Old 12-02-2023, 11:40 PM   #1
Franco Cozzo
Franco Cozzo's Avatar
Default Ineos Grenadier Review - Land Cruiser 70 series competitor
Good to see a new competitor on the block to the Land Cruiser 70 series:
The 3.0-litre twin-turbo diesel six makes 183kW of power (3250-4200rpm) and 550Nm of torque (1250-3000rpm) and is capable of moving the Grenadier from 0-100km/h in 9.9 seconds.
The 3.0-litre single-turbo petrol six makes 210kW of power (4750rpm) and 450Nm of torque (1750-4000rpm) and is capable of moving the Grenadier from 0-100km/h in 8.6 seconds.
Both engines come mated to a ZF eight-speed automatic transmission (codenamed 8HP51 for the petrol, 8HP76 for the diesel), with what Ineos calls a new “heavy duty” torque converter.
https://www.carexpert.com.au/car-rev...enadier-review
It gets a very positive reivew, this thing looks to be a good competitor to the Land Cruiser 70 series wagon, about similar pricing.
Although I'm concerned over the choice of those engines, they spend so much time and effort ruggedising that vehicle, right down to the choice of recirculating ball steering rack, to then put BMW engines in it - not exactly known for their robustness
They should have used a truck manufacturers light/medium duty diesel engine and then either the GM L8T or the Ford 7.3L V8 options I reckon for the unleaded job.
Old 12-02-2023, 11:48 PM   #2
Default Re: Ineos Grenadier Review - Land Cruiser 70 series competitor
Has there been much chatter on its repairability? Field serviceability through to panel work. Does it have redundancies or safety modes for longer range recovery?
I’m impressed it has got this far, I would be tempted if shopping in that bracket.
Although I’d rather the fellow behind it all had sunk the same coin into exact reproduction Phase IIIs.
Old 12-02-2023, 11:50 PM   #3
Franco Cozzo
For owners who want to carry out work on their Grenadier themselves, Ineos is taking a novel approach by providing online 3D interactive manuals with support from the technical team at HQ a call or a click away.
“The vehicle has been deliberately designed and engineered to be easy to work on inside and out,” the company claims. It bills its “open source” approach, without trying to “ring-fence” buyers into its own ecosystem, as a point-of-difference for enthusiasts.
This is very promising, they've also got in bed with the Bosch service centres nationally as their national agents for maintenance.
Old 13-02-2023, 10:19 AM   #4
Vesper Martini
Vesper Martini's Avatar
They will be using the
B57 (diesel) and B58 (petrol).
The B57 is pretty much Bullet Proof & the B58 is the new 2JZ
They are about as Robust as you can get?
I think I posted an article about The Grenadier a while back, as I was impressed with the engine choice
Put a B57 in a Thai special & it would be the best on the market.
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2023, 10:58 AM   #5
I read deeper than the linked article last night, out of curiosity. It’s interesting to note that a vehicle initially pitched as the nadir of “Britishness” by a Brexit cheerleader (its founder) has resorted out of necessity to making use of many European assets.
My impression is that it’s going to be largely resident in the domain of up-spec’d soft roaders. Seems that diff locks, for example, are an option. I’d envisaged something that even in its most basic (cheapest) form could drag itself up to several hundred kilometres on two broken axles, with a torn brake hose and punctured radiator.
Another article (that didn’t get a test drive) reckoned the rear seats were significantly less spacious for grownups, than the linked one did. I’m surprised there is no basic cab-chassis version, it would come closer to meeting the 79 Series head-on.
The lack of a petrol V-engined “sporty” model to compete for aspirational AMG types, is probably a matter of budget right now but if Ineos muck around too long the aftermarket may resolve this, complete with R&P steering…
Old 13-02-2023, 11:59 AM   #6
Paull
P6 LTD
Paull's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For all the hard work performed around paint, trim, engine codes in the Classics section. General all round knwoledge and willingness to impart on others
I had thought that 70 series wasn't even available right now???
Toyota Australia has paused order-taking for the LandCruiser 70 Series as a customer-focussed measure, due to supply and demand factors that have resulted in extended wait times for customers
70 Series
Paull is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2023, 01:40 PM   #7
Hulsty
They are still being delivered and some dealers have them in the yard.
The Silver Bullet - BJ74
Where the actions at Ontrack 4wd Club
https://www.facebook.com/ontrack4wdclub
Hulsty is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2023, 01:49 PM   #8
Bossxr8
Peter Car
Bossxr8's Avatar
Exactly. Why have an engine that is quite complex and hard to work on. And going by stuff i see on other forums, they exceedingly go wrong and are fitted with a bunch of plastic parts that don't stand up well over time. It's an odd choice for sure.
Old 13-02-2023, 02:48 PM   #9
Vesper Martini
Interesting to note the B57(diesel) & B58(petrol) (and the S58) share the same block.
smart move to simplify things
Old 13-02-2023, 02:57 PM   #10
Franco Cozzo
I wouldn't call anything out of BMW 'bullet proof' or 'robust', its finnicky bull**** that demands you are spot on with maintenance that the moment there's a sign of neglect or rough use they **** the bed
I think its a horrible application for the type of vehicle it is,
GM L8T or Ford 7.3L would have been ideal - these things are engines that will run on **** high sulfur fuel like 91 all day every day under high load, plus you know you'd have circa 80KW more under the bonnet.
I reckon Cummins B6.7 Euro VI for the diesel variant.
Also the LC70 crowd loves 8 cylinders, given we'd be a key market for this vehicle I'm not sure why they didn't give it more consideration.
Maybe they got a good deal out of BMW.
Old 13-02-2023, 03:02 PM   #11
Where is that Cummins built now?
Is it China?
kevino is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2023, 03:04 PM   #12
Wondering how something like this might go, with the 4x4 8L90 though.
https://www.jegs.com/i/Chevrolet-Per...955K5/10002/-1
Old 13-02-2023, 03:06 PM   #13
Franco Cozzo
I'm suspect on passenger car engines for commercial vehicle type platforms where you're going to beat on it big time.
https://poweredsolutions.gm.com/products/?filter=engine
Check out their 'powered solutions' range of engines, there's plenty of interesting choices from GM.
Old 13-02-2023, 03:13 PM   #14
hayseed
Is it China?
Nope, still in The U.S.A. they were originally a Joint venture with CASE Farm equipment..
The ISF series are built in China with a Joint venture with FOTON
https://en.wikipedia.org/wiki/Cummin...ressure%20pump.
hayseed is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2023, 03:41 PM   #15
Vesper Martini
Mate Those are truck engines, the Cummins weighs over 500kg dry.
that changes they whole dynamics
You know our Police cars have the same engines, I cant even find any examples of engine failures on these things.
Old 13-02-2023, 03:46 PM   #16
Franco Cozzo
Yes - I am aware how much they weigh
You'll find it in the RAM 2500 as well so its not exactly like its uncommon to see them in road going vehicles.
Given Victoria Police changes over its cars at the 40,000km mark you'll be unlikely to find any with problems, give it some time though, once they're 5 years old and 150,000km on the clock you'll see why BMW was a poor choice for the Ineos Grenadier.
If you're worried about the Cummins engine and its weight, go look at the steering rack the Ineos Grenadier has.
Old 13-02-2023, 03:52 PM   #17
Vesper Martini
I think Dong Feng make Cummins engines too
http://www.enginecummins.com/dongfen...ne-co-ltd.html
But probably for their own purposes i came across this when looking at their military vehicles.
Either way the Ineos Grenadier is going to be built in France. doubt they would get engines from china or the US
Old 13-02-2023, 04:17 PM   #18
Grenadier has recirculating ball steering like an early Falcon, doesn’t it?
Old 13-02-2023, 04:37 PM   #19
Wretched
Render unto Caesar
Wretched's Avatar
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson
Wretched is online now   Reply With Quote Multi-Quote with this Post
Old 13-02-2023, 04:46 PM   #20
Franco Cozzo
Originally Posted by Wretched View Post
No one has seemed to show engine bay shots yet, curious to see what its like under the bonnet.
Old 13-02-2023, 04:48 PM   #21
https://outbacktravelaustralia.com.a...rge/grenadier/
Old 13-02-2023, 04:52 PM   #22
Franco Cozzo
I'm a big fan of the fuse box and the batteries being under the rear seat, it all looks rather easy to get to although its limiting you to AGM batteries rather than traditional lead acid jobs because the batteries being inside the cabin. Also the switches on the roof are great, kind of like the new Ranger and its overhead switch panel allowing you to very easily add extra accessories to the car right off the factory floor.
Old 13-02-2023, 05:28 PM   #23
Burnout
Falcon RTV - FG G6ET
Burnout's Avatar
Mmmm, cant see a lot of success here YET, for this vehicle. As to it being a 79 Series challenger, just go have a look at every & i mean every rubbish dump in regional Aussie. Just loaded up with 79 Series parts.
BAII RTV - with Raptor V S/C.
RTV Power
FG G6ET 50th Anniversary in Sensation.
While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about.
“Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”.
Burnout is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2023, 06:14 PM   #24
Franco Cozzo
Its so British that its built in France and has German driveline
Old 13-02-2023, 06:29 PM   #25
Vesper Martini
To be fair even the Brits wouldn't want it built by a Brummie with a landy box
Old 13-02-2023, 06:49 PM   #26
I’m sure they will reclaim its nationality somehow. Maybe a free oil leak and some iffy wiring to the lights.
Or it comes with chip butty and an “Ey up me duck” T-shirt.
