Old 13-05-2021, 05:08 PM   #1
Reno
Default Cortina TF Ghia 1981
Ever had problems with the A/C Vacuum Distributor Valve (behind the dash).
Mine functions perfectly when motor cold but after driving 10 klms it then directs 50% of the air flow to the windscreen (something within the valve changes).
Can not get a replacement from Fords or EBay.
So if you experienced same problem what did you do ?
Reno is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2021, 05:46 PM   #2
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
Default Re: Cortina TF Ghia 1981
Is it a 2 litre or a six?
Ford air cons from that time shared a few parts between models, you maybe able to expand the search to Escort and Falcon. Got a part number?
Mk1 GT Cortina Project.
FG XR50 Daily.
Old 17-05-2021, 10:33 AM   #3
Reno
Default Re: Cortina TF Ghia 1981 4.1 Xflow 6 cyl
Thank you for your response will enquire from Fords if the Cortina part number which is Basic Part Number 19B919 and Aust Part Num YH24 are the same for Escorts and Falcons.
Should have mentioned that this is a 6 cyl xflow
Old 05-06-2021, 12:14 PM   #4
vdo
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Consistently offers competent electrical and technical advice regarding Ford electrics, especially instrument clusters. He's retired but offers his services for repairs for next to nothing.
Air to the windscreen is the default flow when there's not enough initial vacuum. It might be something as simple as a a split vacuum line in the engine bay getting warmed up and leaking worse when soft and warm.
vdo is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2021, 07:06 PM   #5
Reno
Thank you VDO never considered the aspect of leakage I am in Brisbane also
Do you do vacuum analysis ?
Rgds
Reno
Old 04-07-2021, 10:03 AM   #6
vdo
Rgds
Reno
I don't do analysis. I'm an Instrument and electronics tech.
I know about dash operations functions etc.
The leak will be most likely in the engine bay where the main vacuum feed is, or sometimes the vacuum control switch in the dash could be the culprit.
Listen for hiss sound, (with engine running).
Old 21-07-2021, 07:58 PM   #7
Reno
Your advice is appreciated
Thanks
Old 21-07-2021, 08:47 PM   #8
Crazy Dazz
Is it related only to engine temperature?
Does it change with throttle-position?
My XF used to shift to the floor vents when I put my foot down.
If it is only temp related, then the most likely culprit is the notorious Emissions control valve.
Mounted near the thermostat, is a 3-pronged (temperature-controlled) vacuum-valve. IIRC the originals were a reddy-brown colour. When the car gets up to operating temp, the valve opens and redirects the vacuum. (I think it may go to the EGR valve?)
Any way, they are notorious for getting brittle and snapping, opening up the vacuum to the atmosphere.
If that control-valve is intact and working, it could be the EGR valve itself that's stuffed and leaking.
