Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Shockworks
Shockworks Ford damper specialist located in Melbourne's S.E suburbs. Website Link
Old 05-06-2014, 04:44 PM   #61
Shockworks
Default Re: BA-FG Monoblock 4 Pot Brake Upgrade
Originally Posted by Stazza_Brendan View Post
Not answering PM's?
Sorry Brendan I have answered your PM and somehow missed it
Brett
Shockworks is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2014, 04:53 PM   #62
natedog
Here's a couple pics with rims on looks good!
2010 mk1 GS sedan with 412rwkw thanks to Pitlane Performance!
KPM Street fighter stage 2 intercooler with 70mm pulley
1000cc injectors
Herrod Fuel pump
BMC air filter
Built tailshaft
Shockworks Coilovers
Shockworks 4 piston monobloc front brake kit
Herrod oil breather and "special" diff breather kit
19x9.5 rears 19x8.5 fronts with sticky Michelin rubber
natedog is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2014, 05:21 PM   #63
Stazza_Brendan
Stazza_Brendan's Avatar
How much gap between the caliper and wheel do you have?
Seduce BFII XR6T Ute
ZF - Optioned interior - Hardlid - Rapidsystems V4.5 kit - GTX3576R - Crow Cams Valve springs - 1000cc KPM injectors - 20" MC Racing Wheels - DashDaq/Cobalt Gauges - 4in dump/3.5in exhaust system - Shockworks Coilovers - 30mm Swaybar - Shockworks 4pot 355mm front brakes - GT R-spec rear brakes
CPV Tuned to 340rwkw
Stazza_Brendan is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2014, 05:34 PM   #64
natedog
Not sure, ill have a squizz tomorrow in daylight and post up
1000cc injectors
Herrod Fuel pump
BMC air filter
Built tailshaft
Old 05-06-2014, 05:37 PM   #65
Shockworks
Hi Brendan,
Our brake kit is 207.5mm from the centre of the hub to the outer most part of the calliper.
Old 07-06-2014, 09:25 AM   #66
dl86
dl86's Avatar
How far away for the floating rotors to suit Brembo's?
FG MKII GT ZF, 444.8rwkw, 61mm YT snout, 1000cc injectors, 460lph fuel pump, big kpm intercooler, shockworks w/12kg front springs, SSR GTX01 18X9.5" +22 F/R, nizpro input shaft, 1pce 4" AL tailshaft, poly bushings all round, trutrac, headerback exhaust 3", whiteline sway bars, IMS diff hat, herrod spark booster, Alpine R type speakers/Alpine R type 2x12" ported subs/Pioneer GM-D9601/8604 amps and other bits
dl86 is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2014, 01:10 PM   #67
Shockworks
Hi dl86,
We will be receiving the new floating pins next week so they will be available from the start of the following week.
Old 16-06-2014, 11:37 AM   #68
Stazza_Brendan
Got my brake kit today.
Quick test fit to make sure calipers clear wheel. Got about 4-5mm clearance. These wheels require a 3mm spacer to run Brembos so these calipers are quite thinner.
This is not how they sit when installed. This is just with the caliper zip tied to the suspension to check clearance.
Old 16-06-2014, 04:37 PM   #69
Shockworks
Finally have new bobbins in stock for the floating discs!
Old 16-06-2014, 09:03 PM   #70
dl86
dl86's Avatar
Give me! Give me!
Old 16-06-2014, 09:39 PM   #71
dragons90
What will they be like for noise.
Thanks Gerard
dragons90 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2014, 01:00 AM   #72
MattSAU2XR8
Any chance you can say whether they fit behind the honeycomb XR8 or 2008 to 2012 G6E 18 inch wheels? If not could you list rotor height (back side of disk to face abutting wheel) and how far out from the outer face the wheel sits? Then one could probably extrapolate within reason?
MattSAU2XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2014, 02:14 AM   #73
XXX747
Shockworks can you tell us if these clear the g6et 19's please. I think you will have quite a few sales if they do..
XXX747 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2014, 06:04 AM   #74
Stazza_Brendan
I can try get my hands on a g6et wheel to trial fit. I'll try get an accurate measurement today on how much further out the shockworks caliper sits compared to the standard caliper.
From quick look the shockworks caliper is about 5 or 6mm thinner then a factory brembo setup.
Old 17-06-2014, 08:36 AM   #75
Shockworks
Thanks Gerard
Hi Gerard,
Testing we have done in Korea shows no noise as we use a spring clip that supports the disc and stops the rattle that you can normally get with a floating styles disc assembly.
Brett
Old 17-06-2014, 08:42 AM   #76
Shockworks
We will also try to get G6ET wheel but may be a week or so as I am back oversea's testing in a few days and teaching some driver training again for 10 days.
We should have a track day for the Ford Forums I think.
If I can't get a car and the wheel this week, I will arrange this on my return!
Brett
Old 17-06-2014, 03:28 PM   #77
Stazza_Brendan
Got my brakes on today. Shockworks front and F6/GT rears with DBA rotors.
Huge difference in braking power.
This is the best i can do with the measuring. Ive put the word out on local facebook page to borrow a G6 wheel.
The shockworks caliper sticks out the same distance as the stock wheel studs.
My rough measuring put the shockworks caliper as sitting 40mm further out then the stock BF(FG?) caliper.
This is stock caliper on BF showing it sits back from the rotor on hub a few mm.
Before shot. Stock BF Turbo brakes with DBA rotors.
After, Shockworks 355mm , 4pot setup.
I took a heap more pics of the install in my build thread.
7 users like this post:
Old 17-06-2014, 05:01 PM   #78
Doogs
Doogs's Avatar
Excellent stuff. Are there any other colour options for the calipers and disc yet?
Matt
2010 FPV GS 5.0 manual
Shockworks adjustable coilovers, 19 x 9.5 volk racing te37 superlaps, Stainless headers, cats & Twin 3" exhaust. KPM 1500hp fuel system. Chromoly axles, Truetrac, Carbon Fibre tailshaft, ID1000s, Big Herrod cooler, Yella Terra snout, GT-P seats.
458 rwkw/1020Nm e85, 430/950 98ron 10psi
Audio:
8 Channel active setup
Clarion HX-D2 Special Edition
Crescendo Opus 9.9 A pillars + doors
Audison LRX 3.1k & LRX 4.5
Boston acoustics SPG 555
Doogs is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2014, 05:11 PM   #79
Shockworks
Matt
Hey Matt,
At this stage we have moved away from the gold hats and have the dark grey as in the pictures. We have the option of a red caliper apart from the black. We are now looking at a gun blue colour and a couple of others but that will be a while off yet. What I plan to do is have a range of different colour alloy hats that I can assemble according to what colour the customer wants. This is a bit tricky though, as the disc and alloy hat are balanced together as a unit for best results so need to find a solution to this first. They are balanced to just a couple of grams so don't want to change this too much.
So many other things to get cracking on like finish the testing of the rear disc in which we have a full day of tests tomorrow.
Brett
Old 22-06-2014, 05:48 PM   #80
dl86
dl86's Avatar
Here's a shot of the Shockworks full floating 2 piece brake rotors I installed this Thursday.
Makes your head fly through the window with the Project Mu HC+ competition pads I got. Perfect fit and finish with the rotors.
6 users like this post:
Old 22-06-2014, 06:47 PM   #81
natedog
Hey Brett....Ford forums Track day!!!
I'm in if it can be arranged!!
1000cc injectors
Herrod Fuel pump
BMC air filter
Built tailshaft
Old 22-06-2014, 09:34 PM   #82
Shockworks
Hey natedog,
Sounds like a great idea. I am currently overseas training a whole bunch of chassis engineers advanced driver training and on limit testing on a 20 acre skid pan which is so much fun.
Nothing like fish tails at 160kph with nothing in sight to hit haha.
A Winton day would be great and would be happy to help the guy's with some techniques and smoothness for the track. If we can arrange something, I would happy to do this for free for the forum members. I may also get a lap or two in a Ford so well worth it haha.
Brett
Old 22-06-2014, 09:45 PM   #83
natedog
Hey natedog,
Brett
Winton has test and tunes on Fridays don't they?
Sounds good to me!!
1000cc injectors
Herrod Fuel pump
BMC air filter
Built tailshaft
Old 28-06-2014, 08:58 PM   #84
xr8 007
xr8 007's Avatar
Any word on part numbers for rotor replacement and brake pads im very interested in this kit.
Build Thread: BA XR8 with all the goodies.
fordforums.com.au/showthread.php?t=11247663
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2014, 11:51 AM   #85
Shockworks
Hi xr8 007,
The rotor replacement we have if to suit the Brembo calliper for the GT 355mm disc and our brake upgrade with our own 355mm two piece disc and 4 pot calliper.
At this stage we don't offer replacement discs for the premium FPV brake upgrade option so, sorry mate.
Brett
Old 12-07-2014, 11:51 AM   #86
Stazza_Brendan
Had these for almost a month now. Insane braking even with my current small front tyres (will fix that later). And even better I'm not getting any annoying brake dust.
Old 25-07-2014, 07:25 PM   #87
raband
Any update on the rear set yet?
raband is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2014, 07:24 AM   #88
twr7cx
Member
twr7cx's Avatar
Why aren't these listed for the AU too?
Current vehicles: MY12 Land Rover Discovery 4 TDV6, MY03 Land Rover Discovery 2 HSE Td5 off road modified and 1989 Mazda NA MX-5 toy car.
Previously: 1992 Ford EBII Fairmont, 1994 Ford EF Falcon XR6 supercharged, 2003 Ford BA Falcon XR6 Turbo 325rwkw, and 2002 Ford AU3 Falcon XR8 Pursuit 250 270rwkw.
twr7cx is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2014, 06:00 PM   #89
Shockworks
Most likely because we had not had the chance to do a fitting haha. We still not not have tested the brakes on AU yet but understand that the front upgrade should fit the AU series 2. After we get through some current development work (2012 GT shelby Mustang and some other cars) we will get started on the AU damper work when we find a suitable car.
Brett
Old 31-07-2014, 07:00 PM   #90
FormulaFG
Lurking......
FormulaFG's Avatar
Anyone know the answer to this? Pretty much the only thing stopping me from buying a kit.
FormulaFG is offline   Reply With Quote Multi-Quote with this Post
