Old 16-11-2006, 08:12 PM   #1
napoleon
20 years of driving....
Default Location of engine number
Hi Guys,
I am looking for the location of the engine number on a series 1 Falcon 6cyl. Had a look under the bonnet and searched the Forums but can't seem to find any info.
napoleon is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2006, 09:53 PM   #2
EvilChief
Boost Addict
engine number doubles in with the vin number on the plate
u can also find it located on the front of the engine inbetween the belts
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2006, 10:23 PM   #3
napoleon
I saw some numbers and letters between the belt but they look like Part numbers as they start with WR2A...
Old 16-11-2006, 10:25 PM   #4
bodes-sh
yes they are part numbers, the engine number is the part of the vin after the 6FPAAA bit, ie JG...whatever the next bit is
bodes-sh is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2006, 10:33 PM   #5
napoleon
Thanks, but already knew that about the vin number. I need to register the car and was looking to see if the engine has been changed at all.
Would I be looking for the JG.....on the engine as well?
Old 16-11-2006, 10:35 PM   #6
bodes-sh
id say so, it's probably on the block near the back of the motor knowing what ford is like...wherever it is, it will be stamped on the block
Old 16-11-2006, 11:52 PM   #7
Syncro
The engine number is on the block behind the exhaust manifold where transmission bolts on. Its very hard to read because it is printed in dots on a rough cast area, best to clean area and apply baby powder to highlight.
Syncro is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2006, 12:44 AM   #8
EvilChief
Boost Addict
the engine number is part of the vin number ...
N12 Pulsar - sold
Old 17-11-2006, 06:46 AM   #9
jones_aus
jones_aus's Avatar
you should probably read what your quoting :P
jones_aus is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2006, 08:46 AM   #10
Mechan1k
Mechan1k's Avatar
From what I have been told the engine number is near the rear of the engine under the the intake manifold ... but don't quote me on that though.
Mechanic wrote it down for me before the new engine went in the ute ... hee hee
Now I can get my blue slip for the engine change so I can take it to the RTA to get changed ... hmmm .... must get that done very soon.
Old 17-11-2006, 07:19 PM   #11
Mechan1k
Mechan1k's Avatar
OK ... Tibbo mentioned it in another thread ... it's on a flat section at the rear of the engine on the exhaust side behind the manifold (not the intake manifold side where I thought it was).
Old 11-05-2014, 08:52 PM   #12
Stocky_j
Default Re: Location of engine number
I managed to find it - very hard to find Dots on rough surface. Right side (Drivers Side) of Motor near bellhousing. You had to shine a lamp at an angle to see the full number in was last 11 letters and numbers of Vin.
Stocky_j is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2018, 02:56 PM   #13
MattstaF6
Hi Guys
I know this is a really old thread. Was just wondering if anything had to be taken off to see the number, like the turbo heat shield?
MattstaF6 is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2018, 01:16 PM   #14
uterass
Hi all, i have been searching for days for a clear answer to where the engine number is on a ford explorer 2002 v8, i need it for police inspection but can not find it.
Thankyou in advance
uterass is offline   Reply With Quote Multi-Quote with this Post
