Old 26-12-2005, 05:47 PM   #1
0xyg3n
0xyg3n's Avatar
Default Another DIY Mod Short OEM Aerial.
Found this mod on a US focus forum. I was going to say this is a simple mod to do but I had a ***** of a time getting the little knob off the end of the aerial.
You need to heat the knoby bit on the end cos its glued to the shaft and pry it off. Took me about 20mins. I would just boil up some water and sat it in that for abit. Then used a very small fat head screw driver to brake the glue. the rest was easy once the knob was off.
Just use a hacksaw to trim to desired lenth. Its just a fibreglass shaft with a single copper core. Just be carefull how much you cut off because the shaft is tappered and the knob may not fit back on. I only trimmed mine down to 240mm from 424mm. No need to glue it back on because it was very tight putting it back on.
Lol what an essay for a simple mod. Pic below.
http://users.ncable.net.au/~gtir/mod...l/DSC00281.JPG
0xyg3n is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2005, 06:00 PM   #2
0xyg3n
0xyg3n's Avatar
Another. Grrr who made the stupid 10min limit on edit posts.
Edit: radio still works fine. :P
http://users.ncable.net.au/~gtir/mod...l/DSC00282.JPG
Old 27-12-2005, 01:21 PM   #3
joshf2
striped
joshf2's Avatar
and here i was looking a bmw shark fin antenna replacement. this is far easier
cheers
joshf2 is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2005, 07:47 PM   #4
Scareybear
GRRRR.....
Scareybear's Avatar
Nice work.
Scareybear is offline   Reply With Quote Multi-Quote with this Post
