Old 15-03-2008, 06:48 PM   #1
NinaGeelong
Default Australian Ford Laser Engine?
Hi all...
This post is directed towards the fellow aussies in the group.
The engine in my 1986 bubble back ford lazer seized in hot weather last week after a heater hose burst. I now have an oportunity to buy a engine from a wrecked 1985 bubble back ford lazer. My question is, are the engines interchangable between 1985 and 1986 model ford lazers?
Any help you can give will be much apreciated.
Regards Nina in Geelong
Last edited by NinaGeelong; 15-03-2008 at 06:53 PM. Reason: spelling mistake and wrong year
NinaGeelong is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2008, 07:21 PM   #2
fmc351
let it burn
Originally Posted by NinaGeelong
Hi all...
There are B6 (1.6), B3 (1.3), and B5 (1.5 which arent common) engines.
Then theres EFI or carbie.
Im assuming neither are TX3 or 4WD as some of these had B6T (1.6 turbo) and I think even BPT (1.8 turbo, although I think these were only in later models) engines.
If the two you have are the same, then yes its an easy swap as Im fairly certain all bubble backs were unleaded, 85 was the change over year.
Old 04-04-2008, 12:03 PM   #3
VippiN
What a performer!
VippiN's Avatar
The BPT came out in the the turbo TX3s from 1990 onwards but do fit the hatch with mods.
Be easiest just to go B6>B6 if it's just a runabout.
1981 Ford Laser KA :: E5 :: 2002-2003
1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW
1990 Ford Laser KF TX3 :: BP :: 2010-2011
1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW
2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW
1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020
2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-*
1998 Ford Falcon AU XR6 :: HP Intech :: 2021-*
VippiN is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2008, 06:04 PM   #4
fmc351
let it burn
Apart from the obvious wiring, tank and pump differences between B6 efi and carb in the body shells, are the engines themselves interchangeable?
Can you just shove the efi gear on a carb motor and run it, or is there crank differences/cam etc?
Old 01-05-2008, 06:21 AM   #5
dumb blonde
dumb blonde's Avatar
fmc351 wrote:
"There are B6 (1.6), B3 (1.3), and B5 (1.5 which arent common) engines."
Where do I find the info on whether it's a B3 or B6? On the compliance plate all it has under 'engine' is a 'B'
dumb blonde is offline   Reply With Quote Multi-Quote with this Post
