19-06-2006, 05:38 PM | #1 | ||
can someone tell me if there are two fuse boxes if so can u tell me where the second one is i know where the one is under the bonnet?
also under the same sort of thing i cant figure out why i havent got any indicators or horn any help would be good thankz Mustang
1980 Coupe, Blue, 1.6L, 2" exhaust and extractors. Oversteer Scares The Passengers , Understeer Scares The Driver WWW.QLDSTREETSCENE.COM/ |
21-06-2006, 01:41 PM | #2 | ||
does this mean noone can help me?
22-06-2006, 10:23 AM | #3 | ||
Maybe no one knows to what sort of car you're referring ???
If it's an Esky there is indeed only one set of fuses. If you have tested the circuits for power to the multiplug under your steering column that supplies the indicator stalk then the problem is most likely in the stalk. It is the only "common" denominator from what you've said. |
22-06-2006, 03:04 PM | #4 | ||
FOXWHO
he has that blue escort 1.6L. I remember he posted pics of it.
My indicators stuffed up on me once (i never checked if the lights were actually working or if it was just the dash screwing up) but the wire came loose from the back of the alternator. Put it back on and it works fine now. hope that helps. What part of aus are you in mustang? |
25-06-2006, 11:01 PM | #5 | ||
cairns qld
25-06-2006, 11:02 PM | #6 | ||
Quote(sig):1980 Coupe, Blue, 1.6L, 2" exhaust and extractors.
26-06-2006, 09:50 AM | #7 | |||
Maybe you need to put "Escort" in your sig. so people don't have to guess ... after all it is YOU asking for help. Anyhow, did you sort your prob? PS Arm and hand signals are still legal in QLD if your indicators don't work - oh, and you can use "the finger" for your horn. |
Thread Tools | |
Display Modes | |
