Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Bendix
Bendix BENDIX – Put your foot down with confidence
Old 15-01-2013, 03:45 PM   #1
motorculture
motorculture's Avatar
Default Dealership ‘Vs’ Aftermarket – Brake Service
This is something that can be toyed with, with any aspect when maintaining the car. The question always arises, is it cheaper/better to go factory? OR Should I use aftermarket parts? Earlier in the week we got to work to try and answer these questions for ourselves.
The car at hand was a 2008 Mazda 3 MPS, the owner need to change brake rotors, pads and fluids. After receiving a quote for parts and installation from Mazda at $1989.24 (see break down below), we crunched the numbers and purchased a set F+R DBA Replacement Rotors ($580.00), F+R Bendix Brake Pads ($215.00) and Bendix Brake Fluid ($20.00).
We have all the ingredients ready, so work started. We got car up on jack stands and first took apart the Brake System. Dismounting the calipers, removing the old brake pads and brake rotors. From there a quick clean to all parts, using the Bendix Brake Cleaner / Degreaser we had purchased.
Clean, prepped and ready for the new aftermarkets rotors and pads to be installed. On go the DBA Brake Rotors, followed by installation of the Calipers and the new Bendix Brake pads. Now to bleed the brakes, a quick double check all nuts and bolts are tight and on go the wheels!
After spending about 2.5hours from start to finish, and saving $XXX we’re confident to say DIY Brake Servicing is the way to go!
Mazda Service Center Quote:
For more information on Bendix products Click Here
Automotive social media http://motorculture.com.au or call us on 02 9418 9008
For some daily car culture check out http://zengarage.com.au/
motorculture is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2013, 06:36 AM   #2
PHANTMXR6
It's not an FG MKI.......
PHANTMXR6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Willing to help out with useful advice in the technical areas of the forum.
Smile Re: Dealership ‘Vs’ Aftermarket – Brake Service
Whilst DIY can save you money, it also needs to be taken seriously when dealing with brakes and steering.
I would suggest anyone attempting any DIY on either brakes or steering systems to ensure they use the correct torque specs for all nuts and bolts.
06/08 Manual FG XR6T. Not an FG1 or MKI, an FG...
Want to know how to do an A Service for an FG XR6T?
Look in this http://fordforums.com.au/showthread.php?t=11339404
Thinking of oil sampling your engine?
Have a look at this trend http://fordforums.com.au/showthread....ght=oil+sample
PHANTMXR6 is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
