Old 13-08-2017, 09:26 PM   #1
Edxr6
Default Hood Insulation
Fellas,
How do you remove the plugs that hold the sound insulation under the hoods of the AU's.
Regards
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2017, 11:36 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Re: Hood Insulation
From memory, just pull hard?
Old 22-08-2017, 01:26 AM   #3
snap0964
You'll probably end up tearing it - they do go a bit brittle from the heat.
Usually use a trim removal tool.
snap0964 is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2017, 03:19 PM   #4
Mont5.0
Mont5.0's Avatar
i use a set of side cutters, just dont close the jaws all the way shut.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2017, 07:29 PM   #5
Edxr6
Cheers fellas,
Regards
