Old 21-12-2018, 07:57 PM   #1
justbrett
Default Lifter recommendation?
Hi all
Just bought an AU2 XR8 and it sounds like at least one lifter has seen better days (still to confirm).
I was surprised when researching how much a set costs! Would anyone warn me away from something like this:
https://rover.ebay.com/rover/0/0/0?m...2F400280872029
Cheers in advance for the input
Daily: '08 FPV F6X Territory, #82
Project 1: XA Sedan, Barra swap incoming
justbrett is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2018, 09:05 PM   #2
fordomatic
fordomatic's Avatar
Default Re: Lifter recommendation?
For how cheap you got that XR8 I’d be putting some decent lifters in it. Hopefully that fixes the issue and if not it’s not a huge deal for how cheap you got it. Good pickup mate.
Old 21-12-2018, 09:24 PM   #3
justbrett
It would appear you have me at a disadvantage fordomatic ��
To whom am I speaking?
Old 21-12-2018, 09:27 PM   #4
fordomatic
fordomatic's Avatar
No disadvantage at all mate, you got the car for a really great price. I think regardless of the condition of the engine it was a great price and you did well.
Don’t skimp on cheap lifters, get some good ones. You will probably find it’ll be as quiet as a mouse once it’s done. New tires, exhaust and it’ll be good for rego.
Old 21-12-2018, 10:07 PM   #5
mcfly94
mcfly94's Avatar
FPR lifters will be perfect and their cheap
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2018, 09:26 AM   #6
XC50077
Drive'n Cruise'n Live'n
XC50077's Avatar
Wink Re: Lifter recommendation?
Check for broken valve springs, similar sound to crook lifter and is a known issue on the gt40p heads.
Cheers.
Enjoy your XR8.
XC50077 is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2018, 09:34 AM   #7
Sox
RIP...
Sox's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: As recommended by Ropcher. Personifies the spirit of AFF.
Hi all
Those lifters are good, and pretty much what's in there from new, can go 1/2 mil k's trouble free.
These are slightly better and can be revved a bit harder, but not really needed - M-6500-R302H.
As someone else mentioned, it could also be a broken valve spring, and is actually more likely.
Oval Everywhere...
Sox is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2018, 09:35 AM   #8
justbrett
Cheers XC. Valve covers off is the first step and have a good look around. Still drives ok so hopefully nothing major
Old 22-12-2018, 09:36 AM   #9
justbrett
Thanks Sox, I did find those H lifters later last night, probably worth the minimal extra spend, bit of insurance for future upgrades
Old 26-12-2018, 01:34 PM   #10
lotus
Since talking about lifter replacement, does anyone know where I can get the procedure for lifter replacement and proper adjustment of the rockers. Manual I have is the same as on the Tech Resources. Just shows SER1, and I'm looking for the 220 motor.
We salute those brave souls that enter the DARK side
lotus is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2018, 03:00 PM   #11
Sox
RIP...
Sox's Avatar
The 220's had these - M-6500-R302H, so if you throw them back in you shouldn't need to readjust.
The replacement procedure is the same as any AU Whinger.
The RR's bolt on the same way as the stockers, no adjustment.
Oval Everywhere...
Old 26-12-2018, 04:05 PM   #12
lotus
I've got Crow 5300H lifters which are supposed to be a replacement for the original lifters.
To tension down the rocker bolts (30Nm), what position does the crankshaft have to be at. Thinking TDC would not be right as the pushrods would not be at the lowest point of the cam lobes, but maybe this does not matter as the lifters are hydraulic. Do the exhaust and inlet have to be tensioned at different positions. Thought they had to turned down about 3/4 of a turn after tension reached. But maybe I'm thinking if single rockers.
Also thinking of doing the springs as well ( got a set of Crow replacement). Anyone recommend a good spring compressor. Found one in US (LMT) but not sure which one I need. Sold here at Outlaw Speed Shop and are around the $380 mark
Have not replaced lifters before, that's why the questions.
Old 26-12-2018, 04:28 PM   #13
Sox
RIP...
Sox's Avatar
If the lifters are the same dimensions as the original lifters (and they should be), then no adjustment needed.
If the height is slightly different, then you might need to farnackle around with shims.
Wind them down about 0.030" preload.
TDC is is what you want, otherwise you won't get the lifters out on the corners.
Grab one of these for the springs -
https://www.ebay.com.au/itm/Universa...VXkl:rk:2:pf:0
Oval Everywhere...
Old 26-12-2018, 06:14 PM   #14
lotus
Just pulled off the rockers and pushrods and found a problem.
The rocker on No3 exhaust was loose. When rocker removed the exhaust pushrod came out with it. It seems the cup that the pushrod sits in has been pushed into the rocker arm, giving it the excess movement. Pushrod end is marked.
pictures of the rocker and pushrod
Is this a known problem with these rockers or am I just lucky!!
Old 26-12-2018, 06:21 PM   #15
Sox
RIP...
Sox's Avatar
It's happened before.
Just chuck another rocker and pushrod in.
Some say they YT's are crap because of it, but that's a load of bollocks.
Oval Everywhere...
Old 26-12-2018, 06:31 PM   #16
lotus
I've got another set of YT rockers in the shed but they seem to have a bit of what appears to be pitting on the roller for the valve. Is this a problem or ok to use. If a problem, can the pin that holds them on be removed and use the roller from the faulty one.
What pushrods would be the best to use.
Old 26-12-2018, 07:38 PM   #17
Sox
RIP...
Sox's Avatar
Minor pitting may not be a problem.
They can be knocked out easy though, but only one way as one end is splined.
Just use stock pushrods.
Oval Everywhere...
Old 26-12-2018, 07:42 PM   #18
lotus
Thanks for the info.
much appricated
