Old 18-03-2018, 08:24 PM   #1
cougarsxr8
Au2 tick ford xr8
Default Fuel filling is slow an keeps shutting pump of
Hi I have tick ford xr8 200kw 2001 au ...when I go to fuel up I have to trickle the fuel into the tank so it doesn't keep stoping the pump,have check charcoal canister an solenoid an all seem OK
cougarsxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2018, 09:30 PM   #2
T3rminator
T3rminator's Avatar
Default Re: Fuel filling is slow an keeps shutting pump of
Are you new to Fords? They pretty much all do that if you put it straight in.
Turn the handle on a 45ish degree angle and you'll be right.
Old 18-03-2018, 10:08 PM   #3
TICKFORD220
2009 Fg xr6 turbo
My 2002 au xr8 does it too,only ford ive owned that has done it,it either clicks off constantly or doesn't click at all and ****es fuel everywhere when its full... turning the nozzle does nothing.
TICKFORD220 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2018, 10:30 PM   #4
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Embodiment of the AFF spirit in his efforts with ACP.
Dont stick it in all the way lol, just past the flap, works for me, good luck!
cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792
Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007)
Maka is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2018, 10:33 PM   #5
uniacidz
uniacidz's Avatar
Both my Ford and current Holden does it.
In fact the Holden is worse.
Past the flap, not full but bout half speed on fuel pump throttle handle (dunno what to call it) and wait til proper clicks off
Sent from my ASUS_Z00AD using Tapatalk
Before -
ED Falcon Futura (sold)
EL XR6 (R.I.P.)
VX SS (R.I.P)
VE Berlina
uniacidz is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2018, 04:10 PM   #6
blockhead83
have a look in the filler neck. Is the flap still there?
I've got the same problem in my AU and it's because the flappy thing has fallen down the filler neck. I can pull it up with a magnet but I can't get it out of the hole.
blockhead83 is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2018, 05:49 PM   #7
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
No worries with my AU and previous BA, the new FG does it though. The old work Ranger did it badly and it turned out to be one of the breather hoses that had been bent over when the tray was fitted, straightened it up and had no worries. Might be a long shot but somehow maybe its happened on the Falcon.
Otherwise I just hold my tongue to the left and squint, seems to work lol.
Mk1 GT Cortina Project.
FG XR50 Daily.
Rallye Sport is online now   Reply With Quote Multi-Quote with this Post
Old 25-03-2018, 09:50 AM   #8
sednwol
sednwol's Avatar
My XR8 is the same, I twist the nozzle at an angle when filling and it works without a problem then.
sednwol is offline   Reply With Quote Multi-Quote with this Post
