Old 26-01-2023, 07:59 PM   #1
ford12
Default Vacuum brake bleeder
Hello all.
Can I get some advice from the people in the know.
I bought a vacuum brake bleeder in the hope it would make it much easier to do.
I can not get it to work.
It holds vacuum and easily empties a container of brake fluid in no time.
Problem is it will not suck brake fluid from the bleed nipple, the most I can get out is a couple of drops.
What the hell am I doing wrong ?
Car is a FG mk11 6 cylinder ute.
ford12 is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2023, 08:35 PM   #2
ozpacman
Default Re: Vacuum brake bleeder
I'm wondering if the bleeder nipple might be blocked with crud Ford12?
ozpacman is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2023, 08:47 PM   #3
ford12
Unfortunately not, brake fluid would flow when the brake peddle was pushed
Old 26-01-2023, 09:39 PM   #4
XR Martin
XR Martin's Avatar
Sure you got enough pressure?
They generally need around 100psi.
2004 BA wagon RTV project.
Old 26-01-2023, 11:24 PM   #5
arm79
arm79's Avatar
Is this one of those ones that connect to a air compressor?
I bought one too, it sucks balls and doesn't do squat. It sits in the corner gathering dust now.
arm79 is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2023, 09:05 AM   #6
foxtrot3
foxtrot3's Avatar
Hi. try doing it with the lid off the master cyl. Cheers MD
HI
I'M MICHAEL
foxtrot3 is online now   Reply With Quote Multi-Quote with this Post
Old 28-01-2023, 11:19 AM   #7
Trevor 57
is now there
Trevor 57's Avatar
I bought a reasonably cheap one from Sydney Tools and it works fine - WITHOUT the brake pedal being pushed
https://sydneytools.com.au/product/d...e-bleeding-kit
Trevor 57 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2023, 12:32 PM   #8
ford12
My one is very similar, looks the same.
I must be doing something wrong.
Old 28-01-2023, 12:33 PM   #9
ford12
Tried this
Old 28-01-2023, 01:34 PM   #10
tbro4123
Usually it sucks around the threads on the bleeder nipple, try only opening it 1/4 of a turn.
or
Try gravity bleeding, open the nipple place a catch container under, make sure master cylinder is full and go and make a cup of coffee or tea. Check the master cylinder fluid level and top up once per wheel. Make a cup between each wheel and remember to go when needed.
Sure it's slow, but we found with the race cars it was the only way to guarantee a complete bleed (apparently drivers don't appreciate coming to the 1st corner and finding no brakes, go figure)
Stay safe
Terry aka Tbro
tbro4123 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2023, 04:36 PM   #11
hayseed
I second this Method, Sure It's time consuming But, It works..
hayseed is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2023, 10:45 PM   #12
olds
Vacuum bleeders work well in dealer situations where time is critical to do multiple operations. Pumping fluid via the pedal is the best. although requiring more people to accomplish.
olds is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2023, 09:42 PM   #13
ford12
I wonder if it has something to do with the ABS system
Old 06-02-2023, 07:10 AM   #14
Trevor 57
is now there
Trevor 57's Avatar
ABS is electronic not hydraulic
ABS is an over-ride system and only works when your foot is firmly planted on the brake pedal with the car running
Old 06-02-2023, 09:25 AM   #15
cs123
cs123's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Can't think of anyone more deserving. Russ Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all the technical support behind the scenes. Tech Writer: Recognition for the technical writers of AFF - Issue reason: Technical submission
ABS is both electronic and hydraulic.
I love Holdens....
cs123 is online now   Reply With Quote Multi-Quote with this Post
Old 06-02-2023, 02:58 PM   #16
Trevor 57
is now there
Trevor 57's Avatar
electronic activates hydraulic, they are not interchangeable, I can back it in your car doesn't have electric brakes
