Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Pit Lane Performance
Pit Lane Performance Pit Lane Performance, tuning for power and satisfaction. Website Link
Old 21-10-2015, 08:58 PM   #31
99AUXR
Brad
99AUXR's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Installing starter motor advice on ba / bf 6cyc Falcon.
Default Re: FG Fuel pump testing
Sorry unsure on that one.
Silhouette BF MKII F6
Plazmaman Intercooler Kit, ID1000, 34mm Internal Wastegate and Turbosmart Actuator, Tein Coilovers, Focal Audio, XXR 521 18x8.5 18x10
99AUXR is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2016, 01:01 PM   #32
gp351
Papa Smurf
hi, this is no doubt quite a lame question, for you guys ,but I bet you can help me!!..Worked on a FG XR6 Non Turbo only 110,000ks its a really well looked after car, almost stalling when stopping when cold. Everything fine when hot, and even when cold motor hammers, heaps of power. Checked and cleaned throttle body, was quite clean anyway. Check air filter OK. Checked fuel filter, stuffed full of crap and only been on for maybe 15,ooo ks "holly cow a real bad batch of fuel from somewhere"!!!!. Changed it and motor I am guessing seemed the same (gets hard to check something like this when it needs to be dead cold!!). But anyway I am hoping it may improve itself...maybe computer has to re tune itself?... maybe a bit of crap got into injectors?. Couple of questions, if crap has got into injectors is it worth replacing injector filter baskets...I have never done this before. Also somebody said change fuel pressure regulator...would have thought fuel pressure problem would be more constant fault, and from my experience usually worse hot..... any ideas.
gp351 is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2017, 09:19 PM   #33
ratter
ratter's Avatar
Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful.
Just bumping to the top as we are getting asked about fuel pumps a lot recently
20 Rosella St Frankston 03 9783 8122
Authorised KPM, Herrod Motorsport & SCT Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2017, 05:02 AM   #34
xyfalcon383
xyfalcon383's Avatar
Hi have you done any testing on BF f6 fuel pumps seems some people are running alot of power through the stock pump ?
xyfalcon383 is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2017, 08:28 AM   #35
ratter
ratter's Avatar
Is there a difference on those pumps?
Many people have fuel systems working beyond their actual capabilities to work 100% correctly, their results are based entirely on the afr number, this is not a true indication things are working as intended
Old 03-08-2017, 08:19 PM   #36
xyfalcon383
Will a Walbro 255 gss342 fit straight into a bf f6 typhoon fuel pump carrier or does it need to be modified ?
Old 03-08-2017, 10:17 PM   #37
ratter
ratter's Avatar
They go in but it's not just as simple as pulling one out and the other just takes it place
Old 23-11-2017, 11:42 PM   #38
M5R
Hi Guys
Which part # do i need to order for my FG XR8 Ute?
I'm chasing 400kw.
Cheers Matt
The Meek shall inherat the left lane
M5R is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2017, 09:07 AM   #39
ratter
ratter's Avatar
Herrod and Streetfighter both offer drop in set ups to support that power level
Old 27-03-2018, 11:14 AM   #40
pulonium
pulonium's Avatar
Thanks for this interesting thread.
I need a new fuel pump for my 09 FG G6eT.
The stock pump is causing issues when starting the car after it sits for long periods of time (eg over the weekend). It appears to be slowly losing fuel pressure.
If i prime it for 30 seconds or slow it's fine, and it always starts on the second try. I've replaced the battery with a quality high cca one and the problem remains.
What's a quality pump that can just plug in, that is a different brand than the stock oem one which i want nothing to do with ever again.
pulonium is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2018, 04:21 PM   #41
ratter
ratter's Avatar
if you can find a cradle assembly fitted with a 255 lph walbro, it should be close to drop in and not have to worry about other issues
Old 28-03-2018, 08:23 AM   #42
pulonium
pulonium's Avatar
cheers for that, much appreciated!
Thread Tools
Display Modes
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
