Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Mainline Dynolog Dynamometers
Mainline Dynolog Dynamometers Mainline Dynolog Dynamometers. Website Link
Old 03-11-2010, 06:40 PM   #1
mainlinedyno
mainlinedyno.com.au
mainlinedyno's Avatar
Default Refurbished 2WD Dyno Package For Sale
[font=Verdana', 'sans-serif]FACTORY REFURBISHED 2WD CHASSIS DYNAMOMETER[/font]
[font=Verdana', 'sans-serif]600Kw - 1600Nm Rated Capacity[/font][font=Verdana', 'sans-serif]
[/font]
[font=Verdana', 'sans-serif]12 Months MDD Factory Warranty Included[/font][font=Verdana', 'sans-serif]
[/font]
[font=Verdana', 'sans-serif]SAVE $ 25,000.00 +[/font][font=Verdana', 'sans-serif]
[/font]
[font=Verdana', 'sans-serif](Compared to new Dyno price)[/font][font=Verdana', 'sans-serif]
[font=Verdana', 'sans-serif]SEE ATTACHED FLYER FOR MORE DETAILS[/font][/font]
[font=Verdana', 'sans-serif]We currently have a used DTS 6500 Model Chassis Dynamometer that was traded in, on a new Mainline DynoLog unit. This unit is now available for remanufacture and sale. This is a good quality heavy duty chassis dyno suitable for various LPG, Diesel, High Performance and General Tuning applications. The heavy duty construction allows a high axle loading and would be suitable for light, medium and possibly some heavy vehicles. (Up to 6000Kg axle load). The unit has large 320mm rollers that will be remachined and knurl applied to drive rollers as part of the refurbishment. An added bonus with this unit can be operated at high road speeds up to 250 kph. This unit is fitted with a quality Telma CC160 eddy current retarder.
The dyno vehicle track is 600mm to 2600mm allowing a wide variety of vehicles to be dyno tested. This unit is fitted with a heavy duty pit flange to suit in ground use or could be installed above ground with vehicle ramps fitted if required. The unit will be fully stripped, fully reconditioned and converted to a Mainline DynoLog Control and Data Acquisition system with the majority of the package inclusions being new items. The unit will present as new, and 12 months MDD factory warranty is included (Excluding Consumables) the same as a new dyno.
The offer also includes on-site installation and operator training for Australian purchaser only.
[/font]
[font=Arial', 'sans-serif]The refurbishment process will include the following tasks:[/font][font=Verdana', 'sans-serif]
1. Strip complete unit and pressure clean all components
2. Strip and powder coat complete chassis bed assembly.
3. Remachine all rollers with high traction knurl applied to drive rollers.
4. Zinc coat all rollers
5. Dynamic balance all rollers
6. Replace all roller and retarder mounting bearings
7. Blast and powder coat all cover plates and panels.
8. Fabricate and fit MDD Heavy Duty Traction Control System
9. Fit new MDD speed sensor
10. Fit new MDD load cell and moment arm
11. Fit new MDD wiring harness assemblies
12. Supply new Deluxe Workshop Cabinet with twin boom arms
13. Supply new mains power distribution enclosure ( located in cabinet)
14. Supply new MDD control module
15. Supply new MDD computer module, Windows XP Operating System, HP Colour Printer, Twin 22" LCD Monitors, Wireless Trackball Keyboard Controller
16. DynoLog Chassis Dynamometer Control & Data Acquisition Software Program.
17. Fit retarder cooling fan with temperature logging sensor
[/font]
[font=Arial', 'sans-serif]The unit will be fitted with the following standard and optional accessories:[/font]
  • [font=Verdana', 'sans-serif]New MDD Polished Aluminium Scuff Plates ( Vehicle DrivePath Surface Protection)[/font]
  • [font=Verdana', 'sans-serif]New MDD Heavy Duty Traction Control & Vehicle Restraint System[/font]
  • [font=Verdana', 'sans-serif]New MDD Automatic and Wireless Remote Vehicle Fan Control[/font]
  • [font=Verdana', 'sans-serif]New MDD Automatic and Wireless Remote Retarder Cooling Fan Control[/font]
  • [font=Verdana', 'sans-serif]New MDD Automatic and Wireless Remote AFR Heater Control[/font]
  • [font=Verdana', 'sans-serif]New MDD 14,000CFM 3 Phase Vehicle Cooling Fan ( Programmable Automatic or Wireless Remote Operation)[/font]
  • [font=Verdana', 'sans-serif]New MDD Automatic Weather Station Module (Environmental Power Correction to Multiple International Standards)[/font]
  • [font=Verdana', 'sans-serif]New MDD Engine RPM / *Tacho Trim Module (Secondary Inductive & 3 to 500 Volt Primary Ignition/Crank/Pulse Source Probes)
    [/font][font=Verdana', 'sans-serif]* Tacho Trim Module = Engine RPM control instead of vehicle wheel speed control[/font]
  • [font=Verdana', 'sans-serif]New MDD Data Acquisition / Logging Module[/font]
  • [font=Verdana', 'sans-serif]New MDD Injector/Component Duty Cycle Module & Probe / Clamp[/font]
  • [font=Verdana', 'sans-serif]New MDD 0 – 30V Definable Analog Input with probes[/font]
  • [font=Verdana', 'sans-serif]New Twin 22”LCD Monitor Upgrade Kit (Additional Test Functions, Features & Data /Graphical Displays)[/font]
  • [font=Verdana', 'sans-serif]New MDD Challenge Software Package ( Dedicated Power Competition Management Software Program) [/font]
[font=Verdana', 'sans-serif]See attached flyer for more details, or call (02) 9773 8222, or email sales@mainlineauto.com.au
[/font]
[font=Arial', 'sans-serif]THERE IS NOTHING LIKE A [/font][font=Arial', 'sans-serif][font=Arial', 'sans-serif]MAINLINE DYNO ![/font][/font]
File Type: pdf DTS_2WD600_Refurbished_Chassis_Dynamometer_Package.1.pdf (211.3 KB, 214 views)
Mainline DynoLog Dynamometers
ACCURATE - CONSISTENT - REPEATABLE
www.mainlinedyno.com.au
mainlinedyno is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2010, 09:04 AM   #2
mainlinedyno
mainlinedyno.com.au
The above unit has been sold, however we have some more trade in units coming up that will also be re-manufactured and converted to a Mainline Dyno. If you are in the market for a new or good rebuilt dyno with full factory warranty, please contact our office.
The Mainline Team..........
Thread Tools
Display Modes
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
