Old 20-05-2018, 04:44 PM   #1
Fgrocks
Question Reverse lamps
I have recently purchased a 95 ef fairmont but it has no reverse lamps,i have checked the bulbs and fuse but to no avail,where do i go from here?.
Fgrocks is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2018, 04:53 PM   #2
Default Re: Reverse lamps
Check the relay or the switch on the transmission. There are probably more scientific places to check but if you start small there's a high chance that it's a cheap component.
Old 23-05-2018, 07:35 AM   #3
LTDHO
The one and only
LTDHO's Avatar
Change the inhibitor switch on the transmission.
Like most auto's, this controls reverse lamps as well as the neutral/park start.
1992 DC LTDHO 360rwkw built by me
Tuned by CVE Performance
Going of the rails on a crazy train
Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
LTDHO is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2018, 09:06 PM   #4
Fgrocks
changed the inhibitor switch but no differance.
Old 30-05-2018, 07:19 AM   #5
LTDHO
The one and only
LTDHO's Avatar
With the ignition on, check you are getting power at the switch
Old 30-05-2018, 07:23 PM   #6
Fgrocks
Sorry if i sound like i have limited knowledge on what to do but do i turn the ignition on until the dash lights up,do i put the gear selector in reverse or just leave it in park and which wire(colour) do i prod at the inhibitor,i have pulled the tail light out and tested at the bulb but no power getting to that at all.
Old 31-05-2018, 07:25 AM   #7
LTDHO
The one and only
LTDHO's Avatar
Leave in park.
Turn key to "on"
Climb under car and make sure there is power at switch.
Old 10-06-2018, 07:52 AM   #8
Fgrocks
Finally got a chance to look at the switch,tested it and there is no power at all getting to it,where to from here.
Old 10-06-2018, 09:40 AM   #9
Fgrocks
Also there is power at the fuse that is in the fuse box on the right hand lower side of the steering wheel.
Old 30-08-2018, 07:45 AM   #10
LTDHO
The one and only
LTDHO's Avatar
How'd you go mate, work it out?
Old 08-03-2019, 01:16 PM   #11
Fgrocks
never worked it out,its still a mystery.
Old 14-03-2019, 08:11 AM   #12
LTDHO
The one and only
LTDHO's Avatar
Sorry to hear mate.
