10-10-2007, 07:27 PM | #1 | ||
We got a live one Maxy
Hi there guys,
I have an issue with the aircon/heater fan in my AUII Futura. Everytime I accelerate above 2000rpm the air is re-diredted out to the windscreen instead of through the vents. Once the car reaches it's cruise the air is again directed through the vents. Sounds like a vac line isn't doing it's job or something similar to me. Would like to get this sorted out before the heat arrives. Thanks guys : |
01-03-2018, 09:12 AM | #2 | ||
Bit of a thread mine here I know but has anyone got a solution to this? Mine would be more engine bay related I think as the car has recently had an engine swap
05-03-2018, 09:39 PM | #3 | ||
5.8,
It is a record thread mine alright. Re the problem, it sounds like vacuum related. Check vacuum lines in engine bay. Regards, George V. |
05-03-2018, 09:47 PM | #4 | ||
Here's a recent thread that will help:
https://fordforums.com.au/showthread...ghlight=vacuum |
05-03-2018, 09:53 PM | #5 | ||
I fixed mine, it was the vacuum line beside the fitting where the brake booster hose connects. It had come off, I was probably a bit slack hooking it up when I put it back on.
Thread Tools | |
Display Modes | |
