24-03-2018, 01:47 PM | #1 | ||
Hey guys I'm having a problem with my reverse gear ,,if I park it on a steep driveway it doesn't have enough power at normal revs to back it up ...an if I stomp a bit to hard on the pedal it sounds like it's either breaking traction or the reverse gear is slipping ...any idea what is going on with it,,that the diff would do this only in reverse..
The car is auto..
[B]WTB (Syd)...AU 5.0 or xr8 4 speed auto transmission in good working cond /B] |
24-03-2018, 01:51 PM | #2 | ||
Au Falcon = Mr Reliable
Dont Fairmonts have traction control, i think they do?
cheers, Maka
24-03-2018, 02:13 PM | #3 | ||
sounds like the bands are slipping id have the trans serviced and adjusted
XC GS OLD SCHOOL MUSCLE Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
24-03-2018, 11:36 PM | #5 | ||
Ok thanks for the info , is the tranny dipstick under the bonnet?
Traction control maybe turned off, there's plenty of slip in the back tyres if u get my drift..
25-03-2018, 12:40 AM | #6 | ||
If theres some serious kays on the box, maybe do a service & check the filter for clutch plate debris.
Check the fluid level for now & if its good & your sure there was slippage, i would do the above then go from there, good luck! cheers, Maka
25-03-2018, 08:03 AM | #7 | ||
No dipstick.
https://fordforums.com.au/vbportal/v...?articleid=556 It's on a Territory, but same trans, so you get the idea. |
26-03-2018, 10:29 PM | #8 | ||
So to check the level of ATF in the tranny to be sure it has enough ,
how do I check the level an then how do I top it up????
27-03-2018, 04:41 PM | #9 | ||
The link I already put in tells you how, and has photos.
27-03-2018, 04:57 PM | #10 | ||
The Terrain Tamer
As per the link, but a bit more info.
You can't check it. The only thing you can do is pump more fluid into the tranny until it starts to come out of the hole you are filling it from.
Current Ride : A Ford owned D3... |
27-03-2018, 05:26 PM | #11 | ||
When the filler bolt is undone (after you've jacked the car up level), the fluid should be level with the bottom of the filler bolt thread. Plenty of old threads describing as such, good luck!
cheers, Maka
27-03-2018, 06:39 PM | #12 | ||
Use a single hex socket , 9 times out of 10 this bolt is extremely tight and probably already half rounded from the last attempt , its a PITA
