Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > ASL automedia
ASL automedia Specialising in the upgrade of BA/BF/Territory and FG audio and visual systems. We also repair all Ford (OEM) car stereos and produce OEM quality wiring harnesses. Website Link
Old 07-08-2006, 09:37 PM   #1
GhiaMonster
SY Ghia AWD
GhiaMonster's Avatar
Question HDD Multimedia
Hi Fadi.
I'm looking to install an MG-25 (or similar) HDD Multimedia device into my Territory for playing all media, but especially mp3s. Obviously it needs constant video for menu navigation.
It looks like all I really need is something to convert Component Video (Y, Pr, Pb) to RGBs and connect to the ICC input, and a booster cable for stereo audio.
I also want a Composite Video-in for a reversing camera.
I have the diagram for the RGBs input to the ICC.
Do I need your $420 manual unit? Will it do separate Component and Composite inputs? Do you have a stand-alone (read cheaper) Component to RGBs converter? Can it be installed to switch to cam when reversing even if the video is in use by the MG?
Thanks in advance,
Ross
GhiaMonster is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2006, 10:42 AM   #2
FADI75
Sponsor
Originally Posted by GhiaMonster
Hi Fadi.
Thanks in advance,
Ross
Hi Ross,
It appears you dont need a Component to RGB converter. The MG-25 has composite out. It doesnt specify if the Stereo outputs are RCA but I am sure something could be worked out. All you would require is a normal converter. We can supply these to operate your MG-25 and a reverse camera and yes it will switch to camera when reversing even if the video is in use by the MG.
fadi75
FROM FALCON BA THROUGH FGX, TERRITORY SX THROUGH SZ - ICC UPGRADES, REPAIRS & INTEGRATION SPECIALISTS
AUTHORISED FORD REPAIR CENTRE
website: www.aslautomedia.com.au
email: info@aslautomedia.com
AUDIO INTERFACES, REVERSE CAMERAS, SATELLITE NAVIGATION & VIDEO INTEGRATION ON FACTORY COLOR SCREEN
FADI75 is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2006, 10:53 AM   #3
GhiaMonster
SY Ghia AWD
Thanks Fadi.
They supply cables which convert their phono-outs to RCA (up to 6 of them for Y, Pr, Pb video and either left & right audio or digital coaxial audio) so I just need something to convert to RGB and provide the sync. Of course tidy cabling and switching would be a bonus. Can you give me some detail and price please?
Thanks for your prompt reply.
Ross
Old 08-08-2006, 12:21 PM   #4
GhiaMonster
SY Ghia AWD
Oh yeah - the only reason I wanted component was for the higher quality.
If your experience is that it doesn't matter much for the small ICC screen and that the quality of the composite is perfectly reasonably, then I can save myself the money and hassle I suppose. The MG-25 provides both.
Old 08-08-2006, 01:07 PM   #5
FADI75
Sponsor
I wouldn't worry about using Component. Regardless you would probably lose some quality converting from component to RGB. The picture is great using composite. Anyhow the kit is the same price regardless of the single or dual input for reverse camera.
Regards
fadi75
Old 08-08-2006, 01:41 PM   #6
GhiaMonster
SY Ghia AWD
Thanks mate. I presume you mean the standard $420 dealie which I can get direct through you and have posted to Canberra.
Thanks for your help - again.
Happy camper :eclipsee_
Old 08-08-2006, 04:04 PM   #7
FADI75
Sponsor
Correct, When you ready mate.
cheers
fadi75
