Old 19-05-2007, 11:56 PM   #1
jak_a
Default ax telstar short shocks
i was wondering if someone here would know where i could get my hands on short shocks for my 92 tx5 , i have lovell super low springs in the car and lovell tells me they dont have super lows for telstars i'm in melb
jak_a is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2007, 08:12 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
not agood idea the telstars are already quite low
you may have to chase a few mod shops to find an alternative
My car goes Brumm Brumm
Old 20-05-2007, 11:20 AM   #3
jak_a
so installing stantard shockers will be ok in my car?
Old 20-05-2007, 09:09 PM   #4
dirty hands
Over Thinker
most definatly std shocks wont get you defected
Old 21-05-2007, 11:20 AM   #5
jak_a
thanks for advice
Old 28-05-2007, 11:11 AM   #6
Selfmindead
If the springs are not captured when the car is wheel is off the ground then you will need shorter shocks, but most lowering springs are made to work with the factory shocks & be captured.
Selfmindead is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2007, 04:38 PM   #7
jak_a
Default installing front shocks
could anyone tell me how hard it is to remove original ax tx5 front struts and replacing them with gabriel shockers and what tools i would need , thanks in advance
Old 25-06-2007, 08:21 PM   #8
hitork
Injected
hitork's Avatar
My only advice would b watch out when removing the spring, if you slip and the spring jumps out you could be in some major pain. Most wheel places like bob jane will change the struts/springs over for about $60 and they have devices which lessen the danger and work that is needed.
hitork is offline   Reply With Quote Multi-Quote with this Post
