21-06-2010, 07:19 PM | #1 | ||
Falcon Unbelievable!
Hi guys,
I have a S1 Classic and have an issue with central locking not working by remote. Manually locking and unlocking works fine no issues at all. Previously when I have done actuators usually it beeps and you pull the handle of one of the doors and it unlocks you know which actuator is gone. Problem I have is when manually locked all doors remain locked. Is this still an actuator gone or maybe battery related (its about 3 1/2 years old and I'm waiting for it to go one of these days) Cheers, Chris |
21-06-2010, 08:22 PM | #2 | ||
Hi sounds like a remote control problem, flip open the case and make sure the battery is ok of if the car is responding to the remote the problem will be the drivers door or a relay in the bcm. Cheers MD
21-06-2010, 08:31 PM | #3 | |||
21-06-2010, 08:39 PM | #4 | |||
Boot unlocks no probs at all. so possibly drivers door or a relay. Thanks |
21-06-2010, 08:47 PM | #5 | |||
Sorry JC I should have specified main battery ie 460cca one. I know some cars can do some very weird stuff when battery is about to pack it in. The other interesting thing is that it did this same thing about a month back and it just went away. It's really odd. |
22-06-2010, 02:02 AM | #6 | ||
Do you ever get water in the passenger footwell? If so, you could have water dripping on the ECU and/or BEM. BUT, before trying anything, I'd reteach the remotes to the car and see how you go:
1. Turn car to ACC. Make sure radio is off 2. Press rear demister button 3 times in 5 seconds - door locks should cycle 3. Press any button on one remote 4. Repeat step 3 for all other remotes 5. Turn car to OFF position. Now try the remote - it should open/lock the doors.
22-06-2010, 06:30 PM | #7 | |||
Good part is at least it still manually locks and unlocks with key. |
22-06-2010, 06:34 PM | #8 | ||
Let us know how the retraining goes (and remember, you must do all remotes in the same training "session").
11-08-2011, 11:42 PM | #9 | ||
Hi SirHenry, did you work this one out?
I've got the same problem. I'm guessing the motor/spindle in the actuator has gone but I don't want to replace and find out it's something else. Cheers |
12-08-2011, 01:08 AM | #10 | ||
hey have just had this problem as well. My interior light was staying on and car wouldn't lock. Have had actuators go on me before and thought this was the case again. Couldn't work out the problem after hours of testing each door lock and anything electrical, finally worked out that it could only be the bcm. Got a rebuilt one and installed re programmed everything and car locks again and all working fine.I was lucky as my neighbour is an auto elec and he saved me heaps of money with helping me work out what was wrong.We also fixd heater as the plastic rod had broken which opens the flaps.It is a whole dash out job and very expensive in time if you don't do your self. Any way if locks still going up or down then you should look towards the bcm and anyone else who's car does strange things and then ok again it will be bcm as well. cost was 450 for bcm reco then your labour. good luck.
15-08-2011, 02:53 PM | #11 | |||
Yeah what turned out to be causing all the weird crap was that it was both driver front and driver rear door actuators stuffed. Replaced both and now fine and dandy and just been on a 1600km round trip with no issues. Long Live AU Falcons! |
21-08-2011, 08:16 PM | #12 | ||
Thanks SirHenry, just replaced the actuator and all is good
21-08-2011, 08:37 PM | #13 | |||
24-08-2011, 12:57 PM | #14 | ||
I have a 2001 AU Falcon, when I press the remote the drivers side door does not open. I can lock and unlock the door using the key,I put a new battery in the remote and still no luck.
How do I remove the actuator and how does one tell which actuator not working. Your responce is much appricated. Kind Regards VJJP. |
24-08-2011, 04:46 PM | #15 | ||
Next upgraded Mk1 Leopard
There is a how to here:
http://www.fordforums.com.au/vbporta...article&id=756 I opened the door , hit the button on the remote,and see if anything moved. UK
24-08-2011, 10:23 PM | #16 | |||
24-08-2011, 11:04 PM | #17 | |||
First lock the car manually and check that all doors are locked. Then see if you get the 'click click click" sound when you use the remote. If that is the case it is the spindle in the actuator that is broken but there are 2 different types of spindle. You can pull the actuator apart to determine which spindle it is and then buy on ebay for $30 or save yourself the hassle and buy a reconditioned actuator on ebay for $70. There is a guy on ebay called jimmybean who I've bought a couple off lately and been happy with. |
25-08-2011, 10:15 AM | #18 | ||
Thank you all for your responces,all the doors are locked when I use the key, will try and listen to the "click click click" sound today,is the actuator different from the drives door and the passangers door?
Kind Regards VJJP |
25-08-2011, 05:05 PM | #19 | |||
28-08-2011, 10:05 AM | #20 | ||
I fixed it, the car was not responding to the remote, so I put the car into learn remote mode and waited for all the doors to lock and unlock and then used the remote to lock it worked.
Once again thanks to every ones responce. VJJP |
19-09-2011, 08:01 PM | #21 | ||
the problem l have is the car will lock with the key but will not unlock with the key can anyone help me with this
19-09-2011, 08:26 PM | #22 | ||
if it does the same with the remote its the accuator also if using the key to unlock and it automatically relocks itself accuator is stuffed i replaced mine .$50 used from a ford wrecker
19-09-2011, 08:41 PM | #23 | ||
yer mate the remote has not worked for a long time but car could be opened with key now it will not ,replaced the actuator tonight and same thing locks ,will not unlock
19-09-2011, 09:04 PM | #24 | ||
this is a tricky one will key turn in lock let me know what problem was when fixed.
19-09-2011, 09:12 PM | #25 | ||
key turns in both door and boot lock but will not open ,its got me buggerd
19-09-2011, 09:14 PM | #26 | ||
could the key be the problem?
19-09-2011, 10:34 PM | #27 | ||
its a possibility but if it turns the lock probably not. this is a brainteaser.did you replace the accuator with a new one as a used one can be faulty. you could also ask your local auto electrician.when i had my door locking problem my local auto elect new what the problem was
06-10-2011, 12:57 PM | #28 | ||
I have had a similar problem. I have retrained the remote efter putting a new battery in. It works for a while but then the door lock button will cycle up and down three times. I can open the door but its very annoying. Anyone know what the cause / solution may be?
14-11-2011, 12:31 PM | #29 | |||
ive been 4490'd
Im experiencing a similar issue with my AUII falcon forte.
When i lock all dorrs with remote or key. The front passenger door can be opened when you pull the handle from the outside. Which then unlocks the whole car. Other doors if you try to open dont open. But the front passenger door opens if you pull the handle. Has anyone had this issue?? Also does anyone know what the issue is and how to fix?
14-11-2011, 01:42 PM | #30 | |||
