06-08-2018, 01:47 PM | #61 | |||
IT Drone from Sector 7G
It looks like someone putting a drone on the ground...you can see it left behind when they stand up. ...although happy to admit maybe that's what I want it to be (could also be a very small obedient dog) |
06-08-2018, 02:21 PM | #62 | ||
I am Groot
Can see them getting banned in Venezuela lol....
https://www.bbc.com/news/world-latin-america-45077057 https://www.google.com.au/search?q=d...hrome&ie=UTF-8
.. McLaren F1 Dick Johnson Racing "Those were the days when the cars were cars, they weren't built out of an Ikea pack like they are now and clothed in plastic; they were real cars." John Bowe |
06-08-2018, 03:00 PM | #63 | ||
Watched it again and you might be right, at first it looks like someone scrambling for safety, but it looks like they placed something on the ground.
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's In Storage : '74 XB GS 351 Fairmont Sedan XB Falcon Owners Group Mike's Man Cave |
08-08-2018, 11:44 PM | #64 | ||
Received and installed the M9 and M9R gimbals today.
I didn't actually think they'd make much difference but they do...and I haven't worked out why yet. I've been whizzing around the various tracks on FPVFreerider and found even on the easiest track it was hard to be stable enough close to the ground to make it through the gates...and the gates are huge. Using the easy 'The Meadow' track I was lucky to make it around once, even on lower rates and auto-levelling. I just made it round five and a half times until I hit a gate |
08-08-2018, 11:57 PM | #65 | ||||
Looking for clues...
So, is that stability control, to remove human error at the input?
Swanny’s Fundraiser for the 2024 MS Brissie to the Bay 100km Bike Ride 2016 Ford Falcon FG/X XR6 Turbo you beaut ute 1985 XR4Ti Sierra - Build Thread 1971 Fairlane 500 and... a collection of Jeep Towpigs and... two collections of rust and some new plastic bits roughly shaped like an F-Truck and.... some spare metal bits with holes in them |
09-08-2018, 12:23 AM | #66 | |||
In the 'olden days' the gimbals/gymbals would have two potentiometers connected via a linkage to each control stick to give a X and Y axis and they would have been purely mechanical devices prone to wearing out as the tracks inside the pots wore away over time due to the constant movement of the wiper arm. The original gimbal (I'll use the spelling the manufacturer uses) may have been a resistance device, I can't actually tell without pulling the thing apart...and I don't want to as they're now 'spares' They're mostly plastic and quite complicated and give 30 degrees of movement in each direction from centre (so 60 degrees in total). They're spring-loaded to return to centre but in the case of the throttle (on the left on my transmitter as I fly Mode 2) the spring is disabled/removed and the 'zero' position in now bottom middle. You can also engage a micro-ratchet on the throttle for 'feel'. The ones I have just put in are Hall Effect sensor devices so not mechanical...to a degree. The pivots have ball-bearing races instead of a greased metal sleeve, plus they're made of aluminium and not plastic so 'feel' better. The throttle (on the M9R) is now 45 degree throw instead of 60 degrees. This gives better throttle response, as you go from nothing to full power in less movement...this may be what is making it 'easier' for me to fly. FWIW Mode 2 is meant to be easier for helicopters, apparently it's not that common in Australia. Mode 2: Left Stick is: Throttle (which controls up/down in a drone) Yaw (horizontal spin around a vertical axis) Right stick is: Pitch (tilt forward and back) Roll (tilt side to side) ...slightly different to a fixed wing aircraft: Throttle is still throttle but controls forward movement. Yaw would be rudder Pitch would be elevator Roll would be ailerons That still makes sense in my head so would probably leave it The gimbals in my Taranis Transmitter can be either so the radio is interchangeable Mode 1/Mode 2. Last edited by Ratmick; 09-08-2018 at 12:37 AM. Reason: Added Stuff |
09-08-2018, 05:16 PM | #67 | |||
I am Batman
The M9r has a shorter throw which means you have less movement for the same amount of resolution. It allows you to reach full deflection with minimal finger movement. The gimbals themselves are alot smoother which also helps with accuracy. Up until Frsky came out with the M9 hall effect gimbals the go to set were the Aurora gimbals. Still very mechanical but the components were better made which translated to a better quality gimbal and feel. The issue with the Aurora's was availability. You could only get them maybe once or twice a year. I have a Taranis here with them in but never used them as the M9's came out before I received them ( took 8 months to get mine!) one day I may use that radio and fly them but I just prefer the M9r and M9's!
Rebuilt Boss260 with #Kellogs 1500hp forged and balanced crank#Manley forged flattop pistons with a 9.5/1cr#4340 forged h-beam rods with arp bolts#Clevit performance rod and main bearings#full ARP headstud kit#total seal rings#Mantic twin plate development clutch and lightened flywheel#Mellings uprated oil pump#Mainforce Performance Supercharger kit#AU motorsport 345mm big brake kit. Now sat on an engine stand going nowhere
09-08-2018, 05:24 PM | #68 | ||
Thumber I think you'd call me...the ends of the sticks are sharp.
09-08-2018, 05:33 PM | #69 | ||
I am Batman
yep. Alot of people put umbrella stick ends on. Im Hybrid, so I have my thumb on top but still part pinch and have really short stick length. Thats why the M9r was such a massive improvement for me as I struggled to reach full deflection before I got that.
10-08-2018, 05:05 PM | #70 | ||
I think yanks call gimbals what the rest of the world calls a gyro(scope)
www.bseries.com.au/mercurybullet 2016 Falcon XR8. Powered by the legend that is - David Winter. XC Cobra #181. 1985 Mack Superliner, CAT 3408, 24 speed Allison. |
10-08-2018, 10:07 PM | #71 | ||
I am Batman
My new frame is on its way so started to prep the flight controller and the escs.
I like to build from the center out so all these wires will be cut to size once I mount them.
3 users like this post: |
13-08-2018, 05:05 PM | #72 | ||
Would this sort of stuff be any good if someone wanted to start flying the faster models?? ie not off the shelf DJI stuff.
https://www.ebay.com.au/itm/Eachine-...53.m1438.l2649 https://www.ebay.com.au/itm/FLY-EGG-...53.m1438.l2649
13-08-2018, 08:28 PM | #73 | |||
I am Batman
If you really want to give this a go I would recommend getting a decent FRsky transmitter like the the QX7 , an r-xsr receiver and something like this If you want I would be happy to build something for you but I would recommend getting semi decent components and gear so that if the hobby isnt for you, then you will make most of your money back on resale. You will also need goggles to fly fpv.
15-08-2018, 10:24 PM | #74 | ||
In terms of racing drones what is the way to go, I like flying the buggers (drone/quad copters), I have gone through three so far, now thinking about getting a small racing drone. like a 4" one or similar, buying a controller and some FPV goggles.
I want a controller that will last me, money is not a consideration, but VALUE FOR MONEY is. I am thinking about buying a decent value for money controller that I will be able to use with future drones. Then I am looking for a good 4" or mini quad to get started, but do not really want too build one, I have more than enough projects to take up my spare time. On another note I am going to Kew on the mid north coast tomorrow, so I am thinking of doing another drone video with the little DJI Spark, keep an eye out on this space....
15-08-2018, 10:28 PM | #75 | |||
The Terrain Tamer
Current Ride : A Ford owned D3... |
15-08-2018, 11:58 PM | #76 | ||
Not far for me
Funny thing is I still have one of the old FarKew jumpers that I bought when the Pacific Highway used to go through Kew, and when the Kew servo was a must stop for a pie and coke, I remember riding my Harley from Sydney to the Gold Coast and buying the Jumper as I was cold........it's changed a lot these days....might upload a new video tomorrow if I get the time....
16-08-2018, 10:22 AM | #77 | |||
I am Batman
I started on 4inch frames but moved to 5inch as my skill level improved and I found the 4inch props and motors a limiting factor. Most people either run a 5inch or 3 inch these days. Depending what you want to do these are great little 3inch quads Just add your receiver and a 1000mah 4s battery and off you go. for 5inch I highly recommend the tbs oblivion . bang for buck, these are great and take a bashing. 1300mah 4s batteries and you have a durable beginner quad. A lot of the guys I fly with use these as carpark bashers.
16-08-2018, 10:49 AM | #78 | |||
The Terrain Tamer
16-08-2018, 09:22 PM | #79 | ||||
I like the idea of flying them, but have no interest in building them. I have more than enough projects without adding building drones.
16-08-2018, 09:24 PM | #80 | ||
The Terrain Tamer
I haven't been through Kew since the bypass opened...
16-08-2018, 09:31 PM | #81 | |||
Building one will give you a huge advantage when it comes to fixing them. You need to know how to solder as well
Had EB XR8 AU XR8 220 (awsome car ) AU Fairmont BA MK2 XR6 Turbo Now XDUB |
16-08-2018, 10:14 PM | #82 | ||
I know how to solder, but I really do not have the time, I already have too may hobbies, may be once I retire I can take up building drones.
19-08-2018, 10:55 PM | #83 | ||
My next drone is going to be a lot bigger, 5" drones suck as far as trying to fit everything in the frame...
...well the Armattan Chameleon does anyway. I've dropped one board (I used to have separate PDB and FC) and introduced a hybrid FPV/HD recording camera but it's very very tight. It's actually doing my head in... Looks like this now: ...before anyone says anything, I haven't mounted the top deck yet. That is last after I have made sure everything works, is secure and is unlikely to fall or break off. |
22-08-2018, 07:04 PM | #84 | ||
I am Batman
And my 6s build is complete. Just waiting on my batteries to arrive now~
22-08-2018, 09:12 PM | #86 | ||
Looks like a compact build...
23-08-2018, 03:43 PM | #87 | ||
I am Batman
My team sponsor Team Design FS277 in 5inch flavour.
The only frame I have zero complaints about and is an absolute tank
24-08-2018, 03:10 PM | #88 | |||
I have emailed my local Shire council about where I can/can't fly within the conditions of CASA's and droneflyer's regulations. Apart from disallowing flights at Hanging Rock without a permit and two week's notice there is nothing and they are not answering (so far) direct questions that need specific answers. I can understand the Hanging Rock scenario, the place is crawling in people climbing and visiting the place (would make a more interesting photography site for the OP though), but even though the entire facility is never all used at once sometimes it comes close (obviously those weekends would not be suitable). However in Woodend there is an old horse-racing track and its surrounds which are all public space. Given the population of Woodend is about 4,000 people you'd think I'd be able to get away with being able to fly at the back end of the racecourse reserve...no people, no property but a lot of open flat space and trees to fly around. The issue drones have is that people think they're little spying devices that are used by perverts to look through your bedroom curtains. Plus you get the odd knob that does something stupid like fly his drone to Bunnings for a sausage on a Sunday... ...so I can sort-of understand the Shire's reluctance to give me an answer. Doesn't mean I have to like it though. Push comes to shove I live on an acre in the middle of larger acreages, I don't have neighbours for hundreds of metres in each direction. My nearest neighbour gave me permission to fly my AR.Drone over part of her land...alas she moves out tomorrow and I haven't met the new owners yet. |
25-08-2018, 02:06 AM | #89 | ||
I am Batman
The Hornet comes in 7" flavour as well. ;)
Honestly.... Be sensible and just go out and fly. Never had a bad experience with the general public and most people are actually curious what you have. Usually give them a quick rundown on the hardware and they find it fascinating.
26-08-2018, 06:10 PM | #90 | |||
Apparently people buy them for the purpose of spying on people and to watch children in parks
