17-07-2007, 08:17 PM | #61 | |||
Chairman & Administrator
Cheers Russ
Observatio Facta Rotae
18-07-2007, 03:55 PM | #62 | |||
Regards |
23-07-2007, 03:05 PM | #63 | ||
which wiring diagram has the thermo fans? I've looked on the BEM ones but can not find them
07-08-2007, 07:02 PM | #64 | ||
hey russell, i got au I fairlane.... double din premium sound setero with the 6cd stacker in the boot. Was wondering if you have the diagrams and legend for all the wires at the back of the head unit ie. which wire does what? there is two different plugs at the back as well as the antenna. Im putting a dvd screen in and would be great if i know what the wires all mean coming from the loom.
thanks |
07-08-2007, 08:16 PM | #65 | ||
You will need to look up the connector number and then look up the connector seperately in the connector diagrams - this should show you all the wirs and the master diagram will show you the actual assignments.
Cheers Russ
10-08-2007, 12:32 AM | #66 | ||
thanks buddy got it all under control now thanks alot, great diagrams
alex |
19-08-2007, 09:06 PM | #67 | ||
FishermanDan
Is there underhood wiring diagram for sensors to ecu pin numbers ie cam angle, knock, T-map & ign coil pak?
20-08-2007, 12:35 AM | #68 | |||
Click on the link to Technical Resources on the menu bar above and then look under Technical Documents. Cheers Russ
24-09-2007, 09:13 PM | #69 | ||
[FONT=Arial Black]does any one know where i can get a enigne to ecu wiring diagram for a 2000 au xl ute[/FONT]
10-10-2007, 08:21 PM | #70 | ||
hey im looking for a wiring diagrame for an au falcon 4.l 6 so i can wire in my wolf v500
14-12-2007, 08:36 PM | #71 | ||
thnaks was very helpful, ui have installed the dvd and the dvd radio adn tv all works i jsut cant get the soubnd to come out of the speakers.. any thing i may be doing wrong??
and the blue cord coming from the dvd saying back is not connected to anythin maybe this has something to do with it but everythin else is working |
04-01-2008, 11:19 AM | #72 | ||
Does anyone no if there is possibly a AUX port at the back of the Stock CD player/radio in the AU Fairmont?
Egotism is the anesthetic that dulls the pain of stupidity
04-01-2008, 08:04 PM | #73 | ||
Hi can someone help
My aircon fan in the dash of my AU Fairmont Series 1 has gone troppo and only works on H which is flat out if I try 1 2 3 4 5 6 7 8 or9 I get no air at all only air on H any ideas thanks JOHN in Brisbane also looking for a rear wing in Mercury silver for my BA Ghia thanks |
30-05-2008, 05:44 PM | #74 | ||
jeffro
hi
does any one know what colour the wire is (in the harness to my stereo) that makes the controls on the steering wheel work? and the colour of the one that you can put an amp into. cheersss |
01-03-2021, 02:25 AM | #75 | ||
so google sent me to this link when searching for au falcon wiring info,
so will post on this old old thread. the wiring shown on this link for au falcon http://www.fordforums.com.au/vbporta...?articleid=688 it shows the pcm/ecm connector info, I have au1 1999 model, and colours are different to that shown. so assume that shown is for au2 or au3 if anyone requires correct colours for au1 drop me a message |
02-03-2021, 10:39 PM | #76 | ||
have modified pcm wiring pinout for au1 falcon, it has two extra wires not yet established what they are for at pins 7 and 44. Colours for au1 that are different to au2 and 3 shown also.
had to split into 4 pics to upload, you can cut/paste them into one pic tried to upload as one pic but to get the min file size ( 147kb) none of the writing was readable. |
