Old 12-10-2017, 09:35 AM   #31
BFIIGhiaZF6
George
BFIIGhiaZF6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: The experience, information and willingness to help and share data in regards to the ZF cooling system options has probably cleared a lot of doubt about air/oil coolers and the ZF transmission.
Default Re: DSC on BF Falcons
Anything limited to 80kph as that is is pretty useless as far as I'm concerned and it is referred to as a space saver in my owners manual, was glad to get a real spare in the boot, my 97 EL Ghia had a full size alloy for a spare, sounds like the cost cutting just got worse in the spare wheel department as time went by
BFWSMhttps://fordforums.com.au/vbportal/v...articleid=1708
ZF:http://fordforums.com.au/wsmpub/bf/307-01B.html
2007 BFII Fairmont Ghia I6 4L, ZF6 Auto, Ego Charcoal, Warm Charcoal.
R/Up 2019:Winner 2023:, Best BA-BF Geelong AFD.
PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI.
1997 Fairmont EL Ghia Tickford 4L Auto
1985 Falcon XF GL 4.1L Auto.
1979 Fairmont XD Ghia 4.1L Auto.
1971 Cortina GL Estate 1200cc Manual.
BFIIGhiaZF6 is online now   Reply With Quote Multi-Quote with this Post
Old 12-10-2017, 12:50 PM   #32
data_mine
GT-P With An Ego
data_mine's Avatar
Not just cost cutting, but striving for fuel efficiency numbers too (a lighter spare will have some minute saving over time), because that's all buyers these days care about.
(so win win as far as the bean counters are concerned)
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw.
2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw.
2008 SY F6X in Silhouette, stock for now nope.
Ford Performance Club of ACT
data_mine is online now   Reply With Quote Multi-Quote with this Post
Old 12-10-2017, 01:02 PM   #33
M&Ms
M&Ms's Avatar
It was still a factory option, to the tune of $300 I believe.
In real terms, a new BF2 Ghia was quite a bit cheaper RRP than an EL Ghia.
My Resume:
Current:
Alfa Romeo Giulia Quadrifoglio in Vulcano Black
MY18 Black WRX STi Spec-R
Previous:
'16 White FGX XR8
'09 Black FG FPV GT 5th Anniversary
'04 Blueprint BA XR8
'97 Mocha Foam EL Fairmont
M&Ms is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2017, 03:40 PM   #34
Mercury Bullet
They all have the 80k sticker on them. R-spec cars have a gt rim for the spare and it has an 80k sticker even though it's exactly the same as the wheels/tyres that are mounted.
I had one of your rims in my xt , it's full-size but only 16" and a larger profile.
As mechanik said, spacesavers are more like bicycle tyres, a tiny rim with a huge profile.
They are really dangerous imo and I won't have one in my car.
So don't throw your spare, it's usable.
www.bseries.com.au/mercurybullet
2016 Falcon XR8. Powered by the legend that is - David Winter.
XC Cobra #181.
1985 Mack Superliner, CAT 3408, 24 speed Allison.
Mercury Bullet is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2017, 11:25 AM   #35
the_scotsman
MY21.5 Mustang GT
the_scotsman's Avatar
Originally Posted by bangm001 View Post
Does it turn off when traction control is off? Pretty sure it doesnt. DSC is always active. Someone correct me if im wrong here.
Nah, that button is a one touch does everything. It turns DSC off. DSC includes traction control. There's no way to turn one off without the other, they're all part of the same system.
Unless the FPVs are different?
the_scotsman is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2017, 11:37 AM   #36
BFIIGhiaZF6
George
Still have it, it's a 16
but just prefer to have a Ghia alloy spare (have 4)
and not be limited to 80kph if I need to use it, peace of mind and looks was also concerned that the ZF6 would be upset by it, let alone the DSC or ABS.
Best one is in the boot
Old 13-10-2017, 12:54 PM   #37
Interesting.
I just noticed the "Low Velocity".
I will guess those things are made for suppressors. Suppressors can only work to reduce muzzle blast from the gasses. It can do nothing against the mini sonic boom of bullet breaking the sound barrier.
Old 13-10-2017, 01:22 PM   #38
M&Ms
M&Ms's Avatar
Correct, one button for both. However, the FG is smart enough to sense when you're in deep $h#t and apparently comes back on to save you.
My Resume:
Current:
Previous:
'16 White FGX XR8
Old 13-10-2017, 07:24 PM   #39
BFIIGhiaZF6
George
Originally Posted by solarite_guy View Post
Interesting.
Correct, Blue nose 158gm for UZI suppressor, link is my UZI 158 rego:yummy
