Old 22-09-2006, 11:45 AM   #1
1bad51
1bad51's Avatar
Default vacume sump advice please
Hi guys i run a mild 351 windsor in an xw sedan 13.5 at 102mph. I have just fitted 100 shot of nos and was thinking of putting a set of vacume lines from the rocker covers to the exhaust. Thiis should create a negetive vacume in the sump at rmp. Has anyone done this that can advise on posible hp gains input would be very welcom. :
1bad51 is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2006, 11:54 AM   #2
tufLTD
tufLTD
tufLTD's Avatar
Moroso make a crankcase evacuation system.
Check it out at http://www.moroso.com/catalog/catego...?CatCode=13023
You could probably buy it through Rocket, VPW, etc here in Oz.
My favourite quote:
"Some people compare David Gilmour to God. He's great, talented & inspiring, but he sure as hell can't play the guitar like David".
tufLTD is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2006, 12:10 PM   #3
1bad51
1bad51's Avatar
I have a good exhaust guy and he says he has seen 3/4 hoses run from tappet covers to fitting that enter the collectors at 45deg. He says to use pcv's to stop any blow back and seal all breathers. Will check out these kits for sure though thanks :eclipsee_
Old 22-09-2006, 12:14 PM   #4
tufLTD
tufLTD
tufLTD's Avatar
PCV's might not handle the heat, a reed valve set-up like in the Moroso kits would be better. Many Jap cars use these types of valves in exhaust systems as part of the EGR system.
My favourite quote:
Old 22-09-2006, 09:23 PM   #5
1bad51
1bad51's Avatar
thanks for that have ordered the kit will see how it goes . Do you think it would be ok for street use or would i loose to much oil? :
Old 22-09-2006, 10:15 PM   #6
Rod
Rod's Avatar
i wouldnt run it on the street as it will suck to much oil from the underside of the piston & the small end of the Conrod will run hot & could cause it to lock onto the gudgen pin
if you do run a Vac-U-Pan setup make sure that you use a one way check valve on the extractors
regards
rod
Rod is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2006, 12:28 PM   #7
ebxr8240
Performance moderator
ebxr8240's Avatar
Does this work with full exhaust system???
I thought this only worked with open headers????
I doubt there would be enough vacuum to have oil issues???
There are vacuum pumps that can pull good vacuum..
But don't go too high, the supper V8's pull around 15Lb but they may have pressurized rod bearing, as Oliver rods are....If used?? It helps ring seal, windage...The V8 guys use dry sump which in essence pulls vacuum ....
Daily driver GTE FG..
Old 24-09-2006, 02:16 PM   #8
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
Would one of these be of any help to an engine with slight ring seal problems?
Would it help with blow by?
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2006, 02:18 PM   #9
nugget378
Weezland
nugget378's Avatar
What was the cost of the kit?
Old 27-09-2006, 11:08 PM   #10
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
regards
rod
Whiskey Tango Foxtrot?
Its pulling vacuum in the crankcase via the valve covers, there is no way in hell 4" of mercury vacuum will affect the oiling to the small ends. Nascar guys pull close to 27" of mercury vac with their dry sup systems, and similarly have no issues.
With the Gas on, I'd be more worried about holing a piston and pumping a whole lot of oil out the breathers and exhaust...
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear"
- Too much power is never enough....Mark Donohue on the Can Am Porsche 917.
Gammaboy is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2006, 09:45 PM   #11
camc88
ba xr6 mk1
camc88's Avatar
Why bother, its only a wheezer.
Ba Mk1 xr6
camc88 is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2006, 09:50 PM   #12
Gammaboy
Gammaboy's Avatar
XR6? Why bother, its only a taxi pack with a body kit.
Real constructive there chief.
Old 28-09-2006, 10:28 PM   #13
Barry_v
rocknrolla
Barry_v's Avatar
got any other info on your engine setup 1BAD51? Ive got a 351w ZC Fairlane. cant help with the vacuum sump sorry.
gammaboy, camc88 has twin cams, dont argue with him.
Barry_v is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 01:33 PM   #14
1bad51
1bad51's Avatar
Default Vacum sump is on
Well the vacum sump kit is on and i have been driving it on the street no problem. 1.It does not use more oil.
2.It does stop minor oil leaks,
3.There is a notable differance in rev responce and top end power.
4.It only cost $300 fitted.(local exhaust shop)
Conclusion money well spent good bang for buck
thanks for your help guys
: 1BAD51 XW351 WINDSOR :the_finge : BUILT NOT BOUGHT :ticking:
