Old 10-03-2014, 10:50 AM   #1
peterr
peterr's Avatar
Default Ute stop lights
My son just bought a AU11 ute, there are a couple of things need doing.The stop lights both side dont work, he has relaced the bulbs but still nothing, he bought a test light but is unsure where to start ohg and the horn dont work either.Other things he has to do is front shocks, he paid $6,000 its not a bad looking ute only done 125,000ks but no doubt it will soon go up hes in ALice Springs and is off to a job top end of WA !!
2001 AU11 Organza
peterr is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2014, 02:37 PM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
Default Re: Ute stop lights
Stop lights . probably the switch at the pedal end .pretty common just run the test light between the 2 connection to check. The horn If he has check the unit with a hot wire to see if it is the horn as such then if it does work it is probably the clock spring in the rim bit more complicated .
Originally Posted by Riksta
