Old 13-09-2005, 08:08 PM   #1
Teki04
Clio 182 CUP!
Teki04's Avatar
Default Does not want to start the first time...
Ok, well my car has not wanted to start about 3 times in the 1 year i have owned it.... i mentioned it at the 15000/1 year service, and they said they checked and reflashed all computers.... then today (car was in the sun on all occasions) the car did not want to start, a total of 3 times! First time the a/c was on, so i thought it was for that reason. Then, the next two times it happened again! I really dont understand the reason....
Well, my new light switch and spare wheel screw are in and ready to be installed, so i will mention that to them.
Also, after hard braking once (like a sudden stop) the next few times i hit the brakes, just before it stops they sound as though the are grinding. It says they checked the brakes, so im guessing they are good for the next service (30000km)......
Steven
'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04)
Teki04 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2005, 08:49 PM   #2
Cypher
Fiesta Zetec
Cypher's Avatar
Mine has does this start thing twice, so I just pump the gas like the old carby days (not so good for injected cars) and it does the trick!
Brakes, well I think that might be an issue with the pad compound.
:lookedat:
Cypher is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2005, 09:14 PM   #3
joshf2
striped
joshf2's Avatar
at the end of the day, you end up changing most of these consumables, so you may as well do them right at the start
most of the time, they use quite a hard compound for the brake pads from the factory, i'd change these straight away
joshf2 is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2005, 03:36 PM   #4
Danny
GT4.
Danny's Avatar
Cypher, The Fiesta has an electronic throttle, It wont do a thing unless the car is started and running.....
Old 14-09-2005, 07:51 PM   #5
Cypher
Fiesta Zetec
Cypher's Avatar
Try it, as the car is cranking the throttle will work. Yes it is electronic but as soon as it has power it can function.
:lookedat:
Old 14-09-2005, 08:02 PM   #6
Pieoter
The manual states that if the car doesn't start you should give it some accelerator to get it started.
COLORADO RED FIESTA ZETEC
MODS - Window Tint, Bmc Panel Filter, Euro Plates, Ghia grill, Momo F16 leather gearknob, Momo Leather gearboot, WQ Zetec Front sway bar, WQ Zetec Sway bar links, WQ Zetec bushes.
ICE - Alpine CDA9827, MbQuart Reference 6.5inch splits, MbQuart Reference rears, Rockford Fosgate Punch Stage 3 12inch Sub, Rockford Fosgate P4004 + P3001.
Pieoter is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2005, 10:30 PM   #7
Fez WQ
My car has done this 2 times but both times it was dead. no starter motor only lights. To fix it I locked the car and unlocked it it then started. The immobliser may have just been confused
Fez WQ is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2005, 12:13 AM   #8
Cypher
Fiesta Zetec
Cypher's Avatar
yeah this can happen when U crank the motor and it does not start...must be a fail safe as it assumes the car is trying to be started other than normally. Assuming normal start would get the engine to turn over.
Yep, I just turn the ignition off and then back on again and it seems fine.
:lookedat:
