Old 04-02-2014, 11:30 PM   #1
car10002
Default important exhaust sound
hi
someone has a eb s pack with a standard 4 litre engine with extractors that go half way down the engine such as these http://members.dodo.net.au/~cason2/lukey.jpg
and a redback 2.5 inch exhaust with front and back mufflers such as this http://www.performanceexhaust.com.au...20HS1005_1.jpg
but using the standard ford cat converter
have a ef fairmont with a 4 litre engine with the exact above but a high flow cat and want to make it sound as deep as that eb does with the exact same extractors and exhaust
the note on the eb is deeper than the ef with the same exhaust and extractors for some reason. the ef has had a xr6 ecu in and does go quite good with it
would the cat converters have anything to do or what else could it be
both eb and ef have the exact brand exhausts and extractors both models with front and back mufflers
car10002 is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2014, 10:06 PM   #2
3.9from hell
hoons cause global warmin
Default Re: important exhaust sound
think you will find its the intake manifold making the difference
"if you believe you can, or believe you cant, your probably right" (henry ford)
3.9from hell is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2014, 09:53 AM   #3
car10002
how do you get a ef to sound deeper but not loud even though it still sounds good or would a noisy power steering pump drown the exhaust sound a bit
Old 08-02-2014, 02:20 AM   #4
3.9from hell
muffler choice
Old 09-02-2014, 01:06 AM   #5
car10002
redback rear and mid muffler 2.5 inch is what the eb has just that and 2.5 inch pipe and extractors and cat converter.
do high flow cat converters change exhaust sound
do longer extractors change the exhaust sound from using shorter extractors
what brand extractors are better pacemaker redback lukey some on ebay that look same as pacemaker longer ones that you can buy high flow cats that bolt straight on
Old 09-02-2014, 08:15 AM   #6
ZA-289
ZA-289's Avatar
Berklee mufflers sound the best imho.
ZA-289 is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2014, 08:00 PM   #7
3.9from hell
all these things affect sound. as does comp ratio, headwork. cam profile, mixture and timing, intake design, even spark plugs
Old 10-02-2014, 08:07 PM   #8
ROOSTA
DFDFDF
ROOSTA's Avatar
Take my advice guys... Dont waste your time with this guy's posts... He will just come back with some other stupid post.. And always lately its 'important'...
ROOSTA is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2014, 07:51 PM   #9
Mad Drummer
EF XR6
Mad Drummer's Avatar
To be honet man. I get the whole "i love that sound" but just make your car sound like it does. Make it sound unique. If all cars sound the same then it would be boring. Diffrent is good...diffrent stands out more
www.OzEcruisers.com.au
95 EF XR6:
5spd Manual, 3.45 LSD diff gears, JIM MOCK EXTRACTORS, 2 1/2" sports exhaust Short shifter, Pod filter in standard air box, 17 inch EL gt rims in gold.
Lowered all round with king springs and pedders supsenion
Mad Drummer is offline   Reply With Quote Multi-Quote with this Post
