Old 22-10-2017, 12:13 AM   #1
nimda
Default Escort Mk2 struggling to stay at idle - any help appreciated
Hey guys... anyone good with troubleshooting old Eskies? I have a Mk2 Escort with a 2.0L Pinto motor with a Weber DGV that was running - albeit not super well - about six months ago. While on the road the gearshift lever snapped off and it sat for a few months until I got another one ordered. Installed the new gear lever and I find that the car won't start and idle for more than ~1 second and it would not start with the choke set to anything but fully closed. Throttle position changed nothing.
Thinking that the carbs were the culprit I pulled them, ultrasonically cleaned everything, cleaned with carb cleaner, blew them out with high pressure air and put in a rebuild kit covering O-rings, gaskets, internal filter, valve seat and needle. Fuel filter renewed at the same time. The carbs weren't particularly clean inside and the internal filter was very clogged.
Brass floats were tested, no leaks there. Float height set as per manual.
New carbs on annnnnd... same problem. It'll run fine on starter fluid but it will only start on closed choke and will only run for ~1 second at a time. Mixture screw or idle speed screw being altered change nothing.
Thinking the fuel filter may be part of the problem I renewed the fuel lines and temporarily eliminated the filter, no change.
The engine will run on starter fluid for as long as you care to spray it in the intake for, so I suspect that timing is not the culprit.
I pulled the top of the carbs off and noted that the fuel level in the carb bowl was barely sufficient to cover the jets. The float appeared to be able to move up and down freely. I added 30ml of fuel to the bowl, closed it all back up again and the car started and ran for about 15 seconds before dying. Upon re-starting it would only run for ~1 second.
Since the float appeared to move freely, this leads me to suspect that the fuel pump isn't filling the bowl sufficiently rapidly. When you pull the fuel line off the mechanical fuel pump and crank the motor, should the fuel be coming out at a drip.. drip.. drip.. rate or faster than that? All I get are steady drips, nothing like what you'd call a flow. I know it's a low-pressure pump but have no real idea of just what should be coming out.
Any other thoughts are MOST welcome. I would really like this car back on the road so I can get a blue slip and get it out of the yard...
nimda is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2017, 06:29 AM   #2
raceteam
Default Re: Escort Mk2 struggling to stay at idle - any help appreciated
Those mechanical pumps normally give a visible burst of fuel for each revolution, not just drips. Sometimes the valves in them can jam open/closed if they have sat for a while. If you can suck some fresh fuel through it, sometimes that can clear it.
raceteam is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2017, 11:02 AM   #3
nimda
Thanks for the reply. I pulled the input line and fuel floods out that quite freely (car facing slightly downhill) so it looks as though it's getting a good flow in. I'll try to get some fresh fuel through it and see if that helps.
Old 22-10-2017, 06:28 PM   #4
Engine Guy
get someone to crank the engine with the fuel line in a jar or a can, to make sure the pump is definateley pumping fuel...
you might have an issue with the fuel needle valve or the brass floats might be a bit bent and not allowing fuel to enter the float chamber.
Can easily happen during the carb stripdown / cleaning/ rebuild
Once you have fuel entering the float chamber, it should idle
Engine Guy is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2017, 06:58 PM   #5
nimda
The fuel pump is only outputting drips - not a constant stream, or even a pulsing stream - I pulled the top of the carb again today and the fuel level was only at the level of the jets. I filled the bowl with fuel, reassembled the carbs and had no issues at all starting with no choke and idling or revving up until the bowls drained again, where it will only start for a second on full choke before dying.
I pulled the fuel filler cap and tested the fuel pump again and it put out slightly faster drips but still not much of a flow. I'm going to order a new pump and a new filler cap as that one is pretty crusty and I think not venting well and see how we go.
I did have another look at the floats and they looked straight enough and the movement was free and straight as far as I can measure, though I'm open to suggestions of how I could measure the movement of the floats once it's actually installed. Fingers crossed that I'm correct there and that the fuel pump is the culprit.
Old 22-10-2017, 10:14 PM   #6
Engine Guy
Ok, It looks like a fuel pump problem, fit a new one.
To measure the floats you'll need a vernier, to measure the maximum width of the float assembly, then compare that 'width' to the inside measurement of the float chamber.
I recall seeing a few carbs that had 'bent' floats that actually touched the side of the chamber, causing fuel level problems...
Old 23-10-2017, 12:08 PM   #7
nimda
Resolved - new fuel pump installed and she fires up beautifully. Thanks guys.
