Old 25-07-2021, 02:53 PM   #241
mad2
Regular...with metamusal
Default Re: Definitive AU1 to AU2/AU3 brake upgrade thread
Originally Posted by lumen8 View Post
Genuine 322 fronts getting more difficult to find, there are the aftermarket brackets on ebay
https://www.ebay.com.au/itm/263136426361
https://www.ebay.com.au/itm/283709614621
Then can use any BA caliper, swap the brackets with the new ones, it is the brackets that are different on the 322, rest of caliper is same as the regular BA.
awesome! .... bought those brackets ages ago, but thought i might have to change uprights. it's for a BA. also bought the bigger brakes for the wog mobile [has same brackets] . . . . .
Originally Posted by Ben View Post
Something like https://www.ebay.com.au/itm/254801652084
Those mounting brackets, correct rotors/pads and new lines would work?
not sure on that one .. but yes two piston
Old 25-07-2021, 07:09 PM   #242
lumen8
lumen8's Avatar
Yes, those reco'd calipers, add the aftermarket brackets, some BA lines, the 322 rotors and you're set.
Pads are the same whether its 298 or 322.
Even the AU2 front lines can work if you have an AU2, ive made them work but cant remember exactly what I did, I think I mightve milled some off the side of the block where it bolts to the caliper to get the orientation right.
BA lines/hoses will go straight on though and dont need mods... but they do have a little mounting bracket that slips under the caliper mounting bolt head... you will need those with BA lines.
BA lines clip into that bracket whereas AU2's clip onto the strut/shock assembly.
Here is a pair of BA calipers on ebay, the 4th pic shows the little brackets with the open ended C shape, they live under the mounting bolts.
https://www.ebay.com.au/itm/284378854532
https://i.ebayimg.com/images/g/y3QAA...hS/s-l1600.jpg
lumen8 is online now   Reply With Quote Multi-Quote with this Post
Old Yesterday, 10:42 AM   #243
Peuty
Afterburner + skids =
Peuty's Avatar
Thanks mate will go with arp washers for sure.
Just got ordered a set of refurbed terry 328mm rears.
Think I will contact race brakes sydney to see if they can make up some new lines for the rear.
Fronts seem to be elusive as of right now I did see RBS sell a 325mm front kit same as on the ba gt.
Keep us posted on how you go with the lines. I will be getting RBS to make a set up for me too, so it would be great if you could share the measurements used.
AUII XR8 220 - Manual + V8 = skid time
Oo\===/oO
Old Today, 01:18 PM   #244
Ben
Ben's Avatar
With the rotors am i just looking for the terry 328 style rotors or do i need something different to suit the handbrake setup or do they run they same. And assume any falcon 322 rotor from that period will suit fronts?
Ben
2001 AU2 220 XR8 - Build thread
Ben is online now   Reply With Quote Multi-Quote with this Post
Old Today, 03:23 PM   #245
Peuty
Peuty's Avatar
They are the same mate. And yes, any Falcon rotor will fit.
Oo\===/oO
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
