Old 30-04-2012, 10:19 PM   #1
Kryton
Kryton's Avatar
Default Door lock actuators - different?
Anyone know for certain if series 1 door lock actuators are the same or different to series 2 and beyond?
Old 01-05-2012, 06:37 PM   #2
Rambunctious
Default Re: Door lock actuators - different?
Go into ebay, there are usually a few for sale and the sellers list the difference.
http://www.ebay.com.au/sch/i.html?_f...All-Categories
Rambunctious is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2012, 06:39 PM   #3
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
series1 au are Different to series2/3 They will not work (wireing layout)
hope it helps
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2012, 12:33 AM   #4
Kryton
Kryton's Avatar
Looking at Ebay, none seem to be listed specifically for the Series 1, some even say they all fit.
Do the series 1 have the white plug?
Old 06-05-2012, 12:35 AM   #5
SSD-85
Interesting.
I have a fully functioning AU2 actuator in my AU1....
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2012, 06:40 AM   #6
Jas98XR6
Jas98XR6's Avatar
Just replaced one of mine from the the wreckers out of a ba hooked straight up only difference was the steel rod to the handle was a little longer so used the old rod works perfect.From what I understand the plug didnt change untill the bf which u will need the wiring patch harness to hook up to earlier models.
Jas98XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2012, 12:01 PM   #7
GasoLane
Former BTIKD
GasoLane's Avatar
Give these guys a call, they know their stuff, click on any actuator link, his ph number is there.
http://stores.ebay.com.au/STRUT-ACTU...=p4634.c0.m322
Old 08-05-2012, 12:33 PM   #8
bartsau
bartsau's Avatar
I have used series 2 in a series 1 before and then when you lock the car all the locks do a routine if lock unlock lock every time you lock it or open it. Ended up swapping the broken gear in the lock from the series 2 into the series 1 lock pug it back in and it was good as new.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
Old 08-05-2012, 01:07 PM   #9
blownv8au
Pro Street Au Ute
blownv8au's Avatar
I seem to recall when doing mine that its a b series that i got for my au1.
Daily. AU XR8 s2 ute auto
Weekender. AU XR8 s2 sedan. 427 windsor, t56 magnum. 3.9 locker.
blownv8au is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2012, 08:16 PM   #10
BHDOGS
My friend got his series 1 au actuator replaced with a ba/bf type and on locking unlocking it's locks 3 times up down could this be why? Longer ba rod or something?
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2012, 08:38 PM   #11
Jas98XR6
Jas98XR6's Avatar
If he used the rod that he got with the ba actuator than yes it wont work properly as i tryed doesnt sit in the right position also i forgot to metion the cable for the interior handle is a touch longer on ba as well had to use the origional apart from that actuator is exactly the same with the white plug.
Old 08-05-2012, 09:39 PM   #12
Kryton
Kryton's Avatar
I actually did use these guys when i ordered the actuator the other day.
Told them what the vehicle was and its in the mail already.
Funnily enough, after putting the purchase off for a few days and then deciding to go ahead with it, i went out the next morning and the dorr lock works fine again - typical.
Ill replace it anyway along with all the locks and ignition barrel - all are either worn or dodgy.
Old 09-05-2012, 10:55 AM   #13
macman
macman's Avatar
They are different, as others have said.
I used the (larger) cog and slider from a passenger side AU2 lock to replace the broken (smaller) cog in my AU1 drivers side lock.
Make sure you grease the cog very well.
macman is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2023, 02:54 PM   #14
FroudeyBrand
Just to dig up this thread and not make a new one are BA Falcon Ute door actuators different from the sedan fronts?
FroudeyBrand is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2023, 06:23 PM   #15
mad2
Regular...with metamusal
as far as i know - i believe they are not .... however have never had a ute one to compare.
Old 03-05-2023, 04:00 PM   #16
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
I did a quick search on eBay and Au, Ba and Bf come up the same.
Old 21-05-2023, 01:38 AM   #17
mad2
which they are not - but ask GT Legend as he is the best to say yes/no
