Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Bendix
Bendix BENDIX Put your foot down with confidence
Old 26-01-2012, 06:52 PM   #1
G6ET8U
GTX Turbo & KB Blown
G6ET8U's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: ALWAYS goes out of his way to help others in need, never posts rubbish only facts he has learnt the hard way or with success in his personal experiance. Takes the time to aid more junior members and overall is a solid contributor to AFF.
Default Choosing between Ultimate and SRT.
Looking for advice from you guys here on pad selection.
I have read about the SRT's being a bit noisy but better cold than the Ultimate.
Will be running DBA 4000 rotors. Originally I was looking at Brembo's but now looking away from that as I am not prepared to spend nearly 7k including new wheels (extra spare to clear and tyre) just for brakes I'm never going to track race.
Dust is a consideration too though I also understand that dust is expected with both as that is a consequence of the brakes actually working.
Cheers.
DARTH 2008 FG G6ET
465.6rwkw
not a 10 @ 134.81 MPH
SNOW WHITE 2004 BA FPV PURSUIT
2.6L Kenne Bell
Brembos all round
Twin Screw Awesomeness
Supported, serviced and tuned by
BLUEPOWER RACING DEVELOPMENTS
http://www.fordforums.com.au/showthread.php?t=11354744
G6ET8U is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2012, 03:33 PM   #2
motorculture
motorculture's Avatar
Default Re: Choosing between Ultimate and SRT.
Both the Ultimates and SRTs will work great when cold.
If you are not going to track your car then it would be best to stay clear of the SRTs. Ultimates will be better suited to your needs, they will also create less noise and dust than the SRTs however as you mentioned they are not dust free.
With an increase in braking performance will usually result in an increase in brake dust and noise.
SRTs will also be harsher on your brake discs.
Hope this helps
Automotive social media http://motorculture.com.au or call us on 02 9418 9008
For some daily car culture check out http://zengarage.com.au/
motorculture is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
