Old 17-08-2012, 08:10 PM   #31
LimeGlaze
LimeGlaze's Avatar
Default Re: Complete Auto Trans Oil Change - Howto
I have just completed a trans service and flush on a BA XR6 Turbo, using this and associated threads - thanks to the original posters. A couple of points I thought to add to the thread for anyone doing the same or similar:
Having the benefit of a car hoist and full workshop facilities and having installed a new trans filter and gasket, I chose to remove the rear trans line to drain the old fluid out. With the car up on the hoist and the owner installed in the drivers seat, it was a quick and easy job to have the car run and shut off to catch the old fluid and a drum pump was used for new fluid straight into the trans. For those of you playing at home and choosing to use the trans lines by the radiator - the lower line is the trans fluid outlet.
I must admit I would rather work on an old XA, but mates will drive late model Falcons!
Clint
LimeGlaze is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2018, 12:10 PM   #32
Tony_P
Anyone know which is the pump pressure side of the trans on a BF? Front or rear line? I'm going to guess rear so it's not starved of oil when the car accelerates....
Tony_P is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2019, 03:26 PM   #33
battlewagon
Thanks to all the posters here for great write ups and responses. I just finished doing our 99 AU XR6, it's standard height so checking the level was done without putting the car on stands. I did find the drain and top up a little hit and miss as even when engine is switched off there is still flow expelling the old oil. Checked and filled up 3 times after going through the gears while stationary.
Ended up using 14 litres of TQ95, ran the flush process a little too long.
Very smoothe, car has 200k on it but almost nothing stuck to magnet in pan, pretty happy with that!
battlewagon is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2019, 12:10 PM   #34
battlewagon
Originally Posted by Chewy View Post
Anyone notice much of an improvement in tranny feel after doing this?
Great write up btw.
So about 2 weeks after smooth gear changes and perfect operation the gear change from 1st to second is playing up. When cold it slips 2nd and seems to disengage revving up then bangs into what i assume is 2nd or third. Oil level is fine, oil used was TQ Castrol so at a bit of a loss.
Any advice would be most appreciated!
1999 Ford AU XR6 VCT Auto 200k
1997 Galant VR4 TT 125k
Old 19-06-2019, 12:23 PM   #35
Perhaps you should have adjusted the bands while you doing the fluid change. Per: www.servotechnica.spb.ru/viewdocument/BOOKS/CAR/SY/UNSORTED/Update$20EP.TRANF or http://fordforums.com.au/wsmpub//eflwx/7-1.html
Old 03-11-2019, 05:44 PM   #36
qunal
Dear all I tried to do transmission service but bunk nut is jammed any other way to put oil in.
qunal is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2019, 01:43 PM   #37
gregaust
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Greg always goes out of his way to provide assistance and support to members of AFF. Greg freely shares his knowledge with people who ask for help and often assists them with obtaining parts and repairs.  A great member of the AFF community. Technical Contributor: For members who share their technical expertise. - Issue reason: Always happy to offer assistance from his own experiences and often posts up photos when someone is having issues finding/locating something they are trying to repair or replace.
No the correct procedures are through the plug. Get a single hex socket , see if you can give the plug a few good hits first.
The plugs don’t need to be super tight as the o’ring seals it.
gregaust is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2019, 02:19 PM   #38
qunal
The problem is that I already messed up with the plug tried most of the method and lastly tried chisel and hammer too but no luck.
Old 04-11-2019, 09:27 PM   #39
This chap suffered similar travails recently, he triumphed in the end:
https://www.fordforums.com.au/showthread.php?t=11480847
