Old 13-09-2016, 08:25 PM   #121
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech articles Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always putting some imput into the forums to help or make it a bit easier for others
Cool Re: Definitive au2-au3 brake upgrade thread
Originally Posted by XF_Pilot View Post
Standard AU or BF? Do they need to be slightly longer?
Sorry Standard AU
UK
Plastic Surgery 1 Monsoon Blue
Plastic Surgery 2 AUIIXR8 220 Rebel
Plastic Surgery 3 Watch this space ???
Old 15-09-2016, 08:18 PM   #122
XF_Pilot
Default Re: Definitive au2-au3 brake upgrade thread
Ok thank you. I can get a set custom made. Would you suggest the standard AU ones lengthened slightly? If so by how much? Are we talking IRS or beam here too?
XF_Pilot is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2016, 11:48 PM   #123
XF_Pilot
Ok guys. I have started the conversion and started to tackle the rears tonight.
The catch is, that I got these calipers in a box so ibdont know which is left and which is right.
Can someone please confirm if, when the BF rear caliper installed in the car, brake line should be above or below the bleed nipple? This will confirm orienation for me.
Any tricks to getting the front left and right confirmed?
Thanks?
Old 21-10-2016, 11:56 PM   #124
ebxr82nv
Common sense would suggest the nipple should be at the top but they do weird **** on Falcons that makes no sense at all.
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track.
86 ZL mint grandpa spec with premo sound and 150000km
07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4!
97 el futura MOCKed up with a 2500 stall, heaps of fun!
ebxr82nv is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2016, 12:05 AM   #125
XF_Pilot
This is also a live rear axle if that's worth anything. Can anyone who has done the conversion confirm which brake lines they used on the rear (live axle)
Old 22-10-2016, 01:18 AM   #126
Tiger57
Just checked a picture of mine and the bleeding nipple is above the brake hose. I also used the standard AU brake lines front and rear.
Tiger57 is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2016, 08:53 AM   #127
XF_Pilot
Thank you! Is yours a live rear end or IRS?
Old 22-10-2016, 11:06 AM   #128
Tiger57
Mine's a live rear end
Old 23-10-2016, 12:12 AM   #129
XF_Pilot
That's great, thank you for that. I thought I might have yobuse BA lines because the AU ones looked short but obviously not. How did you find the upgrade? Thanks!
Old 23-10-2016, 01:07 PM   #130
Tiger57
I just bought some Braided Lines of eBay recently and they were to suit the standard AU calipers. The conversion is well worth it. I punish my brakes through the hills and I haven't suffered any brake fade yet.
Old 24-10-2016, 07:36 PM   #131
inventiv
inventiv's Avatar
Anyone looking for a massive upgrade on the AU Brake Setup should check out the for sale thread now - have a sweet BF Turbo Premium Brake upgrade for sale on the bay.
inventiv is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2016, 01:17 AM   #132
XF_Pilot
Thanks guys!
One last thing. do the BF turbo Rear brakes have the Philips head securing screw in them? The rear rotors that I have don't have any provision for them? The AU ones that I just removed did.
Old 26-10-2016, 01:46 AM   #133
tkfd
tkfd's Avatar
No the larger rotors don't have them. Mine, I just drilled them out using old AU ones as the template. Remember you will need to countersunk them to accept the grub screw.
tkfd is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2016, 09:52 AM   #134
XF_Pilot
Ah that makes sense then. I was starting to think that I had been given the wrong rotors.
I guess it's worth doing? Do the BF+ have a different retaining system or just taken care of by wheel nuts?
Old 26-10-2016, 10:49 AM   #135
Sox
RIP...
Sox's Avatar
The screw isn't needed.
Ich fahre ein pooftamatique weißes Ompom.
Old 26-10-2016, 11:37 AM   #136
tkfd
tkfd's Avatar
not really needed, but I use it as it keeps the rotor in place when changing pads and adjusting handbrake. Up to you I guess.
Old 21-06-2017, 12:54 AM   #137
jfk069
New Guy
Default Re: Definitive AU1 to AU2/AU3 brake upgrade thread
Hey guys,
Just in the planning stages to do this upgrade to my EF sedan as the front brakes are average and are constantly warping.
Just wondering if this upgrade changes the front wheel offset to the post AUII offset.
If so, will fitting BA brake on the rear change the offset to post AU2 offset for the rear.
Thanks in advance
jfk069 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2017, 09:30 PM   #138
auxlr8
Hi guys. Can some one please send me a link to the definitive au 1 brake upgrade thread. I just can't seem to actually find it. Thanks
auxlr8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2017, 11:32 PM   #139
tkfd
tkfd's Avatar
Cool Re: Definitive AU1 to AU2/AU3 brake upgrade thread
Is this it?
https://fordforums.com.au/showthread.php?t=11263967
Yes that's it, view in Chrome to see picks.
UK
Old 20-09-2017, 02:40 PM   #140
auxlr8
Thanks mate, cant get the pictures to work but the write up is excellent anyway. Just to make sure i got everything i need was it.....
au3 uprights
au3 lower control arms with spindles and hubs
au3 front brake lines
au3 front sway bar, mounts and clips
4x8mm-100mm bolts with washers and nylon nuts
au3 braker booster
au3 brake master cylinder
bf front brake callipers
$275 from the wreckers
bf 322mm brake upgrade caliper supports from ebay
bf 322mm discs
pads
$250 from ebay
dot 4 brake fluid
Thats everything for the front i need?
Also, what options are out there for upgrading the rear brakes on an au1 5.0 v8 fairmont ghia with irs?
Thanks guys for ur help and info
Thread Tools
Display Modes
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
