Old 14-02-2018, 10:47 PM   #1
Swedishmoose
Default Aircon compressor going?
Appologies up front for opening up a new thread just to post a question which might have been asked before.
I couldn't find anything satisfying
I noticed today a whirring noise when my aircon compressor is engaged. It almost sounds like a faulty harmonic balancer or in a way like a supercharger on idle.
The whirring noise changes with changing rpm's.
Aircon seems fine....a bit week first on a very hot day parked in the sun all day but cools down after a while sitting on fan speed 4 and recirculation setting.
I haven't done a re-charge in a while and its the first compressor.
Ford Falcon Futura, year 2000 nearly 200000 original km's
Any ideas?....the noise disappears when ac-compressor is not engaged and returns immediately when clutch engages.
Would be happy about any answer and help....
Swedishmoose is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2018, 02:15 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: Aircon compressor going?
The AU is fitted with an FS-10 compressor and there are rebuild kits for them that include the compressor bearing. It could also be the A/C compressor clutch that's on the way out although they tend to squeal.
Russ
Observatio Facta Rotae
Old 15-02-2018, 07:11 AM   #3
Swedishmoose
Hey Russel...
Its not really a squeal like a loose serpentine belt.....its a whirring sound when the compressor is engaged. It was very hot yesterday so i dont know if i can put it down to that.
I checked the inlet and outlet lines and one was cold with condensed water on it and the other was warm and that seemed normal.
I am too busy to do it myself.
Ford would charge an arm and a leg and i'm not sure what other organisation is specialised in ac systems on cars in the Wollongong/ Shellharbour area.
I hope its not the compressor and a regas will do.
Old 15-02-2018, 09:48 AM   #4
speedzter
Yes, check that it's not the clutch is not slipping. Replaced mine recently as it had an oil leak, and chewed the clutch out.
speedzter is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2018, 01:56 AM   #5
rowan194
I have a similar problem with my 2002 AUIII Fairmont. The excessively noisy whirring only when the clutch is engaged, and also when the engine has been off for a while sometimes there's a bit of a squeal maybe 30 seconds after I take off. Can't see any obvious belt slipping but I notice the battery voltage is on the low side then suddenly shoots up to normal after the squeal.
Sounds like I have a buggered compressor AND clutch?
How much do they cost to replace at a specialist?
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2018, 09:56 PM   #6
speedzter
Cost me $800 to have a new Sanden compressor fitted.
Old 20-03-2018, 12:18 AM   #7
Vortex-98
Vortex-98's Avatar
I turn mine on but it never gets cold...think it needs to be regassed
[B]WTB (Syd)...AU 5.0 or xr8 4 speed auto transmission in good working cond /B]
Vortex-98 is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2018, 09:45 PM   #8
berney
my au compressor clutch seized .. heaps of smoke but stopped once a/c turned off . I bought a sanden compressor, receiver drier, and valve as a package off ebay for about $360 went to a/c place to get gas sucked out , put on new stuff ... my condenser was ok but I should have replaced then I would have had a completely new system $200 for condenser .$150 for regas its really good now.
if you are reading this and you have a weird smell in your car and carn't figure it out , it used to drive me crazy and I used to think it was oil on muffler or oil burning on engine , bad fuel etc. Once I replaced the compressor ..no more smell . it was the compressor clutch on the way out
berney is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2018, 09:55 PM   #9
T3rminator
T3rminator's Avatar
My 04 BA does the same. Took it to an auto A/C shop and they said it's pretty standard. Replacing will cost in the region of $800 to $1200. Bit of labour involved apparently as there are a few other linked parts that you need to take care of at the same time.
Recommended that i just ignore it until it completely dies. The A/C is still really cold all of the time so thats not a problem. Just the noise is really annoying, especially when going through underground car parks
Old 01-06-2018, 02:04 PM   #10
rowan194
Mine is now super noisy and it's also not cycling properly. If I switch AC on when cruising I can feel the car lurching as it kicks in and out, and the compressor only stays on for about a second each time (excessive friction causing overheat cutout?). Engine bay fan also starts up pretty quickly which didn't used to happen. Not sure it's worth spending $800+ on a repair, but ask me again once summer comes.
