Old 05-03-2011, 01:02 PM   #1
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default How to replace front seat foam
This is a short how to on changing the front drivers seat. As a 'big' guy (or fat to most) the drivers seat was showing its age. The outside back swab foam had worn
and the base had lost the support feel. So I went to the wreckers and bought the back section (drivers side in better nic than mine). This was cheaper than buying the whole seat.
So first remove the front seats (both)
Slide the seat forward and backward to again access to the retaining bolts
and
Unplug the cable at the base of each seat.
with both seats out give the floor a quick vacuum
Next with the seats out, remove the passenger and driver seat bases. they are held on by 4 bolts under each base
The bases just swap straight over. As I hardly ever have a passenger going to and from work the passenger side feels like new.
Next the back section.
Undo the drivers side back rest from the base. Firstly remove the lumber support knob.
next on each side the bolts at the base of the back support (2 on one side, 3 on the other)
Next swap over the cover and inside foam from the donor back section. You will need a pair of wire cutters to remove the retaining clips on the bottom of the back section
As you peel back the seat cover the damage on the driver seat is quite clear.
3/4s of the way up there is a steal rod that holds in the seat cover, again using the wire cutters cut the ties.
Repeat the process to the donor back section. This show the condition of the 'brand new second hand' foam.
Next I repaired the donor cover, I used some tape and glue just to firm it up.
The foam is easy to swap over. Having swapped the foam pull the 'new' cover the foam. I used plastic pull ties to replace the metal ones Ford uses. Re clip the steal rod (sorry no pics). Pulling the seat cover tight, retie the bottom section.
Next bolt the back section back to the base and attach the lumbar support knob
That is it. You put the seats back in. My drivers side base feels a lot firmer and the side is great.
and with seat covers on
Next I might as well use the spare donor steal frame for the passanger side as it has lumber support.
UK
Old 05-03-2011, 01:27 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Awesome writeup UK - can you blow up the photos a bit though pls?
Old 05-03-2011, 02:28 PM   #3
Uncle_Ken
Uncle_Ken's Avatar
Done
Old 05-03-2011, 02:33 PM   #4
GK
Walking with God
GK's Avatar
Nice work UK!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 05-03-2011, 02:48 PM   #5
Uncle_Ken
Uncle_Ken's Avatar
Default Ta
Thanks GK, Praise indeed
UK
Old 06-03-2011, 08:50 AM   #6
Whoosha
AU DIE HARD
Whoosha's Avatar
Another nice job there UK , another for the how to threads , just one more tip, this is what Ford did when my baluster failed after 12 months was to wrap the bars running up the side with a layer of tape to stop it rubbing on it,
must have worked , 8 years on and still going
Originally Posted by Riksta
Old 13-08-2020, 03:04 AM   #7
Tow_Ute XL V8
Tow_Ute XL V8's Avatar
Default Re: How to replace front seat foam
I have an XL ute that has pretty sad seats. I was looking to either refurbish what is there or, reaplace wth something aftermarket (Saas or something)
The foam that is used to refurbsh, none of that seems to suit the non-XR6/8 family...
Is there a HUGE difference in the seats themselves that would cause the form from one, not to work with the fabric cover of mine?
The Gene Pool Needs More Chlorine.
Tow_Ute XL V8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2020, 09:58 AM   #8
Excluding possibly FPV products, the framing of base and backrest is consistent - noting variants that may include lumbar support and side airbags.
Foam has Velcro style “hook strips” bonded to its channels. So the pattern of the foam must match the pattern of the cover stitching.
You can glue in repair chunks with contact adhesive or sometimes polyurethane glue (this can give a hard seam). Foam is best cut in a domestic repair with razor sharp shears IMO.
Old 13-08-2020, 11:52 AM   #9
Tow_Ute XL V8
Thanks heaps for the info. That is great news actually.I would probably not go the "repair chunks" idea I can see how that mighht go down the track...
If I did not get the standard see re-foamed, I would likely look into a sports seat from Saas or Sparco or something like that, similar to what others have done.
Cheers again.
Old 13-08-2020, 06:24 PM   #10
Bill M
Bill M's Avatar
My recollection is that AU seat trim is hog ringed to inset wire in the foam and not attached with the velcro strip.
AUII XR6 VCT ute
20 years and still going strong!
Old 14-08-2020, 12:23 AM   #11
Tow_Ute XL V8
Damn happy I do not have to muck about with that
I watched a "how-to" video and it seems fairly straight forward, albeit tedious.
Cheere for the replies
