of the thread.
Does it need the S2 lines? Wreckers cut them off...
K
AU S1 XR8 Auto Liquid Silver
Daily Drive: Focus ST Mk3, Mrs Ken: 2021 Puma
Previous: XD S-Pack, EB Fairmont Ghia, AUII SR, BFII XT, FG E-Gas, FGII G6 Ecoboost... among many other Falcons
Ken_AUXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2019, 03:40 PM   #193
Climaxxx
K
Attachment 99952
Late reply...yes you need Au2/3 Lines or BA front lines.
Climaxxx is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2019, 10:45 AM   #194
Peuty
Afterburner + skids =
Peuty's Avatar
Hey team - can anyone confirm that BA rear caliper bracket slide pins are the same as the AU ones?
I'm doing a cheap BA rear brake upgrade on the XR8 and one of the BA caliper brackets has a dodgy slide pin, so I was hoping to be able to use my existing AU pins. I could take the wheel off and disassemble to check, but I'm being lazy for now.
Oo\===/oO
Old 28-03-2019, 10:49 AM   #195
Climaxxx
Smile Re: Definitive AU1 to AU2/AU3 brake upgrade thread
That's a go for launch mate. They are the same.
Old 28-03-2019, 11:04 AM   #196
Peuty
Peuty's Avatar
Excellent news, thanks mate!
Oo\===/oO
Old 05-06-2019, 11:32 AM   #197
ebv8
ebv8's Avatar
i just put on AU2 brakes on my AU1 and I can confirm the stock master cylinder does a fantastic job with no issues with a longer pedal at all
my AU1 is a March '99 build and I read that in May '99 they all got the revised larger master cylinder to help with long spongy pedal feel when hot
how can i tell if mine has the larger master cylinder? its 100% and never been touched before
also i'm going to fit a full set of PBR upgrade brakes once i get my 17in wheels refurbished as they don't fit under my 15's currently
the fronts i know will just bolt on but how about the rears? will the caliper bolt onto the live axle rear of my AU1? if so is it just spacers i need? and what size? they are 328mm x 26mm wide where as the AU1 is 287 and 10.5mm wide
or should i sell the upgrade rear calipers and just fit BA-FG rears with 303mm x 16mm rotors and forget the vented rear calipers, the AU is alot lighter than any BA-FG anyway
CURRENT RIDES
BA GT Mk1 #0009 - Narooma Blue
SY Ghia AWD
Black VZ LX8 Adventra
Holden HX 50th Anniversary
AU Saloon Car racecar
1980 GS1000ST - Wes Cooley Rep
ebv8 is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2019, 03:03 PM   #198
xeeclipse
The only problem I see in all this is that the ABS module is calibrated to the smaller volume calipers which will effectively cause a delay in the operation and possibly a long pedal.
I know that the wiring harness changed from model to model so you probably can't even adapt a series 2/3 ABS unit to a 1.
xeeclipse is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2019, 04:17 PM   #199
FOMOCOAU
I have done a s1 to s2 front swap on my sept 99 xr8 previously..now wanting to upgrade to ba rotors and calipers. is there anything else required for this swap? tia.
FOMOCOAU is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2019, 04:22 PM   #200
ebv8
ebv8's Avatar
BA are only 11mm extra dia (287 to 298) so its just calipers and rotor
for $140 you can get new caliper brackets and run 322mm rotors with BA calipers, if you need to buy rotors anyway the extra $140 is probably worth it
CURRENT RIDES
SY Ghia AWD
Old 06-06-2019, 04:54 PM   #201
FOMOCOAU
I might do that..is the upgrade to ba calipers straight forward? Nothing else need changing or spacers added?
Old 06-06-2019, 04:57 PM   #202
ebv8
ebv8's Avatar
just need calipers and rotors, pretty sure the brake lines are the same (same parts on ebay anyway)
CURRENT RIDES
SY Ghia AWD
Old 06-06-2019, 05:36 PM   #203
PG2
#neuteredlyfe
PG2's Avatar
I've done the BF turbo upgrade on my XR8 - 322mm on the front and 303mm on the rear.
You can use your old rear calipers for the rear but will need some brackets off a B-series for the calipers. They swapped straight over though you will need a spacer (a suitable size washer will do) to centre them over the rotor.
For the front, when I fitted my 322mm calipers the brakes lines were at their absolute limit in terms of being long enough. I have since changed the lines over to braided.
PG2 is online now   Reply With Quote Multi-Quote with this Post
Old 07-06-2019, 09:18 AM   #204
Peuty
Peuty's Avatar
Spot on.
And to confirm, it's a 3mm spacer that is needed.
Oo\===/oO
Old 07-06-2019, 09:28 AM   #205
ebv8
ebv8's Avatar
Any tips on mounting the vented rear pbr upgrade brakes on the back of an AU? Id assume its just the caliper thats dufferent and the same 3mm spacers to be used
CURRENT RIDES
SY Ghia AWD
Old 07-06-2019, 09:31 AM   #206
Peuty
Peuty's Avatar
Sorry mate, i only have experience with the solid rear, but from what i have read, the 3mm is a consistent measurement across the board.
Uncle_Ken may be able to elaborate? He has done the Terry upgrade (I think)
Oo\===/oO
Old 07-06-2019, 08:21 PM   #207
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Yeap thanks what I used for my Rear Terry brakes on my XR8
3mm
UK
Old 26-07-2019, 12:34 AM   #208
NCII40
XR6T BA 2002
NCII40's Avatar
what brake upgrade can i do that will fit inside my LTD 16's for AU2
XR6T 2002 BA
Old 26-07-2019, 09:09 AM   #209
ebv8
ebv8's Avatar
I have an update based on my AU S1 Futura
first i fitted AU2 twin piston calipers with 287mm rotors and they fit under 15in alloy wheels easy, plenty of room, not sure about steel wheels as they have a lip where the spot welds are so may rub, or may not rub
some notes about the swap
it all just bolts on but to get the lower arms in, the front sumframe needs to be dropped, plenty of penetration fluid and a rattle gun helps those studs get dirty and they are long, i left the nut on and use a lever to drop the subframe 1 side at a time.
i also only bolted the sway bar bracket on the outer side using the factory threaded holes and i am using my AU1 master cylinder and have noticed no travel difference in the pedal and brakes work awesome compared to the S1 brakes.
I may have issues when i fit the BA calipers but a new late '99 AU ute master cyl should fix that
second i fitted BA twin piston calipers and 298mm rotors and the 15in alloy futura wheel will bolt up but it scraps in the outer edge of the caliper and mounting bracket, i'd say a pretty easy task to trim but i'm not going to bother as i now have a set of FG turbo 322mm brakes and 17in wheels to go on the old girl as 16in steelies won't fit over 322mm brakes
also if you want to know the different between AU, BA and BF/FG Turbo brakes
here is a set of images
note the turbo caliper bracket sits about 15mm off the rotor hub (has a clear gap) where the BA caliper bracket is only about 5mm off the rotor just like the AU, also the turbo caliper bracket has tear drops where the bolts hole are
AU
BA
FG Turbo
CURRENT RIDES
SY Ghia AWD
Old 26-07-2019, 09:12 AM   #210
ebv8
ebv8's Avatar
stock BA brakes will fit under 16's, calipers are about $90 a set from a wrecker or ebay, any cheap 298mm rotor will work ok, another $90 a set there and pads like bendix HD another $90 a set
not sure there would be a huge difference between 287 and 298mm rotors though
CURRENT RIDES
SY Ghia AWD
