Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Pit Lane Performance
Pit Lane Performance Pit Lane Performance, tuning for power and satisfaction. Website Link
Old 06-12-2012, 11:56 AM   #1
MeanstreakJR
. . T U R B O . .
MeanstreakJR's Avatar
Default Atomic Valve Springs
Hi mate
Just wondering could i get price and availability + shipping to Innisfail FNQ 4860
#306801 - Ovate Race Valve Springs to suit Ford DOHC 6 Cylinder Engines
Tension: 90 lbs at 1.490"
Tension at .500 valve lift: 195 lbs
Coil bind: 22.3mm/ 248 lbs
Suitable for use to 2.4 bar boost (35lbs)
Uses standard retainers or Atomic
Cheers Dylan.
BLUEPRINT BA XR6 UTE
MeanstreakJR is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2012, 04:04 PM   #2
ratter
ratter's Avatar
Default Re: Atomic Valve Springs
Hi Dylan
the Atomic 306801 valve springs sets are $495 while the 306800 sets are $363.
I will need to check the freight cost if you wanted a set.
In most cases we fit the 306800 and have cars making upwards of 400 rwkw using them.
Old 07-12-2012, 12:41 PM   #3
MeanstreakJR
. . T U R B O . .
Oh okay, the 306800 would prob's be the better buy then? also do u guy have the tool to install them?
Old 07-12-2012, 02:33 PM   #4
ratter
ratter's Avatar
the 306800's should be all you need for most street cars.
yes we have the atomic tool, but do not hire it out
Old 07-12-2012, 04:22 PM   #5
MeanstreakJR
. . T U R B O . .
thanks mate will most likely be ordering a set down the track Also where can i hire the tool from?? If you could send me a quote with price + fright would be appreciated my email address is MeanstreakJR@wesnet.com.au
Cheers Dylan
Old 08-12-2012, 06:34 PM   #6
sideways82
loving the turbo
your nearest one that i know of is at SVS
BF mkII 6 speed ZF
now with 500hp at the tyres
best times so far on street tyres
12.48@113.92 with 277rwkw
12.27@119.1 with 320rwkw
sideways82 is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2014, 11:05 AM   #7
theshredder
In your opinion Ratter at what power level is critical to install the springs ?
thanks
theshredder is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2014, 11:18 AM   #8
HI PSI
Was the price on the 801's a typo? As the set I got from Atomic only a month ago were close to $700.
HI PSI is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2014, 12:20 PM   #9
ratter
ratter's Avatar
what model turbo?
it is not a power level that is fixed, it varies according to how many klms the car has done, what exhaust and how lucky you are
Old 28-07-2014, 12:31 PM   #10
theshredder
Originally Posted by ratter View Post
what model turbo?
2013 Fg with under 1000Ks & looking to do mods
exhaust will be the High flow cat & ring in pipe removed to start with.
inter-cooler, air box , intake & injectors will pull it up for now.
Just wasn't sure if springs needed doing
thanks
Old 28-07-2014, 12:48 PM   #11
ratter
ratter's Avatar
we had a fg last week that needed valve springs but have done many that didn't need them.
Before you modify your cat, are you aware we have a group buy for High flow cats, this allows you to keep your original one unmolested for when you need to refit it.
Also have a group buy for cooler kits
Old 28-07-2014, 01:11 PM   #12
theshredder
Yes mate i plan on getting the venom off the group buy
wasn't going to touch my org cat . The exhaust ring is in the pipe work isn't it ? that's what i was also going to do.
I just looked at the pic of the venom i take it you ment i wont have to do the ring as the section will all be removed with the high flow &its length of pipe
Old 28-07-2014, 01:21 PM   #13
ratter
ratter's Avatar
the cat in our group buy has the pipe section that eliminates the restrictor ring
Old 19-11-2014, 02:50 AM   #14
982F6
according to the prices listed on the atomic website Mick's prices are spot on (as expected)
http://www.atomicperformanceproducts...rice_list.html
982F6 is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
